Digitising CD's - Codecs, formats and the software needed
Discussion in 'Streamers & Network Music Players' started by Steven, Sep 27, 2010.
What is your format of choice? (Multiple Choice)
  1. *
    Wav
    38 vote(s)
    10.1%
  2. *
    Flac
    261 vote(s)
    69.4%
  3. *
    Apple Lossless
    62 vote(s)
    16.5%
  4. WMA Lossless
    11 vote(s)
    2.9%
  5. *
    MP3
    107 vote(s)
    28.5%
  6. WMA
    6 vote(s)
    1.6%
  7. *
    AAC
    17 vote(s)
    4.5%
  8. Ogg Vorbis
    4 vote(s)
    1.1%
  9. Online Music Store Subscription or downloads
    8 vote(s)
    2.1%
  10. Other format (post below!)
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. McChicken
    McChicken Member
    Mar 24, 2012
    14
    3
    +3
    Thank you all for the suggestions, my Q was moved here, so I did not find it until now. will read all info.
    thanks again
  2. Maxson
    Maxson Member
    Mar 26, 2011
    781
    +71
    I definitely prefer to buy in FLAC. Why buy lossy mp3 when space is not really an issue any more? If I can't buy in FLAC then I will buy the CD and rip to FLAC using Exact Audio Copy. Then I will fix the artwork with bliss. Sorted and ready to play on my Squeezebox Touch! :thumbsup:
    See my thread on buying music in FLAC and please add links to good music! http://www.avforums.com/forums/music/1509400-great-music-flac-wav-where-buy.html
  3. McChicken
    McChicken Member
    Mar 24, 2012
    14
    3
    +3
    Thank U, have decided to go with FLAC, as that seem to be the preferred option of most. will also check out your buying links, as there there soon are no more record shops around, and I refuse iTunes shop
  4. Gixxerblade
    Gixxerblade Member
    Nov 19, 2004
    462
    +45
    (Moved to this thread from the thread below by mod)
    http://www.avforums.com/forums/streamers-network-music-players/1651763-nas-windows-9-2-lossless.html
    The file type is wma though not 9.2 and wma-l is lossless (windows media audio-lossless) which he is comparing to flac (free lossless audio codec).
    I have seen some people say they hear differences between flac and wav, I use wma-l myself and couldn't pick out a difference between it and wav or flac but if you can then I would use the one you prefer.
  5. larkone
    larkone Active Member
    Apr 21, 2006
    2,456
    83
    +360
  6. Gixxerblade
    Gixxerblade Member
    Nov 19, 2004
    462
    +45
  7. Trollslayer
    Trollslayer Active Member
    Feb 11, 2007
    9,386
    +1,422
    FLAC is losseless and supports tags so suits me fine.
    CDex handles everything for me.
  8. Steven
    Steven Senior Moderator
    Feb 1, 2005
    35,725
    +5,412
    But if you cannot hear the difference yourself then why would you forgo the technical advantages of flac (comprehensive tagging, smaller filesize) over wav just because someone with different ears has a different perception?
  9. Gixxerblade
    Gixxerblade Member
    Nov 19, 2004
    462
    +45
    The comment relates to a different thread.
    I have no idea why it was moved here. To answer your question though they shouldn't - they should use whatever they prefer that suits their usage. I use a mixture of file formats including flac and wav but the majority are wma-l, I have no particular preference and use whatever I feel like using when ripping CDs. My comment was not meant for this thread.
  10. JUST ROCK
    JUST ROCK Member
    Jun 29, 2006
    279
    +14
    Hi, I loaded my Dire Straits Brothers in Arms (SACD) into the cd tray and started up EAC but the data base only came back with a standard Brothers in Arms CD, not a SACD, so I went a long with that.
    After ripping the Stereo layer of the (SACD) I thought it was ok as it says at the end of the logfile
    "All tracks accurately ripped, No errors occurred, End of status report.
    But after that at the bottom it says "You can use CUETools to repair this rip".
    What does this mean ? repair the rip with cuetools, when I thought that the rip had been accurately ripped.
    I Would appreciate an explanation
    Here is the logfile
    Exact Audio Copy V1.0 beta 3 from 29. August 2011
    EAC extraction logfile from 3. October 2012, 20:00
    Dire Straits / Brothers in Arms
    Used drive : MATpoopADVD-RAM UJ-850S Adapter: 1 ID: 0
    Read mode : Secure
    Utilize accurate stream : Yes
    Defeat audio cache : Yes
    Make use of C2 pointers : No
    Read offset correction : 102
    Overread into Lead-In and Lead-Out : No
    Fill up missing offset samples with silence : Yes
    Delete leading and trailing silent blocks : No
    Null samples used in CRC calculations : Yes
    Used interface : Native Win32 interface for Win NT & 2000
    Gap handling : Appended to previous track
    Used output format : Internal WAV Routines
    Sample format : 44.100 Hz; 16 Bit; Stereo
    TOC of the extracted CD
    Track | Start | Length | Start sector | End sector
    1 | 0:00.00 | 5:12.20 | 0 | 23419
    2 | 5:12.20 | 8:25.60 | 23420 | 61354
    3 | 13:38.05 | 4:12.37 | 61355 | 80291
    4 | 17:50.42 | 6:33.65 | 80292 | 109831
    5 | 24:24.32 | 8:30.73 | 109832 | 148154
    6 | 32:55.30 | 6:58.00 | 148155 | 179504
    7 | 39:53.30 | 4:40.17 | 179505 | 200521
    8 | 44:33.47 | 3:40.05 | 200522 | 217026
    9 | 48:13.52 | 6:59.58 | 217027 | 248509
    Track 1
    Filename C:\WAV Music Files\01 - So Far Away - Dire Straits - Brothers in Arms - 1985.wav
    Pre-gap length 0:00:02.00
    Peak level 98.8 %
    Extraction speed 0.8 X
    Track quality 100.0 %
    Copy CRC 04331C97
    Accurately ripped (confidence 89) [53CE6B94] (AR v2)
    Copy OK
    Track 2
    Filename C:\WAV Music Files\02 - Money for Nothing - Dire Straits - Brothers in Arms - 1985.wav
    Peak level 98.8 %
    Extraction speed 0.9 X
    Copy CRC 051F214D
    Accurately ripped (confidence 89) [6E3F966C] (AR v2)
    Copy OK
    Track 3
    Filename C:\WAV Music Files\03 - Walk of Life - Dire Straits - Brothers in Arms - 1985.wav
    Pre-gap length 0:00:01.46
    Peak level 98.8 %
    Extraction speed 1.0 X
    Copy CRC AE390C27
    Accurately ripped (confidence 88) [695BC006] (AR v2)
    Copy OK
    Track 4
    Filename C:\WAV Music Files\04 - Your Latest Trick - Dire Straits - Brothers in Arms - 1985.wav
    Pre-gap length 0:00:03.60
    Peak level 98.8 %
    Extraction speed 1.1 X
    Copy CRC 126DB23E
    Accurately ripped (confidence 89) [63896B70] (AR v2)
    Copy OK
    Track 5
    Filename C:\WAV Music Files\05 - Why Worry - Dire Straits - Brothers in Arms - 1985.wav
    Pre-gap length 0:00:04.53
    Peak level 98.8 %
    Extraction speed 1.2 X
    Track quality 99.9 %
    Copy CRC FEC19A7F
    Accurately ripped (confidence 89) [C859F565] (AR v2)
    Copy OK
    Track 6
    Filename C:\WAV Music Files\06 - Ride Across the River - Dire Straits - Brothers in Arms - 1985.wav
    Pre-gap length 0:00:07.80
    Peak level 98.8 %
    Copy CRC F0CB86E5
    Accurately ripped (confidence 89) [FFEF227B] (AR v2)
    Copy OK
    Track 7
    Filename C:\WAV Music Files\07 - The Man's Too Strong - Dire Straits - Brothers in Arms - 1985.wav
    Peak level 98.8 %
    Extraction speed 1.4 X
    Copy CRC C645819A
    Accurately ripped (confidence 87) [41A45F15] (AR v2)
    Copy OK
    Track 8
    Filename C:\WAV Music Files\08 - One World - Dire Straits - Brothers in Arms - 1985.wav
    Pre-gap length 0:00:02.16
    Peak level 98.8 %
    Copy CRC A12C9453
    Accurately ripped (confidence 86) [C85A8DDE] (AR v2)
    Copy OK
    Track 9
    Filename C:\WAV Music Files\09 - Brothers in Arms - Dire Straits - Brothers in Arms - 1985.wav
    Pre-gap length 0:00:02.80
    Peak level 98.8 %
    Extraction speed 1.5 X
    Copy CRC 31EBE1DA
    Accurately ripped (confidence 86) [77DA5AFE] (AR v2)
    Copy OK
    No errors occurred
    ---- CUETools DB Plugin V2.1.3
    [CTDB TOCID: FhuOllXhT7sAE0942nFgmdX0cfQ-] found, Submit result: FhuOllXhT7sAE0942nFgmdX0cfQ- has been confirmed
    [1e1d87a4] (025/328) Differs in 19 samples @05:07:69,05:12:35,13:36:38,17:44:23,24:19:62,24:24:46,39:53:43,44:33:60,48:13:67,55:04:45
    [5a486604] (300/328) Accurately ripped
    [45d40355] (001/328) No match
    [b89bb797] (001/328) No match
    [0192e314] (001/328) No match
    You can use CUETools to repair this rip.
  11. niall campbell
    niall campbell Member
    Nov 16, 2007
    886
    28
    +59
    as its near a Master Disc as you will get , its copy protected !!
  12. JUST ROCK
    JUST ROCK Member
    Jun 29, 2006
    279
    +14
    Oh ok. The ripped sacd does sound great, its a lot better than the remaster cd that is out. So I guess if it says
    All tracks accurately ripped I will leave it at that.
  13. andy1249
    andy1249 Active Member
    May 7, 2006
    6,116
    +1,235
    Theres nothing to worry about here really ,
    This first part ,
    It sees a problem with the TOCID , thats the Table of Contents , which , seeing as your comparing the SACD to a Standard CD , is to be expected.
    The numbers after "Differs in 19 samples" are roughly the start times of each track , which are slightly different on the SACD , again this is to be expected.
    Other than that , your rip is fine.
    It is very often the case that people just use the database entry for track names and don't concern themselves with whether or not the entry they are using is ripped from the same master/pressing.
    As such , a lot of the data in the accurate rip database is incorrect. Especially with titles like this that have so many different releases.
    That is usually OK so long as no features are enabled in the ripping software that will actually act on that incorrect data to modify your rip.
    As you can see from the confidence figures , you are not the first person to rip the SACD CD layer using the database entry from the standard CD.
    Incidentally , I have that same SACD , and I get the same CRC's as you , I always "test and copy" , so I have the same CRC's twice.
  14. JUST ROCK
    JUST ROCK Member
    Jun 29, 2006
    279
    +14
    Thanks for your replies. It is very true that there is so many versions of cds nowadays especially with all these remasters coming out. Hopefully my ripped cds are ok, they have "All tracks accurately ripped" in the logfile.
  15. martin 39
    martin 39 Member
    Aug 20, 2009
    406
    +17
    hi all have started to rip my music collection but seeing as i know nothing about this i need some help please . need to no should i rip to 24 or 16 bit and on the hrz should i use 48000 41000 96000 or just leave it on auto . i have tried this and on 48000 it gives me a kbps at 1300 and if auto its 896 but this means nothing to me any help please thanks guys
  16. larkone
    Apr 21, 2006
    2,456
    83
    +360
    There is no point in ripping a CD higher than 16/44 FLAC as it will not give any better sound. Ripping in this format will give sound quality equal to the original CD.
  17. martin 39
    martin 39 Member
    Aug 20, 2009
    406
    +17
    Thanks just what I needed to know . Does it matter if some have been ripped higher or not
  18. therixonator
    therixonator Member
    Feb 18, 2011
    532
    +40
    It only matters for 2 reasons really, 1 is space as they'll take up more room. The other is whether your player can handle the format. For example Sonos can't play back 24bit codecs.
  19. therixonator
    therixonator Member
    Feb 18, 2011
    532
    +40
    Btw Martin, have read of the sticky in this section about ripping cds. It helped me no end. It's a big job that you really only want to do once.
    Also backup, backup, back up! My method is to rip to my pc, and use synctoy to copy to my Nas and an external harddrive. Then I keep the hdd at work and just bring it home when I have lots of new albums.
  20. martin 39
    martin 39 Member
    Aug 20, 2009
    406
    +17
    Thanks again I'm just getting into this as I never thought I would . Not long got a arcam avr400 . And find It better than my old roksan Caspian . So tried ripping a few cds and was amazed how good it sounded . So just looking for best ways to do this .would a r dac help the sound .
  21. therixonator
    therixonator Member
    Feb 18, 2011
    532
    +40
    I not heard the arcam so I can't really comment but the rdac is a very good dac for the money. I had one for a couple of years and it has served me well. Very simple to use, minimal controls and it made a massive difference to my system at the time.
    I have since upgraded to the audiolab mdac which I'm very happy with too. But it's a different sort of dac really. It needs configuring to get the best out of it, but you do get a lot more choice and features. Plus the support you get from the designer John Westlake is the best I've come across in any product I've ever bought. Audio or not.
    But it does cost twice as much as an rdac. Find a shop that sells your gear and test dacs for yourself. Or get a home demo if you can.
  22. JUST ROCK
    JUST ROCK Member
    Jun 29, 2006
    279
    +14
    Hi all, I ripped my cd and after rip it says (All tracks accurately ripped, No errors occurred)
    So I presume the rip is accurate but I was curious to know what all the (No match) at the end of Log file is all about, should I be concerned about that bit ?
    Please could someone explain this for me
    EAC extraction logfile from 1. December 2012, 20:30
    Led Zeppelin / Mothership - Disc 1 (Digitally Remastered)
    Read mode : Secure
    1 | 0:00.00 | 2:47.40 | 0 | 12564
    2 | 2:47.40 | 2:28.41 | 12565 | 23705
    3 | 5:16.06 | 6:28.07 | 23706 | 52812
    4 | 11:44.13 | 6:41.72 | 52813 | 82959
    5 | 18:26.10 | 5:32.71 | 82960 | 107930
    6 | 23:59.06 | 4:22.22 | 107931 | 127602
    7 | 28:21.28 | 4:15.42 | 127603 | 146769
    8 | 32:36.70 | 2:26.69 | 146770 | 157788
    9 | 35:03.64 | 7:23.72 | 157789 | 191085
    10 | 42:27.61 | 3:41.16 | 191086 | 207676
    11 | 46:09.02 | 4:54.69 | 207677 | 229795
    12 | 51:03.71 | 7:10.20 | 229796 | 262065
    13 | 58:14.16 | 8:02.23 | 262066 | 298238
    Track 1
    Filename G:\Wav Music Files\01 - Good Times Bad Times - Led Zeppelin - Mothership - Disc 1 (Digitally Remastered) - 2007.wav
    Peak level 99.8 %
    Extraction speed 0.7 X
    Copy CRC A956677D
    Accurately ripped (confidence 124) [98C163B5] (AR v2)
    Copy OK
    Track 2
    Filename G:\Wav Music Files\02 - Communication Breakdown - Led Zeppelin - Mothership - Disc 1 (Digitally Remastered) - 2007.wav
    Pre-gap length 0:00:00.42
    Peak level 99.8 %
    Copy CRC FE696ED9
    Accurately ripped (confidence 125) [A32CF662] (AR v2)
    Copy OK
    Track 3
    Filename G:\Wav Music Files\03 - Dazed And Confused - Led Zeppelin - Mothership - Disc 1 (Digitally Remastered) - 2007.wav
    Pre-gap length 0:00:00.64
    Peak level 99.8 %
    Copy CRC FAC6E3F9
    Accurately ripped (confidence 125) [4E47AD60] (AR v2)
    Copy OK
    Track 4
    Filename G:\Wav Music Files\04 - Babe I'm Gonna Leave You - Led Zeppelin - Mothership - Disc 1 (Digitally Remastered) - 2007.wav
    Pre-gap length 0:00:01.49
    Peak level 99.7 %
    Copy CRC 270250CB
    Accurately ripped (confidence 126) [B373A586] (AR v2)
    Copy OK
    Track 5
    Filename G:\Wav Music Files\05 - Whole Lotta Love - Led Zeppelin - Mothership - Disc 1 (Digitally Remastered) - 2007.wav
    Peak level 99.8 %
    Copy CRC BAA0A14E
    Accurately ripped (confidence 125) [A220A370] (AR v2)
    Copy OK
    Track 6
    Filename G:\Wav Music Files\06 - Ramble On - Led Zeppelin - Mothership - Disc 1 (Digitally Remastered) - 2007.wav
    Pre-gap length 0:00:00.38
    Peak level 99.8 %
    Copy CRC CA1491F8
    Accurately ripped (confidence 126) [52E14B80] (AR v2)
    Copy OK
    Track 7
    Filename G:\Wav Music Files\07 - Heartbreaker - Led Zeppelin - Mothership - Disc 1 (Digitally Remastered) - 2007.wav
    Pre-gap length 0:00:00.40
    Peak level 99.8 %
    Copy CRC 42BEDFC3
    Accurately ripped (confidence 125) [B9823480] (AR v2)
    Copy OK
    Track 8
    Filename G:\Wav Music Files\08 - Immigrant Song - Led Zeppelin - Mothership - Disc 1 (Digitally Remastered) - 2007.wav
    Pre-gap length 0:00:00.78
    Peak level 99.8 %
    Copy CRC B4111571
    Accurately ripped (confidence 123) [87A53562] (AR v2)
    Copy OK
    Track 9
    Filename G:\Wav Music Files\09 - Since I've Been Loving You - Led Zeppelin - Mothership - Disc 1 (Digitally Remastered) - 2007.wav
    Pre-gap length 0:00:00.92
    Peak level 99.8 %
    Copy CRC 0D5423F4
    Accurately ripped (confidence 121) [21F549E5] (AR v2)
    Copy OK
    Track 10
    Filename G:\Wav Music Files\10 - Rock And Roll - Led Zeppelin - Mothership - Disc 1 (Digitally Remastered) - 2007.wav
    Peak level 99.8 %
    Copy CRC BE48F391
    Accurately ripped (confidence 122) [33A019BB] (AR v2)
    Copy OK
    Track 11
    Filename G:\Wav Music Files\11 - Black Dog - Led Zeppelin - Mothership - Disc 1 (Digitally Remastered) - 2007.wav
    Pre-gap length 0:00:00.62
    Peak level 99.8 %
    Copy CRC D1AAC5DE
    Accurately ripped (confidence 124) [4458F467] (AR v2)
    Copy OK
    Track 12
    Filename G:\Wav Music Files\12 - When The Levee Breaks - Led Zeppelin - Mothership - Disc 1 (Digitally Remastered) - 2007.wav
    Pre-gap length 0:00:00.56
    Peak level 99.8 %
    Copy CRC 095326AA
    Accurately ripped (confidence 122) [08B27F7A] (AR v2)
    Copy OK
    Track 13
    Filename G:\Wav Music Files\13 - Stairway To Heaven - Led Zeppelin - Mothership - Disc 1 (Digitally Remastered) - 2007.wav
    Pre-gap length 0:00:02.20
    Peak level 99.8 %
    Extraction speed 1.7 X
    Copy CRC 4E8E5A2A
    Accurately ripped (confidence 121) [897653C7] (AR v2)
    Copy OK
    No errors occurred
    [CTDB TOCID: w9F4JBPZfXBSA5hZ_nMvzIZxoCQ-] found, Submit result: already submitted
    [90f0f5af] (694/722) Accurately ripped
    [d08fe270] (001/722) No match
    [26657d67] (001/722) No match
    [a503e30e] (001/722) No match
    [30c472ab] (001/722) No match
    [068174cd] (001/722) No match
    [70f42bf2] (001/722) No match
    [07ff8ef4] (001/722) No match
    [3f00c71e] (001/722) No match
    [5da60adf] (001/722) No match
    [92b9df11] (001/722) No match
    [291aadc3] (001/722) No match
    [080659eb] (001/722) No match
    [6a9b0193] (001/722) No match
    [d1b9118a] (001/722) No match
    [a6787e5b] (001/722) No match
    [59eca8fe] (001/722) No match
    [e39bb263] (001/722) No match
    [ba848fda] (001/722) No match
    [883a4c6a] (001/722) No match
    [db8bcadb] (001/722) No match
    [d0ec1b0e] (001/722) No match
    [9cff4afa] (001/722) No match
    [d08e40cc] (001/722) No match
    [836055c5] (001/722) No match
    [7597d011] (001/722) No match
    [4431b30c] (001/722) No match
    [464a88a2] (001/722) No match
    [dc7fb8a6] (001/722) No match
  23. JUST ROCK
    JUST ROCK Member
    Jun 29, 2006
    279
    +14
    Read mode : Secure
    Track 1
    Peak level 99.8 %
    Copy CRC A956677D
    Copy OK
    Track 2
    Peak level 99.8 %
    Copy CRC FE696ED9
    Copy OK
    Track 3
    Peak level 99.8 %
    Copy CRC FAC6E3F9
    Copy OK
    Track 4
    Peak level 99.7 %
    Copy CRC 270250CB
    Copy OK
    Track 5
    Peak level 99.8 %
    Copy CRC BAA0A14E
    Copy OK
    Track 6
    Peak level 99.8 %
    Copy CRC CA1491F8
    Copy OK
    Track 7
    Peak level 99.8 %
    Copy CRC 42BEDFC3
    Copy OK
    Track 8
    Peak level 99.8 %
    Copy CRC B4111571
    Copy OK
    Track 9
    Peak level 99.8 %
    Copy CRC 0D5423F4
    Copy OK
    Track 10
    Peak level 99.8 %
    Copy CRC BE48F391
    Copy OK
    Track 11
    Peak level 99.8 %
    Copy CRC D1AAC5DE
    Copy OK
    Track 12
    Peak level 99.8 %
    Copy CRC 095326AA
    Copy OK
    Track 13
    Peak level 99.8 %
    Copy CRC 4E8E5A2A
    Copy OK
    No errors occurred
  24. larkone
    Apr 21, 2006
    2,456
    83
    +360
  25. JUST ROCK
    JUST ROCK Member
    Jun 29, 2006
    279
    +14
    So I presume my ripped cd is ok then, with the No match on log file ?
  26. badsoden
    badsoden Member
    Jan 26, 2007
    511
    +17
    Apart from batch converting and multi core processing is there any other reason why I would want to purchase dBpoweramp over using the free EAC? I'm willing to make the investment if there is a reason to, like rip quality or something.
  27. amcluesent
    amcluesent Moderator
    Aug 13, 2002
    4,621
    +816
    AFAIK, EAC has always been the benchmark for rip quality. If you've mastered EAC, I can't see any reason to change.
    • Thanks Thanks x 1
  28. badsoden
    badsoden Member
    Jan 26, 2007
    511
    +17
    That's good to hear, I'm already 100 or so CD's into ripping a collection and just wanted to check I was using the right software! I've used the guides mentioned to set up EAC and I'm happy with the process I just wanted to check that I wasn't missing anything available in a paid for application. I'm also in no hurry so I'm ripping them as and when I have time so I'm not too bothered about speeding the process up which is what dBpoweramp seems to offer over EAC.
  29. JUST ROCK
    JUST ROCK Member
    Jun 29, 2006
    279
    +14
    I think that the slower ripping that EAC does is better because you get better results rather than a high speed rip from dbpoweramp.
  30. badsoden
    badsoden Member
    Jan 26, 2007
    511
    +17
    After thinking I had mastered EAC I've found a problem with some mix CD's showing as having gaps when they shouldn't. I've tried the different gap detection options but get the same results.
