Connecting A Surround System
Discussion in 'Freeview' started by Matthew Bpstock, Oct 11, 2009.
  1. Matthew Bpstock
    Matthew Bpstock Guest
    I have a Logik Freeview Television, and I want to connect it to a Surround sound system. The Television does not seem to have an audio output, or a headphone socket.
    How do I go about connecting the surround sound system.
    It does have these ports:
    RF In
    Audio L/R in
    Component
    Pc Audio
    Scart
    VGA (PC)
    HDMI
    I would like to avoid using an external freeview reciever.
    Matthew
  2. 24 P
    24 P Member
    Mar 29, 2009
    2,642
    +276
    Wont work, you need some kind of Audio out, albeit anaolog or digital, which your panel does not provide.
    Next option is to use the box you don't want to..
    :thumbsup:
  3. grahamlthompson
    grahamlthompson Well-Known Member
    Aug 3, 2006
    18,369
    163
    +3,067
    The scart socket carries stereo audio out you just need to break out the audio out connections.
  4. MarkE19
    MarkE19 Moderator
    Aug 10, 2002
    15,572
    +2,025
    Check the manual of the TV to make sure that at least one of the scart sockets does output a signal. If it does then you can get a scart adapter such as This unless you have an external device connected to the scart socket, in which case you will need something like This.
    Mark.
