Can't reinstall SonicStage (data unable to be retrieved from server)
Discussion in 'Headphones & Portable Music' started by ak47wong, Mar 18, 2010.
  1. ak47wong
    ak47wong Member
    Aug 5, 2005
    115
    I have an NW-HD5. I've been using SonicStage 4.3 on Vista (and previously on XP) for years with no problems. Starting a few days ago, it just crashes every time I start it. The SS screen appears as normal but then Vista immediately displays the message:
    SonicStage Application has stopped working
    -> Check online for a solution and close the program
    -> Close the program​
    Rebooting didn't help. I figured I'd just reinstall it. I have a current backup of my library.
    But when I run the SS 4.3 installer, it first displays "Retrieving data from the server..." and then quits with this message:
    Data was unable to be retrieved from the server.
    Please check your Internet connection and try again.
    (21000)
    My Internet connection is fine. I also tried turning off my firewall. No luck.
    Has Sony turned off the DRM servers?? If so, I'm stuffed.
    If someone else out there has the SS installer handy, would you mind running it and seeing if you can get past the initial server connection? Thanks.
    Andrew
  2. syko67
    syko67 Member
    Apr 22, 2008
    843
    46
    +111
    at work at the mo but will try mine later...when you unistalled did you remove absolutely everything?? I had a problem a few yrs back, had to go into the registry and remove everything in there too...as windows uninstall (xp anyway) doesnt do a full job..I remember downloading an extra uninstall thing from MS that did a fuller job..
    anyway... I'll try later an let you know if mines working ok (not used it for months)
  3. CurryMad
    CurryMad Member
    Sep 4, 2009
    24
    3
    Hmm - Interesting.
    I've been using Sonicstage for years as well, and just last month my album art is not showing on the Album view.
    Coincidence?!
