Do It Yourself Apple Fusion Drive on Your Mac
Discussion in 'Apple Mac' started by dazpazz, Nov 3, 2012.
  1. dazpazz
    dazpazz Active Member
    Nov 15, 2009
    1,509
    +357
    Ever since apple announced Fusion Drive i have been pondering if it was possible to cobble together a diy Fusion Drive.. I found this video tonight on YouTube and thought i'd share it with the fine AVForums apple community :thumbsup:
    • Thanks Thanks x 2
  2. Jase Winter
    Jase Winter Active Member
    Sep 1, 2007
    4,777
    103
    +362
    Pretty cool but what I want to know is whether you run a bootcamp windows instal with this fusion drive set up.
  3. dazpazz
    Nov 15, 2009
    1,509
    +357
    Install windows on a mac?? Blasphemy!!!! :D
    Ive no idea how or if it would work with bootcamp..
  4. Jase Winter
    Sep 1, 2007
    4,777
    103
    +362
    Haha! I use it rarely but do occasionally need it for work/games. Might give it a try sometime.
  5. dave_parki_uk
    dave_parki_uk Active Member
    Mar 29, 2008
    1,527
    +323
    according to the apple FAQ regarding the official fusion drive you can create 1 new partition or a bootcamp partition.
  6. Jase Winter
    Sep 1, 2007
    4,777
    103
    +362
    very good read about the fusion drive here:
    Achieving fusion
    And as dave posted above you can indeed have a bootcamp partition, interestingly though that lives on the HDD only and i guess for obvious reasons doesn't share any of the fusion drive capabilities.
  7. malk
    malk Member
    May 15, 2008
    1,989
    +145
    So thats the command to "make fusion work"on the mac??
    Has anyone here tried it?
    Oh dear,justvseen the blokes tattoo,a mac logo........thats a bit sad imho
    Still,he knows his way round a mac,,
    So,does this mean,on my MBP,running ML,if i installed the ssd as my boot drive,used the superdrive bay,as a storage place for my 500gb hdd,then ran the terminal command of fusion drive,then,using carbon copy cloner,put my data back in,i would have a fusion drive MBP?.
  8. CamFire
    CamFire Active Member
    Apr 26, 2009
    3,920
    +516
    From that ArsTechnica report, it looks like failure of either drive sounds plenty of work later on to recover. I recall not using RAID-0 because of this.
  9. bpsmith
    bpsmith Member
    Jan 8, 2010
    7,615
    +708
    I think the point is that you treat it as a single drive and backup accordingly. Obviously there's double the chance of failure now though. :-(
  10. MrSynner
    MrSynner Member
    Mar 25, 2006
    340
    +47
    I tried it on my 2011 Mini - for a while - whilst fitting a new SSD last week.
    It is distinctly nippier than with just a mechanical drive, but the thought of losing TWO drives worth of data in a crash was too scary - I used to routinely operate RAID arrays in my PC days, and have very singed fingers.
    Also seemed to have quite some trouble installing Bootcamp to the Fusion drive too - Windows didn't seem able to 'see' the drive - not too surprising, as I think the Fusion process is software rather than hardware.
  11. dazpazz
    Nov 15, 2009
    1,509
    +357
    I will be deffo giving this ago on my 2009 MacBook Pro over the Christmas break and hopefully make it feel like a newer machine!!
    I know that the 0 & 1's are split across the drives meaning that lost or corrupt data can occur but surely if you backup on a weekly/monthly basis depending how much stuff you've put on your machine, it shouldn't really be an issue..
    Also isn't it easier to manage a single large volume, than it is to micro manage a small ssd??
    I've no real interest in bootcamp as I have a gaming rig if I need anything windows..
  12. hutch
    hutch Active Member
    Jun 29, 2006
    6,167
    +931
    Does this work on an iMac with two internal drives? The YouTube link seems to say that it only works with one internal and one external.
  13. Jase Winter
    Sep 1, 2007
    4,777
    103
    +362
    I would think so since thats the setup the new iMacs with fusion drives will have, only difference being that the SSD part of the new iMacs are custom non standard drives similar to what they are doing with macbook air/retina.
  14. Jase Winter
    Sep 1, 2007
    4,777
    103
    +362
    i'm very tempted to try a fusion drive set up in my macbook only thing that puts me off is the bootcamp stuff, from the article I posted it says the windows install will only go on the HDD, i've got quite used to my windows bootcamp install being nice and fast on a partition on the SSD and don't really want it to be limited to HDD speed.
  15. MrSynner
    MrSynner Member
    Mar 25, 2006
    340
    +47
    In theory, it should work on any Mac running two drives - under Mountain Lion. It seems to be a form of software RAID - combined with some cacheing and and file optimisation.
  16. nigelbb
    nigelbb Member
    Apr 4, 2005
    5,192
    103
    +497
    Except the SSD is 1000x less likely to fail.
  17. Jase Winter
    Sep 1, 2007
    4,777
    103
    +362
    Just about to give this a shot myself as I finally dug out my optical bay caddy, backing up my MBP then opening it up, will let you guys know how it went!
    • Thanks Thanks x 2
  18. malk
    malk Member
    May 15, 2008
    1,989
    +145
    Excellent,been dying for someone to try it!!! I would if i had the money to get the bits.
  19. nigelbb
    nigelbb Member
    Apr 4, 2005
    5,192
    103
    +497
    Sounds ideal for my Mac Pro that I just upgraded with an SSD & have been experimenting with Mountain Lion while still booting off a Velociraptor with Snow Leopard. Are there any written tutorials I really don't want o sit through some amateur YouTube video when I can read the same information in a fraction of the time.
  20. nigelbb
    nigelbb Member
    Apr 4, 2005
    5,192
    103
    +497
    I just found a detailed article with performance testing on creating a DIY Fusion drive MPG - Fusion Volume - Apple?s Fusion Drive Technology
    Unfortunately the conclusion in big red letters is:-
  21. malk
    malk Member
    May 15, 2008
    1,989
    +145
    Oh no,hope jase is reading this.
    Thats urinated on future fusion goodness.
    Is that on a MAC PRO?
    Not a macbook pro?
    Is there any major differences as regards to running fusion?
  22. nigelbb
    nigelbb Member
    Apr 4, 2005
    5,192
    103
    +497
    Who knows? The Fusion drive is only available on the new iMac & even then the 21.5" version can only have a 5400rpm 1TB drive whereas the 27" can have a 3TB 7200rpm drive. Even for the non-Retina MBP there is no option for a Fusion drive. So it could be some iMac specific code i.e. it will only operate if it is on a new iMac. It could be that the testing was flawed. It could be that real Fusion drives in iMacs show the same behaviour.
    Possibly there is no point to attempting a DIY approach as if you can fit two drives then you can just use the SSD as the boot & applications drive & allocate other files yourself rather than relying on some Fusion magic to do the work for you. MPG - Apple Mac Mini (Late 2012) - Mac Mini: Dual Drives Are Better than 'Fusion'
  23. Jase Winter
    Sep 1, 2007
    4,777
    103
    +362
    Well, got my second drive in the optibay and seem to have successfully set up the fusion drive, currently just restoring my backup which is gonna take some time but i'll let you know the outcome. I did test to see what would appear if I tried to do a fresh install and it did only show the one larger combined volume that I created though so looks to have worked ok.
    • Thanks Thanks x 2
  24. Jase Winter
    Sep 1, 2007
    4,777
    103
    +362
    Lol, just caught up on the other posts, I guess I'll find out pretty soon, ultimately i'm not too fussed either way as I wanted to put the HDD in and really was just playing about with the fusion stuff out of interest.
  25. malk
    malk Member
    May 15, 2008
    1,989
    +145
    Fusion also works on minis,i think its software in ML than anything really.
    The point is,its a cool feature,and if can be used,why not.
    I understand you can put the files wherever manually,but if you dont have to.....
  26. malk
    malk Member
    May 15, 2008
    1,989
    +145
    God speed jase,our thoughts and prayers are with you on this day...
    Lol,i reckon itll be cool.
  27. Jase Winter
    Sep 1, 2007
    4,777
    103
    +362
    I;m sure one of the other articles I read they tested and saw data moving back to the SSD, they could of course been testing on a new mac mini which can come configured with it, I can't really remember.
  28. Jase Winter
    Sep 1, 2007
    4,777
    103
    +362
    Having skimmed the last bit of the article Nigel posted, the points made are that it could be related to the mac pro hardware, being an older chipset, sata II not III, who knows!
  29. Jase Winter
    Sep 1, 2007
    4,777
    103
    +362
    Back up and running and all seems well, not sure how I'll be able to test if data is moved around in the long run though but following the guides online has created a single volume at least and my TM backup has restored to it no problem. I also get pretty much the same read/write speed I got on just the SSD before using blackmagic speed test.
    On a side note, my OCZ agility 3 SATA 3 SSD has never performed very well to begin with lol.
    • Thanks Thanks x 2
  30. nigelbb
    nigelbb Member
    Apr 4, 2005
    5,192
    103
    +497
    I think that all you need do is fill up the SSD like the guy on MPG did MPG - Fusion Volume - Fusion Volume Speed (OWC PCIe SSD + HDD)
    How old is your MBP. I have a 256GB Crucial C300 in my 2008 MBP & while much faster than the 7200rpm disk it replaced it' nowhere near the potential performance of an SSD as the disk i/o is throttled at SATA-I speed (just tested with Black Magic Disk Test app at 128MB/s & 135MB/s R/W). I have a 256GB Crucial M4 in my 2008 Mac Pro but it is also throttled but this time at SATA-II speeds so while I see around 250MB/s for both read & write the theoretical maximum of the SSD is nearly double.
