Can you use a loft digital TV aerial for a DAB feed?
Discussion in 'DAB Digital Radio & FM Radio' started by Sheff, Jun 15, 2009.
  1. Sheff
    Sheff Member
    Jun 15, 2009
    Hope this is in the right forum, please forgive the noob if it isn't!!:)
    I have a loft aerial for digital tv that I no longer use since I've got Sky.
    I've got a DAB radio with a built in aerial but it gets a pretty limited signal so I've been thinking about getting a rooftop DAB aerial to try to get better recption on a wider range of stations
    Before I do that though I thought it would be worth asking if my digital tv aerial would receive DAB signals as well?
  2. sennen
    sennen Member
    Nov 2, 2004
    103
    +8
    It might do if it is a wideband aerial and is pointed in the direction of your local DAB transmitter, and you don't use frequency-limiting boosters/amplifiers (e.g. a masthead amplifier that filters for UHF only).
    It worked in my case - taking me from a variable 60%-ish quality with the dangly wire to 100% on all stations.
    Have you tried plugging your existing TV loft aerial into your DAB radio?
  3. grahamlthompson
    grahamlthompson Well-Known Member
    Aug 3, 2006
    18,798
    163
    +3,106
    The answer is not very well DAB is VHF band 3 (an old 405 line ITV aerial will work fine as VHF band 111 was used for this) with the active element at around 2 ft long, UHF TV aerials are designed for the much higher frequencies of the UHF band with the active element (half wavelength) of around 6"
