Steve Withers
Outstanding Member
Disclaimer: The settings below are supplied for information purposes only. We make no guarantee that using the adjustments below will improve your TV's picture, they may even make it look worse. Every TV, even from the same manufacturer and model number will vary, as will the environment the TV is used in. For further information on how to set up your TV, please follow the steps in our Picture Perfect campaign.
To find a professional calibrator near you, see our Custom Installer and Calibrator Directory.
You can read the review here: BenQ W1070 review
Preset:
User 1
Brightness: 51
Contrast: 53
Colour: 50
Tint: 50
Sharpness: 8
Colour Temp: Normal
Lamp Power: Economic
Advanced
Clarity Level: 0
Gamma: 2.2
BrilliantColor: Off
Colour Temp Fine Tuning: Red Gain 96, Green Gain 88, Blue Gain 95, Red Offset 256, Green Offset 256, Blue Offset 256
Colour Management: Red - Hue 50/Gain 52/Saturation 49, Green - H 64/G 48/S 50, Blue - H 52/G 47/S 50, Cyan - H 50/G 47/S 50, Magenta - H 70/G 51/S 50, Yellow - H 64/G 50/S 47
Aspect Ratio: Real
Brightness: 51
Contrast: 53
Colour: 50
Tint: 50
Sharpness: 8
Colour Temp: Normal
Advanced
Clarity Level: 0
Gamma: 2.2
BrilliantColor: Off
Aspect Ratio: Real
