Configure Wake on Wireless LAN (WoWLAN)
Discussion in 'Computer Components' started by monkey121, Oct 29, 2010.
  1. monkey121
    monkey121 Member
    Feb 14, 2007
    58
    I am trying to set WoWLAN up but in the power management of the wifi card the allow this device to wake the computer is greyed out.
    I have a XFX nforce 630i 7100 motherboard
    PCI wifi card
    and I am running windows 7
    Any help you guys can give would be great
  2. djmakz
    djmakz Member
    Dec 5, 2010
    24
    3
    +3
    Try different divers for WLAN card and a motherboard. Check in BIOS, there may be a n option to enable power to PCI devices while off.
  3. TechnoMusic
    TechnoMusic Member
    Jun 15, 2010
    96
    +3
    it depends on your motherboard really,
    check if there is an option called wake on lan
    otherwise, enable power for PIC device, (some say PIC-E)
    and also, booting into windows, control panel, system, device manager
    network and adaptors
    right click, properties -> advanced -> shutdown wake up - enabled,
    -->wake up capabilities - magic packet
    ( some people found their computer restarting weirdly if not setting the magic packet)
  4. monkey121
    monkey121 Member
    Feb 14, 2007
    58
    TechnoMusic - those options are not available
    djmakz - i have changed the bois but still doesnt work.
    I have since got a usb wifi Wireless adapter, but i still have the same issue.
    I'm trying to configure my Win 7 machine to wake from sleep. My computer is connected through a Belkin N+ USB Wireless adapter.
    When I go to the adapter's power settings the Advanced tab doesn't have any of the WOL settings available and the Power Management tab has the "Allow this device to wake the computer" option greyed out.
    In my bios I have S1 & S3 sleep enabled and everything I can find that could be related with WOL enabled (Wake from Modem, Wake from Ring, etc.) although I see nothing referring to Wake on Lan or WOL specifically mentioned. The machine wakes from sleep using a keyboard perfectly so no problems there.
    If anyone can help that would be great. :lease:
  5. alasrati
    alasrati Member
    Dec 20, 2010
    824
    28
    +95
    If you have WoL for your wired Ethernet port, use a wireless bridge instead. Make sure it can handle magic packets though.
