I bought two damaged players on eBay and I'm trying to fix them (display is showing "LOAD").
I expected that main PCB should be BD-P1620, however there is a BD-P3600 (on NAND is label BD-P1620A and no SATA port installed).
Is this OK or I bought fake hardware.
Which firmware version I should use - for DB-P3600 or DB-P1620 or DB-P1620A ?
************ Edit: several hours later ***********
I connected serial console, boot loader is running, but I don't have any idea how to extract firmware from RUF file and run it ?
Code:
BCM74430010
Setting NAND Params
CFE starting from ROM
SoooooooooooooR
Starting code in RAM
Before:
Secure Boot is enabled.
Public Key Index = 0.
Market ID = 0.
Epoch = 0.
Programming OTP bits.
Pub key index is programmed
Market ID is programmed
Epoch is programmed
Enable bit is programmed
After:
Market ID = 0.
Epoch = 0.
Booting Secured CFE...
BCM97601 B0-BSEC CFE v2.1.12 (CFE core v2.1, BSP_REV 12), Endian Mode: Little
Build Date: Tue May 19 14:46:23 KST 2009 ([email protected])
Copyright (C) Broadcom Corporation.
DDR : Bank0:128MB@400MHz | Bank1:256MB@400MHz
NAND Boot : FlashSize 64MB on CS0, BlkSize 16KB, PgSize 512B
NAND vendor timing : 20762076 ST NAND512W3A SLC t1(32622226) t2(676)
Macrovision is enabled
Display splash screen
Using valid user input parameters - Resolution 480p on Component
[ Default Video ] : Current Video Output : Component @ Resolution : 480p
Loading NTSC SD image only to 0x027f4800 size 691200 bytes
Reading flash0.splash to V:0xa27f4800 from offset 0 len 691200
Copying NTSC SD image to 0x02400000 size 691200 bytes
Done displaying splash screen
Reading flash0.splash to V:0xa2fadc00 from offset 691200 len 44
Wav audio not found
Trying to load audio splash from offset: 0xa8c00, result: -1
Loader:elf Filesys:raw Dev:flash0.kernel File: Options:root=/dev/romblock2 conso le=0,115200n8 BDVD_BOOT_AUTOSTART=y BAPP_OUT=/dev/console ro
Loading: 0x80008000/4440608 0x80444220/289920
Not a secure elf image, cannot load/boot !!!!
Entry address is 0x00000000
CFE> ?
Invalid command: "?"
Available commands: info, splashsd, splash, loop, dir, macprog, macprog2, flashmarkbb, flasherase, flasheeprom, flash, memtest, f, e, d, u, reboot, batch, go, load, save, boot, ping, ifconfig, sleep, show, unsetenv, printenv, setenv, help
*** command status = -1
CFE>
