BD60: DVD 4:3 aspect ratio problem?
Discussion in 'Blu-ray & DVD Players' started by EssCeeUK, May 4, 2009.
  1. EssCeeUK
    EssCeeUK Member
    May 6, 2006
    97
    +75
    Hello all,
    I've just bought a BD60 from Richer Sounds and having a problem when it comes to viewing DVD that are in 4:3 aspect ratio.
    I set the BD60 to output HDMI/720p (native resolution of my Panasonic TX32-LXD500) and set TV aspect to 16:9. Inserting a 4:3 disc i.e. ST:TNG Season 1/Disc 1 or X-Files Season 1/Disc 1 results 4:3 back the vertical bars are white instead of black (actually, they are black for about a second then go white). I've performed a FW update to the latest version (1.5) and the issue remains. The problem is also present on a Sony KDL-37P3020 with the same effect (setting player to both 720p and 1080i). Seeing as my old Pioneer DVD player would output 4:3 with black bars ok it's either a firmware issue or faulty unit.
    [​IMG]
    Secondly, when play a BD disc the player is silent. Playing a DVD (i've tried 3 separate discs) have a high pitched whine/whistle while spinning. Anyone else noticed?
    Looking forward to your comments and suggestions. :lease:
    Simon.
  2. alsina
    alsina Active Member
    Nov 30, 2008
    3,796
    +620
    As regards the grey side panels, this is either being done by the tv or more likely by the 'Screensaver' being set to 'On' in the 'Display Menu' on the Blu-ray player.
    • Thanks Thanks x 1
  3. kingfats
    kingfats Well-Known Member
    Dec 29, 2006
    36,477
    +7,844
    Yeah :thumbsup: Screensaver OFF then your sorted. :)
    • Thanks Thanks x 1
  4. EssCeeUK
    EssCeeUK Member
    May 6, 2006
    97
    +75
    To both kingfats and alsina, you were right on the money with the screensaver option.
    Turned it off and no more white bars :clap:
    Cheers guys,
    Simon.
  5. norfred
    norfred Member
    May 2, 2004
    289
    +9
    I suppose it is quite safe to do this if the tv is an LCD screen?
    norfred
  6. simonblue
    simonblue Active Member
    Jan 29, 2006
    10,855
    +1,647
    Hi yep your ok on an LCD screen,even plamas have got better,about burn in :)
  7. kingfats
    Dec 29, 2006
    36,477
    +7,844
    Totally safe. :smashin:
