Before I get my JSC Sport Card for Football...
Discussion in 'Satellite TV Forum' started by VJVJ, Sep 29, 2012.
  1. VJVJ
    VJVJ Member
    Sep 27, 2008
    16
    Before I get my JSC (Al Jazeera) Sport card, which I know doesn't carry Premier League Football, are there any other cards which do carry Premier League football for a good price?
    Is there a cheap package where I can get trace tropical music channel?
    Your help is always appreciated
    VJVJ
  2. logiciel
    logiciel Moderator
    Feb 2, 2008
    46,266
    +4,487
    What satellite is that channel on?
  3. VJVJ
    VJVJ Member
    Sep 27, 2008
    16
    19.2e
  4. ABARKIE
    ABARKIE Member
    Jan 2, 2010
    654
    28
    +60
    Have you got a motorised dish then?
    JSC is on 13e / 7w.
    Trace Tropical is on 9e or 19.2e
    This is on Hello package which I think you get a Hungarian card for €65.55 euros
    Google Translate - I have no idea over this shop etc
    I think this comes with Digisport which shows Premiership but you might want to check this
    Hope this helps
    • Thanks Thanks x 1
  5. ABARKIE
    ABARKIE Member
    Jan 2, 2010
    654
    28
    +60
    A JSC card should be circa £100, a renewal would be £68 via ebay, if that is any use to you
    How much are looking to spend on cards overall?
    Sat BG - 23.5e circa £280 via TV Corner / Ebay
    Cyfra on 13e - €340 approx via Satskelp http://www.satsklep.pl/en_US/c/Cyfra-Canal-/70
    Tring 16e - circa £260
    Viasat - £200 via ebay
    Plenty of cards are available, depends on your budget and your system
    Hope this helps
    • Thanks Thanks x 1
  6. VJVJ
    VJVJ Member
    Sep 27, 2008
    16
    Thanks. Since it's only the channel Trace Tropical I want, as little as possible. For one channel it's a bit much. To be honest JSC works out to be good package for me because of the amount of athletics so I will be definitely getting that for sure.
    I have technomate 5402HD and 60cm motorised dish.
    That would mean I could only use one card at a time?
    Does anyone know if Hello HD involves 3pm Premiership football as well as trace tropical?
    Is it a one off payment for both Hello HD and JSC or do you pay a monthly subscription fee?
  7. ABARKIE
    ABARKIE Member
    Jan 2, 2010
    654
    28
    +60
    If you used the TM5402 - 1 card in the card reader and 1 in the cam slot (via a cam - cost circa £25 to £50)
    Hello HD has premiership but I dont think 3pms - wish it did
    Packages: Hello HD - KingOfSat
    Your dish may not be big enough - dependent upon where you are in the country
    Hope this helps
  8. kevkbuk
    kevkbuk Active Member
    Jan 27, 2011
    4,030
    +566
    Your dish size will probably restrict you, but do explore all the features of your tm5402 and 10e/39e and others.
  9. VJVJ
    VJVJ Member
    Sep 27, 2008
    16
    JSC channels the signal is is normally around 75% just that it is scrambled of course. Is there any other reason it would prevent me from getting it?
  10. kevkbuk
    Jan 27, 2011
    4,030
    +566
    JSC, no it'll be fine.
  11. VJVJ
    VJVJ Member
    Sep 27, 2008
    16
    Which card should I buy. Viaccess or Irdeto? It's a hotbird card I need and I'm talking about JSC Sport. I don't want to buy the wrong card or does it matter?
    I have a TM 5402
  12. ABARKIE
    ABARKIE Member
    Jan 2, 2010
    654
    28
    +60
    Both can be read in 5402
    I would say viaccess as the entitlements are more easily seen
    • Thanks Thanks x 1
  13. Ghostleader
    Ghostleader Active Member
    Nov 21, 2009
    2,355
    +308
    True, I'm a Irdeto man my self lol:)
    • Thanks Thanks x 1
  14. VJVJ
    VJVJ Member
    Sep 27, 2008
    16
    LOL. So it doesn't really matter? LOL
  15. Ghostleader
    Nov 21, 2009
    2,355
    +308
    If you have a Viaccess card mate you can see your cards expiry date and check on renewals etc, go for the Viaccess card mate.
    • Thanks Thanks x 1
  16. VJVJ
    VJVJ Member
    Sep 27, 2008
    16
    Thanks. Much Appreciated! I love this site, so helpful!
    Edit: I see why you said Viaaccess the card is unavailable at the moment from Tech-Digital. It was for a good price too, £90. Alot of people must've brought it for those same reasons you mentioned.
  17. Ghostleader
    Nov 21, 2009
    2,355
    +308
    See example here mate:
    [​IMG]
    • Thanks Thanks x 1
  18. VJVJ
    VJVJ Member
    Sep 27, 2008
    16
    Thanks! I just brought a card from Tunisat via Ebay! Viaccess!
  19. Ghostleader
    Nov 21, 2009
    2,355
    +308
    Sods law mate, shop around mate, there's still good prices out there.:smashin:
    • Thanks Thanks x 1
  20. Ghostleader
    Nov 21, 2009
    2,355
    +308
    When you get your card it go's in the card reader with the chip in the viewing card facing down mate.:smashin:
    • Thanks Thanks x 1
