Denon 1906 how to reset to factory settings?
Discussion in 'Integrated Amplifiers & Receivers' started by sambd, Aug 17, 2008.
  1. sambd
    sambd Member
    May 22, 2008
    308
    +13
    Hi all i have just brought a denon 1906 for £80 and i'm happy with the looks but i would really like to hear my movies and music off my pc via an optical cable.
    The first thing i need to do is reset the setting. I'm looking through the manual and i cannot see any reference to a factory reset, i want it reset because the previous own had a named PS3 setting and i don't have a ps3.
    Then i will need to figure out how which setting i need for an optical out :rotfl:
  2. sambd
    sambd Member
    May 22, 2008
    308
    +13
    ok found out how to get the sound working now just by luck lols
    Now i just need to reset it :smashin:
  3. Shared
    Shared Member
    Jul 22, 2006
    1,228
    63
    +249
    1/ Switch off the unit using Main power switch
    2/ Keep both Speaker A and Speaker B buttons depressed and turn on unit using Main power switch
    3/ Check that the entire display is flashing at 1 Second intervals, when it is release the buttons. :)
    • Thanks Thanks x 1
  4. sambd
    sambd Member
    May 22, 2008
    308
    +13
    Thanks a lot it did the trick :smashin:
  5. sambd
    sambd Member
    May 22, 2008
    308
    +13
    Hi all got another question :D
    Just used the auto setup with the mic and everything in movie terms is good with DTS. But when i switch to just lessening to music in 5ch stereo it sounds very flat and muffled. When i turn my main L and R speakers off the music sounds even worse like it's playing a very low bit rate:confused: does anyone have any good advice?
    BTW when i lessen to music in just stereo with the 5ch enabled it sounds very very good :D
