Block Diagrams of current LCD TV
Discussion in 'LCD & LED LCD TVs' started by mikl1984, Mar 29, 2008.
  1. mikl1984
    mikl1984 Member
    Apr 20, 2007
    383
    43
    +130
    First prompt - this post not for everybody:)
    But If you are interested in what you have in reality in your box without any marketing - welcome
    All vendors doesn't like to talk about it. Marketing departments find new words for super-duper technology. What's behind this words?
    Try to research:)
    First of all - what's rated source for reliable information:
    - service training
    - service manual
    - service menu settings
    - mainboard photo
    - panel sticker(s)
    - TV sticker(s)
    - user manual
    - vendor's spec
    Most hard thing - many vendors remark main chips, use just own PN for replacement.
    As I am experienced in Samsung let's begin from this brand
    http://www.avforums.com/forums/showthread.php?t=601553
    In 2007 Samsung produced following platforms:
    Series Type Letters_in_FW CodeName Announce Date
    S8/R8 JA JSM Jasmine Spring 2007
    R8 BP BDP Bordeaux+ Spring 2007
    M/N8 TU TLP Tulip Spring 2007
    F8 PY PON Peony Summer 2007
    F9 RO ROS Rose Summer 2007
    In 2008 appears:
    A3 Jade Spring 2008
    A4 Coral Spring 2008
    A5 Pearl Spring 2008
    A6 Amber Spring 2008
    A7 Ruby Spring 2008
    In attached file you may find all known configuration for LCD TV (mainly Samsung for now:( )
    Block diagrams with some description of main components will follow...
    Hope to support with other brands :lease:
    • Thanks Thanks x 4
  2. mikl1984
    mikl1984 Member
    Apr 20, 2007
    383
    43
    +130
    First diagrams will be just announced A6 series from Samsung.
    A lot of rumors due to sales in US began 2-3 weeks before Europe.
    Some words about new naming convention for Samsung TV LE40A65*A for example
    - L - LCD
    - E - Europe model. May use A- Asia&Africa N - Korea, America
    - 40 - diagonal size
    - A6 - serie of TV
    - 5 - no ideas ???
    - * - digit from 1 to 9 for some minor modifications in appearance (from 1 to 4 - w/o DVB-T, 5-9 -with DVB-T)
    - A - First letter of platform (in this case Amber)
    Let's begin with US version
    P/N: BN82-00347A-00
    Chassis :
    GAM32MUS
    GAM40MUS
    GAM46MUS
    GAM52MUS
    Model :
    LN32A650A1F
    LN40A650A1F
    LN46A650A1F
    LN52A650A1F
    [​IMG]
    Main processor
    Samsung Bay hill+ (BHP) S4LJ003X
    1204-002814 IC-DECODER;S4LJ003X,PBGA,816P,35x35mm,PL
    Appear Fan in LN40A650
    [​IMG]
    No direct input for HDMI - additional DA-AD conversions
    [​IMG]
    BN07-00537A LCD-PANEL ??? 32"
    BN07-00529A LCD-PANEL;LTF400HC01,10bit,40inch,1.07B,
    BN44-00198A IP BOARD;SIP40D,PEARL,15mA,130mA,150Hz,2
    BN07-00530A LCD-PANEL;LTF460HE01,10bit,46inch,1.07B,
    BN44-00203A IP BOARD;SIP468A,PEARL,15mA,135mA,150Hz,
    BN07-00531A LCD-PANEL;LTF520HE01,10bit,52inch,1.07B,
    BN44-00201A IP BOARD;SIP528A,PEARL,15mA,150mA,150Hz,
    Now more about Europe version
    Chassis : N46A
    Model :
    LE32A65*A
    LE37A65*A
    LE40A65*A
    LE46A65*A
    LE52A65*A
    LE32A65*A
    Brightness : 500cd/m2
    Contrast Ratio : 8000:1
    Response time : 6ms
    Dynamic contrast, Super-PVA
    BN07-00537A LCD-PANEL;LTF320HA02,8bit,32inch,16.7M,1
    BN44-00208A SMPS-LCDTV;MK32P5T,SEM,AC/DC,137W,AC100
    LE40A65*A
    Response time : 6ms
    BN44-00197A IP BOARD;SIP408A,PEARL,15mA,130mA,150Hz,
    LE46A65*A
    Response time : 6ms
    BN44-00202A IP BOARD;IP-271135A,PEARL,15mA,116mA,150
    LE52A65*A
    Response time : 6ms
    BN44-00200A IP BOARD;IP-361135A,PEARL,15mA,116mA,150
    TFT LCD Panel 100Hz (only 32” 50Hz)
    HDMI 4
    BN59-00706A
    BN59-00706A REMOCON;TM-98A,49,EUROPE_IDTV_L650
    [​IMG]
    Fan is used in 40” only
    [​IMG]
    Mediatek SEMT01(MT8226)
    IC118 1204-002869 IC-VIDEO PROCESS;MT8226FJ,BGA,569P,31x31
    NEC UPD61213GM-104-GAA-A
    IC7001 1204-002861 IC-DECODER;UPD61211GM-104-GAA-A,QFP,216P
    Samsung FBE3 DNIe Pro S4LF136X01
    IC118 1204-002779 IC-VIDEO PROCESS;S4LF122X01,PBGA,208P,17
    The Block Processing Video Signal
    Component, PC and CVBS signal like AV are inputted to Scaler-IC (MT8226(IC5105)) directly.
    HDMI signal is inputted to switch-IC, TMDS351 to select just 1-HDMI input in 3-HDMI input.
    (But HDMI3 (Side) inputted to Scaler-IC directly), And then Selected HDMI signal is inputted to Scaler-IC.
    Scaler-IC converts video signal to 12bit of LVDS Signal, standard format to run a LCD panel.
    FBE3-IC receives this LVDS signals and processing it to enhamce picture quality.
    And then final 12bit of LVDS Signal is outputted.
    The Block Processing Sound Signal
    Sound signals of RF(SIF), HDMI, Component, DVI, PC and AV input are inputted to
    Sound-IC (MT8291 (IC2102)).
    DTV_AUDIO signal is also inputted for MP3 connected to wiselink.
    MT8291(IC2102) processes these signal and outputs 12C signal to digital AMP-IC (NTP3100 (IC2104)).
    And signals for headphone and Monitor-out are outputted.
    NTP-3100 IC outputs an analog sound signal to run Speakers.
    [​IMG]
    Why Samsung decide to make abs different model for diff markets?
    His BHP doesn't support DVB-T:(
    Due to this reason they used SoC from Mediatek for Europe.
    • Thanks Thanks x 3
  3. kwm30
    kwm30 Guest
    nice, i have an la46f81bx/rad, sq02, so no DVB-T
    Model la46f1bdx has a DVB-T, am i right in making the assumption that the f81bx model has the capability for a dvb-t daughter board???
    Would you happen to know a part nuber if so????
    cheers
    kelly
  4. mikl1984
    mikl1984 Member
    Apr 20, 2007
    383
    43
    +130
    DVB-T is soldered in mainboard
    No daugter board in your case
  5. DaveC
    DaveC Member
    Dec 7, 2003
    312
    28
    +54
    Interesting stuff. I'm suprised that samsung are using a 3rd party chip to power their european A6 series. Do you know if this is a common theme with Samsung TVs? Any idea if the MediaTek chip end up in other manufacturers TVs?
  6. LCP
    LCP Member
    Jul 28, 2008
    Hi, I live in South East Asia and have a LA40A650A1R, this is the non-DVB-T tuner version for generic Asian market. It would be great to see the block diagram.
    Thanks!
  7. LCP
    LCP Member
    Jul 28, 2008
    Found out from my service menu that my LA40A650A1R (Asia - non DVB-T) is also using the Mediatek MTK8226 processor, so I guess the different architecture for US (vs. Europe/Asia) is due to some other reasons.
  8. mikl1984
    mikl1984 Member
    Apr 20, 2007
    383
    43
    +130
    According Service Menu photos you have the same platform as EU TV
    • Thanks Thanks x 1
  9. davidteam
    davidteam Member
    Aug 15, 2008
    Hi, I live in Asia, do you know where can I get the
    BN44-00198A IP BOARD;SIP40D,PEARL,15mA,130mA,150Hz, board
    and so for the 52".. thx
  10. doofus
    doofus Member
    Apr 14, 2007
    419
    +15
    @mikl1984 thanks for the excellent infos- have you got diagrams of 2007 models?? please can you accept pms? i tried pming you but you dont allow pms :(
  11. mikl1984
    mikl1984 Member
    Apr 20, 2007
    383
    43
    +130
    • Thanks Thanks x 3
  12. doofus
    doofus Member
    Apr 14, 2007
    419
    +15
    thanks mikl but as im in uk the site doesnt allow- even if i click on one of the advertisers the 30 second countdown doesnt work
  13. KeanosMagicHat
    KeanosMagicHat Member
    Feb 7, 2005
    4,551
    +597
    I can confirm that having seen a UK model LE40A756 in store that it has an LTF400HC01 panel.
    • Thanks Thanks x 1
  14. kamaldr
    kamaldr Member
    Nov 18, 2008
    Hi, Mr david my LCD TV LE32R86BDX/XEC THE LED OF
    POWER FLASH AND CAN NOT START
    I am technician crt TV and I do not know what are the failure ,of the video card or other boards
    THANKS .​
  15. mikl1984
    mikl1984 Member
    Apr 20, 2007
    383
    43
    +130
  16. mv737
    mv737 Member
    Aug 11, 2009
    This information is quite useful as well as the platform.xls file including different chipsets, IC and features. Do you have any additional or updated information about 2008-2009 Samsung TV models? Do you have other spreadsheet such as platform.xls?
  17. mikl1984
    mikl1984 Member
    Apr 20, 2007
    383
    43
    +130
    It's interesting just for few people:(
    Therefore I will not update this file for public
    Anybody are able to add info to this file, using my collections of Service Manuals
    iFolder.ru Samsung 2007-2008
    Dump.Ru Samsung 2009
