cannot get set up menu to appear on tv screen vsx 920
Discussion in 'Integrated Amplifiers & Receivers' started by mick23, Jan 23, 2011.
  1. mick23
    mick23 Member
    Mar 20, 2002
    801
    hi all ive posted this before but cannot seem to resolve this problem.
    last week had hdmi out connected to lg lcd, could not get any setv up menu to display on my tv, it turned out to be (the av control needed to be set to off)
    yesterday went to set up speakers through microphone ,macca on pioneer display. it did all the test tones,
    it finished but nothing shows on my tv screen as regards settings??
    i then tried to get the set up menu to appear on tv screen ,but the tv just locks up and does not respond to remote .i have to reboot tv.
    i have tried av control on/off and sometimes it shows (not avaliable)
    if i use reciever/home menu i seem to be stuck on the macca set up,
    can some confirm hdmi out to tv, select reciever/home menu and set up appears on tv.
    not sure if hdmi control thing is interfering with set up.
    thank you all
  2. akhlaq768
    akhlaq768 Member
    Oct 14, 2006
    811
    +6
    Didn't know u could get the amp setting displayed on the tv
  3. kit1cat
    kit1cat Member
    Sep 4, 2002
    1,316
    +75
    I don't know your amp, but you could try a different video output. composite video is good enough for setup menu's or component. Is there a setting in your amp to chose the video out for the menu's?
  4. mick23
    mick23 Member
    Mar 20, 2002
    801
    hi all finally got it to work i needed to enable hdmi control to on.
  5. akhlaq768
    akhlaq768 Member
    Oct 14, 2006
    811
    +6
    Can I do the sane for the vsx 520
