Core 360 to HD display cable?
Discussion in 'Xbox 360 Hardware' started by lonecub, Feb 24, 2012.
  1. lonecub
    lonecub Member
    Feb 10, 2007
    119
    16
    Hi, could anyone tell me which cable to buy to link up my first generation core 360 to my hd display?
    Muchas gracias
  2. Sooby
    Sooby Member
    Apr 21, 2008
    190
    +6
    xbox 360 component cable - 1080i only on some screens but excellent nonetheless
  3. gamingboy
    gamingboy Member
    May 23, 2006
    1,621
    63
    +230
    Or the VGA cable depending on TV and it's native resolution.
  4. lonecub
    lonecub Member
    Feb 10, 2007
    119
    16
    Hi again
    My display only has a hd and hdmi input sockets?
    Not sure any of those cables are sufficient
  5. DJSigma
    DJSigma New Member
    Apr 23, 2008
    6,729
    +1,910
    What does the "HD" socket look like? What is the make and model of the TV?
  6. lonecub
    lonecub Member
    Feb 10, 2007
    119
    16
    it's just a standard hd socket. it'c ompatible with my ps3
    the big problem is the core 360, as it wasn't hd enabled. could i buy a cable that links the picture and sound from the 360 to an hdmi port on the display
    it's a philips display, bought a year ago
  7. DJSigma
    DJSigma New Member
    Apr 23, 2008
    6,729
    +1,910
    I don't know what you mean by "HD socket" though, as you said it has "a HD and HDMI input sockets". Or did you just mean that all it has is HDMI?
    The only signals that a non-HDMI 360 can put out are analogue and HDMI is digital, so unfortunately it's not as simple as buying a cable. You can buy a product like this: -
    http://www.amazon.co.uk/Neet®-Component-Converter-Supports-Lifetime/dp/B002C7CCJ6
    That would accept a component input from your 360 and output it via a HDMI cable to your TV, but it's kinda pricey and doesn't include the component and HDMI cables that you would need. I'm not recommending that specific product BTW as I've never used it - it's just an example.
    But are you 100% sure that your TV doesn't have other inputs capable of carrying a HD signal? No component? No VGA?
  8. Indiana Jones
    Indiana Jones Moderator
    Nov 4, 2003
    23,556
    +2,335
    The PS3 cable, would it happen to be yellow, red and white because that isn't an HD connection but composite and the worst possible connection you can use.
    Are you sure it doesn't have component inputs (red/green/blue)?
    If not and HDMI is your only choice then I'm afraid you will need to get a new 360 with HDMI output.
  9. lonecub
    lonecub Member
    Feb 10, 2007
    119
    16
    hey folks
    thankyou for the response. sorry, i forgot i posted this
    there is a dvi socket on the display
  10. Indiana Jones
    Nov 4, 2003
    23,556
    +2,335
    If it has a DVI socket then you might be able to use the 360 VGA cable and then use a VGA -> DVI adapter, all depends on whether the socket is digital only or if it can handle analogue as well.
