Connected TV to PC but screen flickers. Any ideas?
Discussion in 'LCD & LED LCD TVs' started by iantib, Dec 21, 2006.
  1. iantib
    iantib Guest
    SONY KDL40W2000, connected to my pc by a bog standard VGA cable, but the image on the screen flickers around the icons & text.:thumbsdow
    Do you experts know if there is there anything I can do to fix it?
    Thanks & Merry Christmas.
  2. Robstar
    Robstar Member
    May 29, 2002
    37
    What refresh rate have you set your PC to? I don't know what rate it will support for each resolution, but the higher the better.
  3. JimBob1971
    JimBob1971 Member
    Jan 12, 2004
    1,348
    48
    +46
    Hi Ian,
    I have a Sony bit haven't tried VGA only HDMI via DVI. The picture is perfect. If your pc can do DVI I'd advise you to try this.
  4. iantib
    iantib Guest
    Its an old dell laptop. Dont even think hdmi was around when this was new :-(
    The refresh rate is 60hz (whatever that means), looking at the options it goes up to 85hz.
  5. chrise
    chrise Member
    Dec 13, 2002
    556
    28
    +57
    Lantib I have a w series and get the best results by using 1360 x 768 at 60 Hz and get a rock steady picture with the TV set at Full2. There are 2 adjustments in the TVs PC setup the first tries to automatically settle the picture if that does not work try altering the setting labelled phase.
