Cannot change channel on Samsung LE26R74BD
Discussion in 'LCD & LED LCD TVs' started by Severus1977, Oct 7, 2008.
  1. Severus1977
    Severus1977 Member
    Oct 7, 2008
    2
    Hi, tonight i changed my samsung LE26R74BD back to TV from HDMI and it switched back to channel 5, the last channel i'd been watching.
    The picture was moving in a jerky manner and so i switched the tv off for a few seconds then switched it back on.
    I now cannot change the channel away from channel 5. I can do everything else (put it on av, HDMI, change the volume up and down, change the picture mode and screen size etc) but it remains stuck on channel 5 and i cannot bring up the electronic program guide either.
    Please does anyone know what has caused this and more importantly how i can fix this?
  2. alnwrd
    alnwrd Member
    Oct 21, 2005
    324
    28
    +30
    I suggest you do a rescan of channels or a factory rest if this option is available. Have you tried channel changing by pushing buttons on the tv to eliminate possible problems with the remote control?
  3. Severus1977
    Severus1977 Member
    Oct 7, 2008
    2
    HI alnwrd, thanks for such a quick reply :)
    Yes that was my first thought, to somehow reset it to the factory settings but i do not have the option to do this. I've checked in the manual and it says to press the "D.Menu" button but nothing happens when i press this.
    I've also tried pressing the buttons on the set itself but again the only ones which do anything are the volume ones.
  4. wkm026
    wkm026 Member
    Oct 23, 2008
    I have just come across a similar problem with my Samsung 26" LCD TV I retuned the analogue channels to test new arial and now can only get one Digital Channel ...BBC1. The D Menu key does not work ..I have removed batteries from remote and switched off and on the TV but still unable to get the TV to tune any other Digital Channels .....will call Sansung in the morning
  5. Hex69
    Hex69 Guest
    I had exactly the same problem. I fixed it by doing the following
    1 Turn off the TV so its on standby
    2 Then press these keys one after another
    Info, Menu, Mute, Power.
    When the TV turns back on you are in the Service MENU.
    Now press your down arrow key until you get to number 12 on the on screen options,
    It’s marked RESET.
    Push the arrow key to the right, to RESET your TV.
    Next simply follow the instructions on the TV to retune your channels.
    I would love to take the credit for knowing this but I found it on another forum how to mend it .com - chanel stuck on dtv on samsung le32r74bd?
    It took about 10- 12 attempts to bring up the Service menu but I swear it works.
    • Thanks Thanks x 1
  6. ovaspark
    ovaspark Member
    Dec 12, 2008
    3
    4
    Just tried this fix on a TV we have and it worked 1st time - thanks !!!
  7. chaos7
    chaos7 Guest
    Bit of an old topic here but i've came across this solution while searching google. I have reset the TV using the method shown above and I still cannot get the freeview to work. The TV has never been tuned to recieve freeview so I dont know if it was like it when I purchased it. When I press the DTV button to switch to freeview I either get a Samsung splash screen or a choice of various coloured backgrounds (bright green, pink grey etc) but still no freeview and the D Menu button doesnt work either and I have tried two different remotes.I have also reset the TV now numerous times and still no solution. Has anyone got any suggestions?
    TV is a LE26R73BD by the way.
  8. cecemf
    cecemf Member
    Jan 7, 2007
    120
    +12
    I have the same problem but can't ge ton the SERVICE menu, the TV does seems do be doing something different after the manip. it start then go off again straight away but restart and no service menu, can any one help ?
  9. cecemf
    cecemf Member
    Jan 7, 2007
    120
    +12
    I have been doing it for the pas 30 min and still can'y get into the service menu ! Did anyone had similar Probleme !
  10. Adrian_F
    Adrian_F Active Member
    Jun 29, 2007
    1,413
    83
    +305
    Make sure that you are starting from Standby .
  11. cecemf
    cecemf Member
    Jan 7, 2007
    120
    +12
    I did, but still nothing, the TV start then restart straight away but no menu. I try to start DTT then analogue then on hdmi still the same :-(
    Even powered off then first start with the code.
  12. cecemf
    cecemf Member
    Jan 7, 2007
    120
    +12
    Good news ! I manage to do it !
    I found outwhy it didn't let me enter the service menu, I went to the TV menu to turn OFF the Melody (melody when you turn your TV ON/OFF) and then I turn OFF the Digital NR option after that it work's ! so I guess the melody at the start was stoping the TV to go on Service mode !
    Hope that will help other people with similar probleme as Samsung wanted to charge me $100 for reinstalling the firmware !
    :smashin:
  13. ram5e5
    ram5e5 Member
    Apr 21, 2008
    23
    Just in case anyone looks on here, my Samsung LE26R74BD also 'broke' today (30/09/2009) when Freeview changed in the UK, resulting in the D Menu button not working at all. There is nothng at all in the manual about how to reset the TV but I applied the instructions above and it worked a treat first time!
    Thanks.
    ram5e5
