cant format to ntfs for my 32gb mem stick "windows is unable to complete format"
Discussion in 'Hard Disks & Memory' started by Proto Omega, Oct 22, 2009.
  1. Proto Omega
    Proto Omega Member
    Aug 6, 2005
    350
    Whenever I try to select the NTFS option to format my 32gb stick, it always gives a message saying "windows is unable to complete the format"
    I wanted ntffs so i can tranfer large files onto it but it wont let me format it. The stick itself works fine in FAT32 but this option only has a limit of 2gb for a file size.
    I'm using XP Pro SP2
  2. confused88
    confused88 Member
    May 15, 2009
    1,246
    +70
    I think the limit is 4gb. I have not been able to reformat a flash drive either.
  3. arthurleung
    arthurleung Member
    Sep 11, 2009
    +7
    You probably bought a fake 32GB stick (perhaps the recent CeX deal?), and hence it is not able to format correctly.
  4. sammieb121
    sammieb121 Member
    Jan 3, 2010
    2
    I'm having the same problem with my 32gb USB memory stick in that it won't let me format to NTFS. I bought it for music in the car so have tried instead to copy and paste album by album, and the drive is obviously holding the data because i can see that in properties, but i can't actually see the files to use, hence me trying to format to NTFS.
    Is there any way i am able to tell if this is a fake drive as i've run a scan on it and it tells me all is ok.
    All help would be much appreciated guys :)
    Sam
  5. hyperfish
    hyperfish Active Member
    Nov 15, 2009
    3,154
    +1,009
    >start>>run>>cmd
    convert X: /fs:ntfs (Where “X” is your USB drive letter)
  6. sammieb121
    sammieb121 Member
    Jan 3, 2010
    2
    thanks for that hyperfish :)
    does this take some time as i've set it running, and its currently saying 'converting file system' but it doesn';t actually appear to be doing anything??
  7. hyperfish
    Nov 15, 2009
    3,154
    +1,009
    I would expect so but I had to leave mine unattended at the time so I cannot really advise.
  8. Iccz
    Iccz Active Member
    Apr 29, 2008
    24,173
    +6,763
