Best projector for 1366x768 around £300?
Discussion in 'Projectors' started by Spiiral, Feb 21, 2012.
  1. Spiiral
    Spiiral New Member
    Feb 21, 2012
    2
    I have a laptop with a max res. of 1366x768. My max budget is £300 (ish) Could anyone suggest a good projector? I have found some for this res. but they are in the thousands for some reason.
  2. Deano79
    Deano79 Member
    May 3, 2011
    651
    +50
    The Sony HS20 has native 1366x768. It looks to be a decent pj and you can probably pick one up used for your budget.
