Boston Acoustics Soundware S or CA Minx (compared to Kef Egg 2001's)
Discussion in 'Speakers' started by S2KI, Dec 19, 2012.
  1. S2KI
    S2KI Member
    Jan 3, 2003
    112
    Having just moved house I need a new 5.1 compact cube surround package, as my KEF Egg 2001's are just too big to be ceiling mounted in the new space.
    The main requirements are:-
    They need to be white
    Smaller than the Kefs
    Be as good as the Kefs with music (or as close as possible). We probably listen to music more than using them as surround sound.
    I would prefer not to go with the BA Soundware XS SE, my brother has them and they lack any mid range in musical reproduction.
    Therefore I have been looking on the internet at:
    Cambridge Audio Minx cubes. (Min 10)
    or
    Boston Acoustic Soundware S (which are larger than the XS, but there are not many reviews out on them yet.)
    I probably wont get a chance to demo them as RS that stock the Minx do not do the BA Soundware S.
    Does anyone have any input or opinion on the BA vs the Minx vs my old Kef's?
    Also how would my Kef sub compare to the newer subs.
    They are going to be used with a Denon 1612 which I picked up cheaply as last years stock.
    All advice great fully received, thanks.
  2. PSM1
    PSM1 Well-Known Member
    Dec 20, 2008
    18,225
    171
    +2,903
    Personally I do not think either set of speakers is going to match up to your current speakers, especially with music. You should be looking to pay in the region of £1k or so to really match the Kefs. Anthony Galleo has some small speaker options that could be worth a look. As would the Monitor Audio Radius or Apex ranges (although the PAex really deserves better amplification than the 1612).
  3. quantumAV
    quantumAV Active Member Assured Advertiser
    Oct 14, 2004
    2,599
    +421
    Radius HD R45HD will be your best bet I think
  4. S2KI
    S2KI Member
    Jan 3, 2003
    112
    Thank you for the input, I'm sure that these will do a better job.
    I particularly like the Anthony Galleo Micros.
    However they are more money and I wonder if they are worth it? Will either of the other 2 options do a good enough job for me? Has anyone heard the BA Soundware S?
  5. Suave
    Suave Member
    Jul 30, 2004
    3,860
    103
    +340
    Do they have to be white? If not, I have some Orb Audio Speakers that are as every bit as good if not better than the Gallo Micro's - they are in black though but sound great with both music & movies!
    Suave!
