Be Box - Getting Wireless N
Discussion in 'ISPs & The Internet' started by aduro, Feb 25, 2011.
  1. aduro
    aduro Member
    Jan 24, 2011
    22
    3
    I was surprised that the Be Box I just got a while ago seems to only support wireless G.
    Would have thought wireless N would be the norm in this age. Any suggestions on a suitable replacement? Or would it be better to run the Be box in bridge mode as a modem?
  2. avinitski
    avinitski Member
    Apr 22, 2005
    3,308
    +222
    can the BeBox run in bridge mode?
    i was struggling getting the BeBox to only work as a modem and use a D-Link DSL-2740R (modem\router) for wireless N and firewall etc
  3. beerhunter
    beerhunter Member
    Nov 9, 2005
    6,335
    +759
    I'm not sure what you mean by "bridge Mode" nor its relevance to the problem at hand.
    You could either switch off the Be box's 802.11g WiFi and then either connect an 802.11n Wireless Access Point to one of its Ethernet ports or replace the router entirely with one that supports 802.11n.
  4. daroca
    daroca Member
    Jan 3, 2005
    47
    +6
    You could purchase a O2 wireless box IV, they come up time to time on ebay, I got one for around £15 a while back.
    It works just fine on BE.
    The wireless box IV has wireless 'N' and two USB ports which support flash disks / usb disks, but I couldn't get a usb printer to work.
