Direction of flow - Domestic Central Heating system
Discussion in 'General Chat Forum' started by Newton's Ring, Oct 14, 2008.
  1. Newton's Ring
    Newton's Ring Member
    Apr 26, 2005
    530
    +64
    Quick question - How do you determine the direction of flow of water through a radiator? I'm fitting a new radiator upstairs and the instructions say that the bleed valve must be diagonally opposite the flow.
    Any help would be much appreciated :lease:
  2. Bilbob
    Bilbob Active Member
    Feb 21, 2005
    4,399
    103
    +295
    In my experience, it is usually marked either on the boiler itself, or in the instructions for said boiler... either way, unless the plumber who installed it in the first place marked the pipes, you will be following pipes...:)
    • Thanks Thanks x 1
  3. John7
    John7 Member
    Aug 6, 2004
    1,549
    63
    +228
    If you've got an existing radiator there (or capped off pipework), fire up the system and feel the pipes - the inlet will be getting warm, the outlet will remain cold (or much cooler)
    • Thanks Thanks x 1
