Connecting a ethernet cable to my Panasonic Plasma TXP42V10B
Discussion in 'Plasma TVs' started by Melwyn, Sep 7, 2009.
  1. Melwyn
    Melwyn Member
    Aug 20, 2009
    11
    I have just got a panasonic plasma TXP42V10B and I want to try the Viera Cast feature by connecting the Ethernet cable to the TV.
    I have the wireless router upstairs in my study while my plasma tv is in the sitting room. The sitting room has a spare Telephone point.
    I have connected one end of the Ethernet cable to my plasma screen.
    Where should I connect the other end of the Ethernet cable ?
    1. To the wireless router in the study
    or
    2. Directly connect it the the telephone point in the hall ?
    Mel
  2. Daniel SL
    Daniel SL Member
    Mar 26, 2006
    +6
    the router upstairs in the study.
    you can get creative with wiring but since you are asking thats probably not going to happen :)
    perhaps a homeplug Ethernet over AC solution could save you running cat5 to the study.
    or you could use a wireless bridge.
    have i helped? probably not. sorry about that.
  3. paulr2006
    paulr2006 Active Member
    Jun 30, 2007
    7,607
    +1,593
    Or use a wireless gaming adapter which you can pick up for around £14 from Amazon. :)
  4. choddo2006
    choddo2006 Active Member
    Dec 30, 2005
    8,526
    +610
    I'd go for Ethernet over Power (in fact, I need to do this for something in my house - timely reminder) - should be better than wifi
  5. killabyte
    killabyte Member
    Jun 28, 2007
    408
    +4
    can u connect the V10 via a wirless connection? dont know u could
  6. charles_b
    charles_b Member
    Apr 28, 2006
    597
    +89
    Yes you can. you buy a wireless bridge, which to all intents and purposes is an ethernet wired connection to a device, but talks wirelessly to the router. I used one of these successfully for 3 years unti I discovered homeplugs, which are far more reliable than wireless.
  7. Melwyn
    Melwyn Member
    Aug 20, 2009
    11
    Sorry being a novice I don't know anything obout the following technical jargons from the replies I have been receiving.
    What are these and how do they work
    1. Wireless Bridge
    2. Homeplugs
    3. Ethernet over power
    4. Wireless gaming adapter
    5. homeplug Ethernet over AC solution
    Will any of these work to access the Viera Cast on my panasonic Panasonic Plasma TXP42V10B TV ?
  8. rewerb
    rewerb Active Member
    Feb 29, 2008
    4,447
    +661
    Connect to the wireless router.
  9. killabyte
    killabyte Member
    Jun 28, 2007
    408
    +4
    so the V10 has built-in wifi?:confused:
  10. rewerb
    Feb 29, 2008
    4,447
    +661
    No, he wanted to know where to connect his ethernet cable to : the router or the telephone socket.
  11. choddo2006
    Dec 30, 2005
    8,526
    +610
    Not directly. People were suggesting trying a wireless bridge.
  12. charles_b
    charles_b Member
    Apr 28, 2006
    597
    +89
    This is a piece of Kit that looks like a Router or Wireless Access point, with an aerial, but has an Ethernet port on the back. You plug the Ethernet cable from the Bridge to your V10 ethernet socket. The Bridge then Connects Wirelessly to your Router. Belkin certainly do one (I have one), but I think it's USB Powered. Others may call them Gaming Adaptors
    Homeplugs are similar to Wireless Bridges, but utilise your Electricity wires in the house to create the connection to the Router. You need a pair of these (Solwise have these for around £40/50 a pair, but there are deals on at various places, including Amazon).
    1 plugs in next to your router and you connect an ethernet cable to it and your router. The Other plugs in next to your TV and ethernet cable plugs into it and your V10.
    The best thing about Homeplug is that is is truly Plug and Play - no need to configure anything.
    I presume you actually mean Power over Ethernet - this is a way of powering remote Network devices without an external power supply. This is not a requirement for your issue
    See Point 1
    See point 2
    YES, Either option 1 or option 2. I would recommend 2 having used both. Homeplug is a very easy to use system. There are various options, from 84Mb/s, 200Mb/S and even Gigabit. I would look at what you want to use. If you are looking to stream any High Definition Content, then go with 200 Mb/s (Sometimes called Homeplug AV).
    I truly hope this helps. I can recommend ADSL, ISDN, VoIP, Networking, Wireless, Advice....Solwise Ltd as a place to look at the different options available.
    Charles
  13. choddo2006
    Dec 30, 2005
    8,526
    +610
    Actually "ethernet over power" is a term I used - I meant the same as homeplugs/ethernet over mains
  14. charles_b
    charles_b Member
    Apr 28, 2006
    597
    +89
    Choddo, It is very confusing, Homeplug really isn't a good name for it. They should really call it Powerline Networking.
    Incidentally, Belkin just release their Gigabit Homeplug, Several places have it at around £120 for a pair, which is not bad price for the speed. Apparently compatible with the 200Mbit kit..... I might be investing as I wanted to move my NAS into my Garage and 84Mbit doesn't really cut it against my current hard-wire connection.
  15. Melwyn
    Melwyn Member
    Aug 20, 2009
    11
    Hi Charles,
    I am facinated by this Homeplug option.
    But I am a bit suspicious of using the electricity wires for ethernet connectivity.
    Is there any chance of contamination happening, like electricity current getting passed through the eternet cable connected to the TV. In this case won't it screw up the TV.
    Maybe my fears are without any justification and entirely unfounded.
    Mel
  16. choddo2006
    Dec 30, 2005
    8,526
    +610
    My NAS is the reason I'm looking at this - and you're right, anything less than gigabit is painful but I don't need to go as far as a garage so I think maybe a long ethernet cable will be more palatable to the bank manager :) I'd be interested in your findings on performance if you do go for the pricey option.
  17. choddo2006
    Dec 30, 2005
    8,526
    +610
    I think they probably thought of that when they designed them ;)
  18. charles_b
    charles_b Member
    Apr 28, 2006
    597
    +89
    Mel
    You shouldn't have any issue with Homeplug. I've been using it for 2-3 years with it constantly connected to my router and 3 separate PC's and not had any issue. It won't affect your TV at all.
    It utilises a signal passed through the copper wires at a separate frequency to the electricity itself. The plugs filter the signal and convert to ethernet. It's similar to how the ADSL signal works and why you have a filter in place to separate out low frequency (Telephone conversation) and high frequency (internet) for internet delivered over telephone lines.
    I'm more worried about the effect on my kids of all the wireless signals bouncing around in the radio spectrum.
    Charles
  19. charles_b
    charles_b Member
    Apr 28, 2006
    597
    +89
    Choddo, I have 100 metres of Cat5e and a £12 cable feeder from b&q, plus crimping tools etc.. bought when b&q were having a sell off of loads of networking kit about a year or 2 ago. I'm going to try that option before I resort to spending on gigabit powerline, although I think it might involve a considerable amount of sweat/swearing and bruised knuckles.
  20. charles_b
    charles_b Member
    Apr 28, 2006
    597
    +89
    Quick Update. I've got some issues with hard-wiring, so Powerline is back on the cards. I thought this link to a review of the Belkin Gigabit, including side-side comparison with the netgear XAV1004 kit (200mbps)
    http://www.smallnetbuilder.com/content/view/30888/51/
    One thing to note is that this is a US review, where they use 110V, they also have an issue with AFCI Circuit Breakers killing homeplug signals, but I'm pretty sure that these are an American/Canadian system for breaking circuits (Anyway, my current 85Mbps setup goes through 3 circuit breakers to my Garage and I get consistent 50-60mbps speed - according to the supplied software, not real world)
    Interesting that the Netgear outperformed it in some areas. I'm not known to be an early adopter of technology, so I might be waiting a while before relocation of my NAS
