Cocktail Audio X10 Discussion, Part II
Discussion in 'Streamers & Network Music Players' started by amcluesent, Jun 7, 2012.
  1. Big Chief Onion
    Big Chief Onion Member
    Mar 23, 2012
    13
    Is there any way of making the web interface between my laptop and the X10 more stable? The connection is often lost for long periods. I used to be able to easily set it up again by rebooting the router but that doesn't work so well any more.
  2. graham.myers
    graham.myers Active Member
    Mar 11, 2003
    6,155
    +923
    Is it a wired or wireless connection? Wireless is open to all sorts of connection issues. Have a look at ssinsider to see if you just getting interference on the channel you are using
  3. Big Chief Onion
    Mar 23, 2012
    13
    It's a wireless connection Graham. What's ssinsider? I Googled it but all I could find was something about bass fishing. I'm sure that's not what you were referring to!
  4. amcluesent
    amcluesent Moderator
    Aug 13, 2002
    4,895
    +963
  5. graham.myers
    Mar 11, 2003
    6,155
    +923
    oooo close :) Thanks amcluesent
  6. mullers63
    mullers63 Member
    Jan 3, 2012
    11
    3
    Anyone have a quick set of instructions for streaming (rather than downloading) tracks from the X10 using VLC. I have VLC now on an Android phone and am assuming it should stream FLAC effectively but am struggling.
    Many thanks
  7. nellieboy
    nellieboy Member
    Jun 9, 2012
    hi chris mk. well im glad the exporting and conversion works. seems like the copy is fathful to the original as the problem already existed on the x10.cant help with that sorry. have you tried doing it with a whole album preferably one that is correctly labled
  8. Big Chief Onion
    Mar 23, 2012
    13
    Thanks but after I'd downloaded it I realised it's way beyond my level of understanding. I managed to find out that my router uses channel 9 and 13 but I don't know what that means or what to do with the information.
  9. hamish72
    hamish72 Guest
    Insider can show you if any other wifi is using the same channels if so change the channels your router uses
    Many electronic devices can degrade your wifi if near router or X10 radio tv and cordless phones are about the worst offenders along with switch mode power supplies as used by most routers keep it and all other electronic gear as far from the router as you can
  10. Big Chief Onion
    Mar 23, 2012
    13
    Thanks Hamish. It's not a problem with channels but just about every device you mentioned is clustered in one portion of the room. It could be that some moving around is needed.
  11. Chris MK
    Chris MK Member
    Jan 22, 2008
    58
    I think the answer is not to rush things!
    I've redone a few and they seem to be fine thanks.
  12. russypussy
    russypussy Member
    Aug 11, 2011
    37
    9
    Any new info anybody?
  13. gpauk
    gpauk Member
    Sep 17, 2011
    85
    +3
    Yeah - gone really quiet here -- is no news good news?!
  14. whatstrumpsnell
    whatstrumpsnell Member
    Nov 6, 2012
    2
    booted my X10 today offered upgrade to firmware R1669 both the UK and US Cocktail Audio sites as of an hour ago had no details of the release has anyone taken the step to upgrade ??
  15. russypussy
    russypussy Member
    Aug 11, 2011
    37
    9
    Just updating as I speak.
  16. russypussy
    russypussy Member
    Aug 11, 2011
    37
    9
    On first inspection there's an auto shutdown option.
  17. TheZillionthSue
    TheZillionthSue Member
    Mar 12, 2012
    16
    3
    What does that do?
    I've downloaded the new release but also can't find any notes for it.
    Also - am I doing something wrong? When I try to do a search, I can only search on the first letter. This is really irritating if for example I am looking for a title beginning with S and have to scroll through hundreds before reaching it.
    Surely I should be able to search on at least the first three letters?
    I'm supposedly up to date with all the upgrades.
  18. russypussy
    russypussy Member
    Aug 11, 2011
    37
    9
    It shuts it down automatically at a pre-determined time.
  19. Mahay
    Mahay Member
    Aug 16, 2011
    26
    4
    Me tooo...........
  20. gpauk
    gpauk Member
    Sep 17, 2011
    85
    +3
    I wouldn't touch it without seeing release notes... There have been updates worth skipping before!
  21. Hagar63
    Hagar63 Member
    Sep 5, 2011
    65
    11
  22. simonblue
    simonblue Active Member
    Jan 29, 2006
    10,874
    +1,649
  23. Mahay
    Mahay Member
    Aug 16, 2011
    26
    4
    Now I am able to browse album by genre with the new firmware. :smashin: Nice job!!!
    The playlist is getting better because you can add an entire album directly. However I find the process to be little complicated or confusing. I wish there is a very simple option where you can add an album or a group of song, genre etc. directly through menu, not through the protocol described in the release note nor through the blue/yellow button. I mean, something like you can create an empty playlist, then you browse your DB and add song from there.
    But anyway, I still find the X10 worth the money. I also like the fact that they listen to your issue and trying hard to resolve the problem. I personally notice a big improvement since the date I made my purchase. I think this is one of the best player out there.:devil:
  24. gpauk
    gpauk Member
    Sep 17, 2011
    85
    +3
  25. simonblue
    Jan 29, 2006
    10,874
    +1,649
    Nice you can download artwork now :smashin:
  26. russypussy
    russypussy Member
    Aug 11, 2011
    37
    9
    It's really efficient too. This is a great addition it's now leaps and bounds ahead of the Brennan.
  27. eNeeMac
    eNeeMac Member
    Mar 23, 2011
    36
    11
    I've had the X10 for over a year now and can honestly say I've never had an issue with it. I also bought my father in law one and he's in his 80's he loves it...agreed he does need help with how to update software and operate the unit but you don't need a computing degree! The updates so far are great...gapless playback was a must but now to download artwork is easy! Keep up the good work Cocktail updaters!
  28. carl w
    carl w Member
    Oct 12, 2011
    20
    3
    Let's face it,the Brennan was never even close was it?
  29. tea4one
    tea4one Member
    May 11, 2011
    58
    11
    +6
    The best just got better! Its like getting a new gadget every month. Had mine about 15 months now, its a completely different machine now - and it was great back then!!!! I nearly bought a pad just to use for the GUI downstairs instead of firing the laptop up each time - no need at all now! Well done those guys!!!!
  30. russypussy
    russypussy Member
    Aug 11, 2011
    37
    9
    True.
