Damaged B&W Tweeter
Discussion in 'Speakers' started by Westfield, Mar 1, 2007.
  1. Westfield
    Westfield Member
    Dec 20, 2004
    60
    I got home last night to find that one of my childrens friends had stuck their grubby little finger into the tweeter of my B&W CM Center speaker.:eek: Considering that I have only had it for a couple of weeks I remained remarkably calm!
    Phoned B&W this morning and spoke to a chap in their tech services dept. He was very helpful and took an order for a replacement tweeter (considerably cheeper than I expected) which should arrive 3 - 5 days. :clap: I'll have a look and if fitting the replacement looks tricky I'll go to my dealer to have it done.
    When I first bought the speaker. B&W had a backlog and couldn't supply it for 2 weeks, they kindly lent me one of their demo speakers. I have to say that my experience so far with B&W customer services has been excellent. I just through that this was worth mentioning as very often when when we suggest/recommend speakers, this factor is not often mentioned - although one does not expect to have to order replacement compenents that often!
    Does anyone else have similar good experiences from other manufacturers?
  2. GW43
    GW43 Member
    Feb 27, 2005
    1,453
    63
    +140
    A tweeter that's also a cheeper!:D
  3. GW43
    GW43 Member
    Feb 27, 2005
    1,453
    63
    +140
    On a more serious note, I had a good experience with Tannoy on a similar matter (replacement driver) a few years ago.
  4. Mr Forgetful
    Mr Forgetful Member
    Jun 7, 2004
    377
    +15
    My ex-girlfriend somehow misplaced the metal connects for my CM4's, phoned B & W and they sent out a new pair free of charge, I was expecting a bill for them so was very pleased with their service.
  5. mjw1999
    mjw1999 Member
    May 23, 2005
    588
    +16
    I had a damaged midrange driver in my 604's and had no idea how it happened. As a goodwill gesture, B&W sent a new driver to my dealer who replaced it, all free of charge.
    Because of this good service i never had any hesitation about upgrading to 800 series B&W's
  6. thatalextaylor
    thatalextaylor Guest
    One of the saddest hi-fi moments I've had recently was seeing a brand new B&W CM7 with a mashed-up tweeter in a shop. Please people, keep your fingers to yourself. Think of the tweeters ;-)
  7. morksbeanbag
    morksbeanbag Member
    Jul 25, 2004
    723
    +48
    I've had only good experience with B&W too. When i've needed port bungs or those little rubber parts that hold the grillies in place i've always found B&W sent them out free of charge. Nice surprise.
    Their tweeter diaphragm's were also reasonably priced at £20.
  8. Arcam_boy
    Arcam_boy Moderator
    Jun 13, 2006
    8,362
    +896
    don't wanna sound like a broken record but when I phoned b&w they where excellent and really helpful and there replacement parts are much cheaper than I expected!
    One of the reasons I felt happy to buy a pair of 805s and soon hopefully a set of 802s :D
  9. sjj84
    sjj84 Member
    Aug 7, 2006
    279
    28
    +26
    I emailed B&W on Sunday night regarding the forthcoming series 4 range and received a reply first thing on Monday morning, think I'll definately spend the extra cash and get something with decent service.
  10. joffy1780
    joffy1780 Member
    Dec 19, 2004
    1,371
    +82
    Tell us more,please.
  11. sjj84
    sjj84 Member
    Aug 7, 2006
    279
    28
    +26
    Not much to tell really, the series 4 speakers are expected to be released in the Autumn, don't know any other details I'm afraid.
    • Thanks Thanks x 1
  12. fertonani
    fertonani Guest
    Does anyone know the cost of a replacement tweeter for a CM&?
  13. MarkB
    MarkB Member
    Oct 29, 2000
    737
    +27
    I think you typed in a capital 7 there!
    Best thing to do mate is to email B&W directly and ask. uksales@bwgroup.com
  14. wickfut
    wickfut Member
    Mar 13, 2006
    296
    +21
    not 100% sure if this will work on your speakers but Ive fixed damaged speakers this way..
    remove the tweeter and then remove the fixing screws that hold the actual dome and coil from the magent (the small ones on the front near the actual cone)
    if you gently remove the magnet you can push the metal dome out from the inside.. be carefull, if you bend the coil you will wreck it totally.
    put it back together and bingo , you wont even know its been crushed.
  15. Fingerz6
    Fingerz6 Member
    Mar 19, 2010
    17
    3
    Just thought i would put my bit in, Watched my brother unpacked his b&w centre and put it on the shelf only to watch his son march straight up and push in the tweeter with his finger, My brother went a bright shade of red and then walked over and calmly suck the dent out, It did leave a little mark but it did work.
  16. kfalls
    kfalls Member
    Aug 22, 2006
    137
    +13
    I've had good results with B&W as well. I've purchased two pairs of LM1 Leisure Monitors. They have an integral base which can be used to hang the speaker from the ceiling or wall, or used as a base on it on a bookshelf or stand. To hold the base in position is a shaft with a ball at one end and a tightening bolt at the other. One speaker in each pair had the bolt snapped off requiring replacement. I was fortunate that the prices per mount was only 11/ea shipped.
    The hard part was the installation. It required you to remove two M6 bolts from the outside of the base. Ten remove the four bolts holding the speaker baffle to the rear portion of the cabinet. Once inside the speaker, four screws need removed from the xover so it can be moved to one side to remove the last two bolts holding the mounting base from the inside.
    The new shaft is installed and the process is reversed. It takes a little over an hour to replace one shaft. The disturbing part is the snapped shafts are very common. Even though I specifically asked the seller if one or both were damaged, I was told no and that the damage must have happened during shipping. The last seller actually paid for the repair. I believe he thought it would cost much more to replace, so he sold them. Once I told him the cost, he was happy to pay the cost.
    Good company, products and support. B&W has always been a class act.
  17. bluedroog
    bluedroog Active Member
    Nov 16, 2009
    2,209
    +409
    B&W's customer service is first rate. They make it so easy, I blew my mid / bass unit after a bit of a party. Rang B&W spares & repairs up with card details and the unit arrived a few days later really well packaged.
  18. Stick
    Stick Member
    Sep 10, 2011
    Good Afternoon Everyone,
    Does anyone know where, who, or can point me in the right direction for some replacement tweeters for an older pair of 803 Series 2 speakers? I would greatly appreciate any help I can get!
  19. Storry
    Storry Member
    Aug 16, 2009
    53
    9
    Was it expensive to replace the tweeter mate? I accidentally knocked my tweeter in when moving my CM8 the other day! :-(
