Do I need to charge my Iphone for 24 hours?
Discussion in 'iPhone' started by kingolympics, Jun 23, 2009.
  1. kingolympics
    kingolympics Member
    Dec 8, 2006
    310
    +6
    Would be really grateful if anyone can help me out asap.
    Just got my new Iphone, back in the day I was always told to charge new phoens for 24 hours the first time I charged it.
    Does this apply to the iphone?
  2. djcla
    djcla Active Member
    Nov 27, 2005
    5,821
    +238
    I have always done this also and I like to drain battery before charging too but not sure if it is All required sorry
  3. bigdavecox90
    bigdavecox90 Member
    May 27, 2006
    2,872
    71
    +46
    I know it does notify you when fully charged, but I usually find if you leave it on a bit longer then the battery lasts alot longer.
  4. Slackadder
    Slackadder Member
    Nov 18, 2007
    845
    +82
    Left mine to charge for 16 hours as stated by bod in o2 shop......
    Going to run down then fully recharge again and then after that try and recharge at circa 20%+ to make sure the battery gets a good start in life.
    Anthony
  5. RobM
    RobM Well-Known Member
    Dec 29, 2006
    13,107
    +2,184
    You really don't need to these days. Modern battery tech' doesn't require it, but it doesn't do any harm. The phone will simply stop charging when it's full so you wont gain any benefit from leaving it plugged in over night.
    What I would advise is using it straight out of the box and running the battery totally dry. Then charge it fully and let it run totally dry again. Do this a couple more times and then use as normal.
    Batteries get better over the first few charge cycles. But bear in mind a charge cycle of 100% can be two 50% charges (i.e. half to full) or four 25% charges (three quarters to full) or any other combination that adds up to 100% :)
  6. alan280170
    alan280170 Active Member
    Apr 18, 2006
    4,200
    +963
    If you want to, fill your boots. :)
