connecting TV - HIFI
Discussion in 'LCD & LED LCD TVs' started by GSi, Mar 3, 2012.
  1. GSi
    GSi Member
    Aug 9, 2009
    139
    Pretty straightforward on my old tv
    had a 32" sony bravia S series Connected to my sony hifi ( HCD-XG500 )
    VIA av leads and worked.
    I decided to hook to the hifi up to my LG 32LW450U via same means as i did with the Bravia and i cannot figure out why it wont work iv tried every option hifi and what sound options there are on the tv to no avail
    im hoping some one may have the solution on here
    thanks
  2. GSi
    GSi Member
    Aug 9, 2009
    139
    When i had it connected to bravia i used the white and red av wires in av socket connected to game av sockets on hifi
    and worked on HDMI channels, i was getting tv sound and hifi sound at sametime while playing ps3 etc
    on this lg tv i cannot work out why it wont work using the same method as before?
  3. logiciel
    logiciel Moderator
    Feb 2, 2008
    46,356
    +4,490
    Maybe it doesn't output at all.
  4. JayCee
    JayCee Active Member
    Jan 20, 2004
    15,752
    +1,576
    It doesn't work because your LG Tv does not have audio out RCA sockets
    The sockets you've used on your Tv are inputs not outputs.
    You'll need to use the headphone out (if it has one) using a 3.5mm stereo jack to 2 phonos lead.
    If it doesn't have a headphone out it probably has an optical out and you'd need an optical to analogue audio convertor which are available for around £30-£40.
  5. blankscreen
    blankscreen Member
    Jun 24, 2009
    327
    +16
    My LG don't have headphone socket, assume LG don't supply them.
    Can he get scart to phono adapter and use that for Tv outpt To his amp?
    Will Only be stereo depends on his budget.
  6. GSi
    GSi Member
    Aug 9, 2009
    139
    Cheers guys explains why it doesnt work
    best option would be a new sound system? My budget would be £200 max
    any good ones you could recommend for my needs thanks
  7. JayCee
    Jan 20, 2004
    15,752
    +1,576
    Some LG models have a headphone out, some don't.
    Some LG models output analogue, some output Freeview and some don't output anything.
    They're all different.
  8. JayCee
    Jan 20, 2004
    15,752
    +1,576
    Onkyo have some good models.
  9. logiciel
    logiciel Moderator
    Feb 2, 2008
    46,356
    +4,490
    If the Scart is not input only.
    Thet certainly do, but do we know that OP's TV has optical audio out to make use of one?
  10. blankscreen
    blankscreen Member
    Jun 24, 2009
    327
    +16
    Ti my mind, if the O/P has £200.00, he only need spend £40 ish for an optical to analogue converter off EBay.
    Never used one from there so no idea how good. I used a creative labs multi-converter with very good results from my Toshiba LED
    Most expensive choice to be made, update speakers but will they be any good?
    Cheaper is buy converter - but same issue.
  11. flippence
    flippence Member
    Dec 14, 2009
    308
    28
    +39
    Try and future proof to some degree. Something like Denon 1312. Has 3D throughput and HDMI 1.4 ARC ( not required now)
    and Optical and Coaxial Input. Available £199.
