B&W M-1 Wall Mounted ?
Discussion in 'Speakers' started by rob shaw, Oct 3, 2006.
  1. rob shaw
    rob shaw Member
    Sep 18, 2006
    19
    3
    Can the centre speaker be wall mounted on its side ? if so does it come with the bracket ?? :lease:
  2. Altezza
    Altezza Member
    May 23, 2005
    17
    Yes, I have it wall mounted on it's side, it is supplied with a bracket
  3. rob shaw
    rob shaw Member
    Sep 18, 2006
    19
    3
    do you or does anyone else out there have any pics of the M-1's wall mounted in theyre own installs ???
    I would really like to see them relative to a Plasma !!!
    I'm worried they might look a bit big over/under my plasma :lease:
  4. James Fortune
    James Fortune Member
    May 31, 2009
    68
    Hear! Hear! Did you get any response?
  5. Mr. Wilby
    Mr. Wilby Member
    Dec 15, 2002
    636
    +16
  6. James Fortune
    May 31, 2009
    68
    Very nice.
    I'm getting the Pioneer PDPLX5090 also.
    What do you think of the B&W M1s? Are they part of the B&W MT-25/30 set up?
  7. Mr. Wilby
    Mr. Wilby Member
    Dec 15, 2002
    636
    +16
    Ta. I'm very happy with them. They are surprisingly loud for such small speakers and suit my lounge quite well. I currently just have three at the front and purchased some FPM's for the rears but we're selling our house at the moment so I likely won't fit the rears now.
    That said, we'll definitely be taking the M1's along with us after we move house. In fact, we liked them so much we bought a set of 5 for use in our home cinema room (for 4 rears, with 1 spare). Personally, I think they're great, but because I live in Finland it's rather hard to find alternatives to compare them with... so there could be better choices in the size/price bracket, but I couldn't demo them here.
  8. TGjn
    TGjn Member
    Dec 8, 2009
    43
    Will the Alphason SS20-S speaker stands be good for the B&W MT-25 at the rear and possibly at the front?
    Online Store - Audio T
  9. markdj79
    markdj79 Member
    Nov 8, 2009
    359
    28
    +33
    i have all my m1's wall mounted, the centre is really easy to mount, you can turn the wall bracket sideways and it will not be seen behind the speaker when viewed from the front, but i have my bracket upright, so it looks like its growing from the bottom of the tv
    im very happy with mine, like has already been stated, they are a very loud little speaker, however they do sound smooth and refined with plenty of detail
    im not allowed anything bigger so im thankful that they are as good as they are:smashin:
    you wont regret using them
    mark
  10. TGjn
    TGjn Member
    Dec 8, 2009
    43
    cool, I have booked a demo over the xmas period so looking forward to it.
    I wont be able to mount mine the way my living room (my main sofa is in a bay window) is setup plus I have my TV sitting on the stand.
    I have also seen the stands that B&W have on their wesbsite but this must cost £££...
  11. markdj79
    markdj79 Member
    Nov 8, 2009
    359
    28
    +33
    yes i think the stands do cost a premium
    im not sure if you can buy 3rd party ones either
    also, wiring them up is strange,
    the actual wires attach to the bracket or the stand, you cant wire up the speaker like normal as there are no binding posts on the speakers, just little screws inside the bracket, its the same with the little stands that come with them so i assume its the same with the tall stands
    try and have a good look at them in the shop, you will see what i mean
    top speakers tho
    good luck mate
    mark
  12. IL Cattivo
    IL Cattivo Active Member
    Jan 29, 2007
    2,420
    +259
    Can any of you guys please tell me what Wall Mounting speaker brackets you used for these B&W M1's and do the small stands that come with them come off easily?
    :smashin:
  13. bluedroog
    bluedroog Active Member
    Nov 16, 2009
    2,218
    +410
    Has anyone a comparison of the M1's vs. an 'average' book shelf speaker? I like many do in their set ups have an old redundant pair of speakers used as rears, in my case a pair of Mission speakers which must be approaching 20 years old now.
    I'm not expecting the M1's to be an upgrade as such but would like to think they would not result in any reduction in performance. The swap would be purely aesthetic. I reckon at some point I'll try a 7.1 set-up with 4 of these in white across the back.
  14. markdj79
    markdj79 Member
    Nov 8, 2009
    359
    28
    +33
    the m1's come with a wall bracket in the box, its a really easy task to change from the chrome bookshelf stands, plus its really easy to attach the brackets to the wall
    its a small metal bracket, which a plastic (colour dependant) cover clips onto
    good luck
    mark
