Difference between cables - CAT6 & HDMI
Discussion in 'CAT5 Cabling' started by sunil1234, Dec 19, 2009.
  1. sunil1234
    sunil1234 Member
    Dec 5, 2004
    1,266
    48
    +98
    Hi there
    About to run some cat6 15m in our pending garage conversion in ceiling void.
    Wondered what the difference was between these two please?
    Belkin Cat6 Snagless UTP Patch Cable 15m: Amazon.co.uk: Electronics & Photo
    and
    Belkin Cat6 Snagless Patch Cable - 4Pair, RJ45M: Amazon.co.uk: Electronics & Photo
    Also are these hdmi leads too cheap to be good for v1.4 and a 10m run from source to projector (HD200x)
    10m HDMI v1.4 Cable with Ethernet ~ Professional: Amazon.co.uk: Electronics & Photo
    Many thanks for any advice. Just need to get input from the wise ones here and then i can buy them
  2. richard_ha
    richard_ha Member
    Aug 5, 2009
    246
    +23
    UTP stands for Unshielded twisted pair.
    Over such short distance you are unlikely to be able to tell the difference so go for the cheaper one!
    • Thanks Thanks x 1
  3. sunil1234
    sunil1234 Member
    Dec 5, 2004
    1,266
    48
    +98
    thanks, from what i can see they are both UTP but not sure why amazon has two products at diff prices as belkin website only has one 15m cat6 blue cable
    Anyone got any comments on the hdmi cables pls?
  4. Member 426448
    Member 426448 Member
    Nov 30, 2009
    37
    +11
    Seems very cheap, especially for a V1.4 cable. The conductors don't look that well shielded (looks thin) and the connector looks similar to the type we have on our Value range of cables which I wouldn't recommend for anything over a few metres.
    As with all things I would suggest buying it and testing before it is installed.
    Is your projector a V1.4 device?
    If not I would suggest a good quality V1.3 cable such as
    10m HDMI Cable
    As these have been tested up to 15m.
    If you do buy it and it is OK please let us know.
    • Thanks Thanks x 1
  5. sunil1234
    sunil1234 Member
    Dec 5, 2004
    1,266
    48
    +98
    Many thanks, i think i will look at other options inc yours as i dont want to get an issue once they are put above the ceiling!. They might be fine at first but if issues arise after a while. DOnt have anything that supports/needs 1.4 and plan to run 2 x cat6 utp with the 2 x hdmi anyhow up to the projector. Should i be running a pc lead as well?
    thanks
    Ho hum....
  6. Member 426448
    Nov 30, 2009
    37
    +11
    If you mean up to the projector, its up to you, bear in mind that most modern PC graphics cards have a hdmi output so you should be OK.
    On the other hand, the general rule of thumb appears to be to run twice as many cables as you think you are going to need in the future as the added expense now is nothing compared to the pain of ripping down walls / celings.
    • Thanks Thanks x 1
  7. Joe Fernand
    Joe Fernand Active Member Assured Advertiser
    Jan 20, 2002
    18,530
    +1,824
    No such thing as a v1.4 HDMI cable - or v1.2, 1.3 for that matter.
    HDMI.org are very clear about folk not labeling or marketing cables in this way - http://www.hdmi.org/manufacturer/trademark_logo_pub.aspx
    Cables are either High Speed, High Speed with Ethernet, Standard Speed or Standard Speed with Internet - High Speed cables having being tested with a 1080p signal whereas Standard Speed cables are tested at 1080i/720p.
    A High Speed cable will support all features found in the 1.4 'hardware' specification - the only choice being will you eventually need Ethernet support or not!
    At this time there is nigh on nothing available to the Consumer market that supports 'with Ethernet' nor most of anything else 1.4 has on offer.
    Any cable thats being sold/labeled as v1.4 compliant is (at this time) unlikely to have actually gone through any form of official HDMI certification!
    The Belkin CAT6 cable is likely to be fine for your requirement.
    Joe
    • Thanks Thanks x 1
  8. Member 426448
    Nov 30, 2009
    37
    +11
    Hey Joe,
    I thought I read somewhere that the 2 previously unused pins in a cable are used to carry the ethernet stuff and that it was fairly important that they are a twisted pair which is not true in some cables (as they are unused they may even be omitted in some cheaper cables).
    I could be wrong though, I'll try and remember where I read it........
    I agree that nothing seems to support the extra V1.4 stuff yet. Not convinced we will see anything anytime soon or if we will see a benefit when we do.
    • Thanks Thanks x 1
  9. Member 426448
    Nov 30, 2009
    37
    +11
    Found it:
    HDMI 1.4 Includes Ethernet, 2-Way Audio - Tom's Guide
    Guess your right about the High Speed and Standard Speed cables with and without Ethernet.
    Hope it catches on soon, should finally help clear up the what cable will work with what arguments and discussions that are going on.
    • Thanks Thanks x 1
  10. sunil1234
    sunil1234 Member
    Dec 5, 2004
    1,266
    48
    +98
    thanks all
    just had a proper measure up now the floor has been constructed and the room will be 4.4m long max with 2.4m ceiling height so i can even opt for slightly shorter than 10m cables.
    I saw another site with belkin cat 6 shielded in 10m, is this a better option for potential hdmi use given there is only about £2 in it?
    5th one on link below
    Homestead - Belkin Shielded Snagless 500Mhz Cat6 Network Cables
    thanks
  11. Joe Fernand
    Jan 20, 2002
    18,530
    +1,824
    Hello
    UTP CAT6 is fine for use with all HDMI Extenders I've had a look at.
    Keep in mind that whilst most Extenders are wired as per a 'standard' CAT5/6 cable (TIA-468B or TIA-468A) some use a straight through wiring config!
    At 10m you would require an Amplified HDMI cable if you want High Speed (CAT2) Certification - Media Factory - Bettercables HIgh Speed CAT2 HDMI cables, 1m to 12m.
    If you go with dual CAT6 plus a set of Extenders you are arguably more future proofed in that the Extenders could be swapped out in the future if anything current lets you down at a future date.
    Media Factory - Octava HDOCAT, HDMI + Optical 5.1 over CAT5 Extender inc. IR Passthru
    I'd be tempted to consider a High Speed HDMI cable plus two length of CAT6 and use the HDMI cable for now and have the CAT6 cable in place as a back up - where possible ensure you can pull through a replacement cable should anything ever be damaged.
    Joe
    • Thanks Thanks x 1
