Bt total broadband fibre optic plus sky hd anytime
Discussion in 'Sky, Sky+, Sky HD & Sky 3D' started by podgey3874, May 2, 2012.
  1. podgey3874
    podgey3874 Member
    Feb 12, 2012
    512
    +3
    Hi guys can anyone help I have bt fibre optic broad band and want to connect my sky hd box to the router via Ethernet cable but the problem I am not sure about Iis were my Ethernet cable goes in to the bt box on my wall that is white in colour or do I need to put the cable in to the router the black one a standerd bt customer as not fibre optic I just want to make sure I have the best speed possible cheers
    Basically what i am saying is my router with the 4 yellow ports on the router are empty
    But I have also got a red cable on the back only my router saying bt infinity on it rubbing to the white bt box on the wall but this also has a spare Ethernet socket in it and a Belive that should be we're the cable should go but I want to be certain
  2. True Romance
    True Romance Active Member
    Feb 7, 2005
    3,160
    +627
    :confused:
    Your router should have aorund 4 +- ports on the back, plug your cable into one of these and the other end into the sky box (if it will reach).
  3. logiciel
    logiciel Moderator
    Feb 2, 2008
    45,572
    +4,418
    What connection do you have for the broadband on your computer?
  4. podgey3874
    podgey3874 Member
    Feb 12, 2012
    512
    +3
    Wireless
  5. podgey3874
    podgey3874 Member
    Feb 12, 2012
    512
    +3
    I have bt infinity so I have the black router that is connected to a another router on my wall think this is the fibre optic part does any 1 no
    And do I connect the Ethernet cable from my sky hd box to the fibre optic box if this is what it is or to the router?
  6. Andy98765
    Andy98765 Active Member
    Feb 15, 2006
    10,374
    +1,491
    You only touch the black box (BT HOME HUB), it has 4 outputs. Do not waste the 1 gig port on the SKY box.
  7. Stevenage Neil
    Stevenage Neil Active Member
    Jul 14, 2008
    9,413
    +884
    You have a modem and a BT Hub, (router). All internal connections, hard wired or wireless, go via the hub.
  8. Stevenage Neil
    Jul 14, 2008
    9,413
    +884
    Why the double post?
  9. podgey3874
    podgey3874 Member
    Feb 12, 2012
    512
    +3
    What do you mean do not waste the 1 gig port on the sky box please explain
  10. podgey3874
    podgey3874 Member
    Feb 12, 2012
    512
    +3
    So the white box I refer to is the modem?
  11. podgey3874
    podgey3874 Member
    Feb 12, 2012
    512
    +3
    Don't no how to delete this And had to retype
  12. Stevenage Neil
    Jul 14, 2008
    9,413
    +884
    How would I know? I don't have Infinity. All I do know is what I said previously:- "You have a modem and a BT Hub, (router)."
    One will have a single Ethernet connection, the other will have multiple ethernet connections.
  13. podgey3874
    podgey3874 Member
    Feb 12, 2012
    512
    +3
    That's we're your wrongs az the modem as 2 Ethernet connections that's why an asking the question would it be ok to or should I plug the Ethernet cable to the sky box in to the modem
  14. logiciel
    logiciel Moderator
    Feb 2, 2008
    45,572
    +4,418
    The Sky machine has to be connected by an ethernet cable not to the modem, but to the router.
    That's the thing that you also use to access the internet through your computer.
    As you do that by wireless you should be able to establish which device is doing it.
    Maybe Andy will explain his note about a "1 gig port". :confused:
    • Thanks Thanks x 1
  15. Andy98765
    Feb 15, 2006
    10,374
    +1,491
    The BT hub has a 1 gig port and 3 100meg ports, pointless connecting to the SKY box as that I believe is only 100meg anyway, still way fast enough. best used for a PC with a 1 gig port or connected to a 1 gig switch for more ports.
    The modem has 2 LAN ports one of which is used by BT to supply your service. That box is then connected to your router (Home Hub) and that is the unit that distributes the service to your home connected PC's Blu-ray, Sky boxes etc and gives you the IP addresses in your home.
    • Thanks Thanks x 1
