Buying DIY Trade Tools
Discussion in 'Home Cinema Building DIY' started by zoink, Feb 12, 2012.
  1. zoink
    zoink Member
    Nov 27, 2011
    52
    Hello
    Could someone please recommend some websites where one could purchase trade tools such as drills, jig saws etc?
    Thanks!
    P.S. I'm new to DIY and wanting to have the base tools before embarking on work! lol ;)
  2. jtotheb
    jtotheb Member
    Aug 14, 2007
    76
    +3
    Screwfix would be a good starting point
  3. Geps
    Geps Member
    May 7, 2011
    792
    28
    +87
    Another recommendation for Screwfix - I've used their returns service a couple of times now and it's been well worth it.
  4. rdmbfossa
    rdmbfossa Member
    Jan 4, 2007
    829
    28
    +38
    I buy quite a lot of tools for work and find ffx and toolstop both very good. Depends on your budget, I find Metabo stuff very good, quality tools should last a long time if you look after them.
  5. mifty12
    mifty12 Member
    Jul 8, 2007
    59
    11
    I am a carpenter and personally find screw fix over priced my recommendation would be www.itslondon.co.uk
  6. Daftvader1
    Daftvader1 Member
    Oct 2, 2011
  7. J-a-m-e-s_7
    J-a-m-e-s_7 Member
    Sep 23, 2009
    399
    +75
  8. 27neth
    27neth Active Member
    Feb 15, 2007
    2,315
    83
    +329
  9. zoink
    zoink Member
    Nov 27, 2011
    52
    Thanks for the list guys! That's awesome! Now let the bargain hunting begin! :D
  10. liamt
    liamt Active Member
    Aug 18, 2009
    9,359
    +1,795
    op: get the best tools you can. buy cheap and you buy twice and end up with a bad job.
    i would recommend Makita tools, very good. their jigsaw is awesome too. not cheap but should last years. black and decker just arent built to last.
  11. Geps
    Geps Member
    May 7, 2011
    792
    28
    +87
    Screwfix will price match so you don't need to worry about over paying ;)
  12. Yaka
    Yaka Member
    Dec 20, 2000
    1,303
    48
    +45
    Personally use screwfix the most and they are more than happy to price match.
    One tip I can give to a DIY newbie is be careful who you lend tools to. I've lost count the amount of times family
    Members have naffed up blades, drill bits and drills etc. much more cost effective to tell careless folk to get lost
  13. Navvie
    Navvie Member
    Apr 17, 2007
    331
    +49
    I second the Makita recommendation. DeWalt used to have a very good reputation before Black & Decker got hold of them.
    Amazon can be surprisingly competitive on power tools.
  14. davepuma
    davepuma Well-Known Member
    Jun 24, 2004
    17,091
    +3,012
    There are a few ebay retailers that sell Milwaukee tools at far cheaper than you will find at your local trade supplier. If you're buying a job lot of power tools, it would make sense to get them all from the same brand so that they use the same battery etc. Bosch blue, Makita, DeWalt, Hilti seem to be the most popular trade brands. Hilti can only be bought direct. The build quality and back up is meant to be second-to-none. It should be for the prices they charge. I have a Hilti SDS and combi drill. Way over the top for my use but they should last a lifetime.
  15. J-a-m-e-s_7
    J-a-m-e-s_7 Member
    Sep 23, 2009
    399
    +75
    I second this, these are the 5 main brands you want to be looking at in my opinion: Dewalt, Makita, Milwaukee, Bosch and Hilti if you can get a good price. I buy a lot of dewalt and makita and have never had any major problems they are equally as good in my opinion i never understand why people always talk about dewalt being rubbish because of the affilation with black and decker. Yes i now people who have had dewalt tools go wrong but i also know people myself included that have had makita stuff pack up on them. Thankfully i received good customer care from makita and dewalt and each time anyone had any problems they were more than happy to sort it. I think really when your buying tools this is what you end up paying the extra money for. I'm in the trade and i use my tools everyday so they take a fair bit of wear and tear having the peace of mind that it shouldnt break and in the unlikely event it does they will sort it is worth the extra money the tools cost over cheaper brands. Milwaukee is also very well made too.
    Regards
    James
  16. aVdub
    aVdub Active Member
    May 27, 2010
    2,316
    116
    +922
    It's also worth checking the DIY giants now and again.
    I've picked up some good named tools at good prices because the store is clearing old stock.
  17. 27neth
    Feb 15, 2007
    2,315
    83
    +329
    My cordless tools are all Hilti. I have used Makita and Dewalt in the past, the Hilti are better :smashing: The plumber i work with binned all his Dewalt tools and bought Hilti after using mine..
    If you do have a problem, (i had a wire come loose on a charger) took it to Hilti on Monday afternoon, it was back repaired on the Wednesday afternoon...:smashing:
    John..
  18. Yaka
    Yaka Member
    Dec 20, 2000
    1,303
    48
    +45
    They are in a similar league to festools arnt they, prolly out of the price for the average diyer
  19. 27neth
    Feb 15, 2007
    2,315
    83
    +329
    I have some Festool tools too :smashing: Id say the Hilti tools are better than the Festool ..... For a diyer they are a waste of money..
    John
  20. MrGrumpie
    MrGrumpie Active Member
    Aug 13, 2002
    17,016
    +1,663
    Agreed, I buy all my stuff from here too. Found out the hard way on the last refurb project. The last time I bought anything in orange, or green Bosch.
    Slowly amassed a collection of Makita powertools and I must say, it makes a HUGE difference on DIY projects...
  21. MrGrumpie
    Aug 13, 2002
    17,016
    +1,663
    I've never found the DIY giants to be good value on decent power tools. Sure, you find some cheap Makita, Dewalt and Bosch blue kit, but it's stuff that's generally at the bottom of their ranges and for the serious DIY'er, or someone doing a big project, even that stuff doesn't cut it.
    Go for Dewalt or Makita 18v lithium ion kit...and go for cordless on everything you can (the caveat being something like a big mitre saw or SDS drill if you have lots of masonry to get through). Even then for SDS, I'd probably still go cordless. Just make sure you have more than one battery...
    Essentials for me are:
    Impact driver
    Drill driver
    Hammer driver (often good having this separate to the drill driver for convenience)
    Jigsaw
    Circular saw
    Mitre saw
    ...but it all depends on the work you're doing.
  22. aVdub
    aVdub Active Member
    May 27, 2010
    2,316
    116
    +922
    And how much the OP wants to spend.
    The majority of my tools are high quality and were bought for the jobs I was doing at the time and are still going strong now. Bosch is my prefered brand.
  23. Sanders79
    Sanders79 Member
    Aug 16, 2006
    1,502
    +158
    Love my impact driver (dewalt 18v li-ion), best tool I bought last year.
  24. Geps
    Geps Member
    May 7, 2011
    792
    28
    +87
    I'd say angle drill driver over the impact driver - very useful when you're building stud walls and drilling holes to run cables through joists.
  25. MrGrumpie
    Aug 13, 2002
    17,016
    +1,663
    tbh I bought mine gradually over time. The best thing for me was to buy tools as I could afford them, not just when I needed them. Saved me the pain of shelling out an absolute fortune in one hit...
  26. MrGrumpie
    Aug 13, 2002
    17,016
    +1,663
    I have to say, out of all of my tools, the impact has been the most useful. Very compact, and makes short work out of DIY when it comes to any form of construction.
    I've got an adaptor bit for one of my drills, but I have to say, a dedicated angle drill driver is next on my list for when I do the current house refurb project that's in the planning.
  27. Rick2102
    Rick2102 Member
    Nov 2, 2011
    338
    28
    +46
    ITS are good, I always shop around, but never heard of these guys, ordered a catalogue and am impressed :smashin: Thanks.
