DAB to Sky Dish
Discussion in 'DAB Digital Radio & FM Radio' started by JEDIBLADE, Jun 2, 2006.
  1. JEDIBLADE
    JEDIBLADE Member
    Sep 24, 2002
    890
    +32
    If I connect my DAB radio to my Sky LNB will it act as an aerial and get me good reception?
  2. Nick_UK
    Nick_UK New Member
    Nov 13, 2004
    9,748
    +315
    In a word, NO.
  3. Chris Muriel
    Chris Muriel Active Member
    Jun 14, 2002
    6,864
    +703
    The mind boggles !
    Chris Muriel, Manchester
  4. JEDIBLADE
    JEDIBLADE Member
    Sep 24, 2002
    890
    +32
    Thanks for that. If you don't ask you don't know. I don't think there's any need for derogatory comments though ! Haven't you anything better to do like train spotting ?
  5. Chris Muriel
    Jun 14, 2002
    6,864
    +703
    It wasn't actaully meant to be derogatory- apologies for any offence.
    Besides the fact satellite TV looks at frequencies in the 10.7-12.75 GHz area whereas DAB is VHF around 180-220 MHz (with an LNB output in L-band 950-2150 MHz) there is the point that the LNB needs 14/18 volts DC to power it;
    your DAB aerial socket will not be designed to supply a DC voltage.
    I cannot think of many less compatible situations.
    However, I have quite often seen people ask if they can connect their cable TV STBs to a dish - where similar incompatibilities exist.
    (without mentioning the different modulation systems used by all 3).
    What will work is an old Band III TV aerial (from the days when ITV channels were VHF) if you can find one.
