AVForums Squeezebox Touch discussion thread Pt.II
Discussion in 'Streamers & Network Music Players' started by amcluesent, Mar 19, 2011.
Thread Status:
Not open for further replies.
  1. Crocodile
    Crocodile Well-Known Member
    Nov 4, 2002
    12,321
    +2,418
    Put it this way, if in the last few years you had been given a Boom, Duet, Radio (with battery) & a Touch all for free & were in line to receive any future products also free, would you squeal? :D
    I'm curious as to what benefit USB out could offer?
  2. amcluesent
    amcluesent Moderator
    Aug 13, 2002
    4,616
    +812
  3. formbypc
    formbypc Member
    Oct 9, 2010
    1,577
    63
    +103
    From original setup, SB Touch connected wirelessly to my network, found music folder on PC, and played music from folders without issue.
    I tried an SD card with music files, and had to start SB server on the touch itself to read the SD card. This worked fine, so I ejected the SD card and tried to read from the PC folder again. No matter what I do, it won't find the folder or PC.
    It connects to my network, plays internet radio without problem, but won't find the music folder
    SB Server is running on the PC. I've restarted the PC, and also used the Restore Factory Settings on the SB Touch, to no avail
    Any ideas before I contact Logitech Tech Support?
  4. Crocodile
    Nov 4, 2002
    12,321
    +2,418
    I don't use the inbuilt server but isn't there an option in the menus to switch library or similar? I'm pretty sure it won't auto-switch back to SBS just by ejecting the SD card.
    Edit
    Home menu > My Music > Switch Library?
  5. formbypc
    formbypc Member
    Oct 9, 2010
    1,577
    63
    +103
    Tried that. It leads to a screen that says, roughly;
    "To access My Music, ensure that SB Server is running on a PC on the network"
    Which it is.....
  6. Crocodile
    Nov 4, 2002
    12,321
    +2,418
    Maybe temporarily disable any firewall & anti-virus on the server PC in case an update had blocked the required ports.
    Do you have another PC/web enabled device that can access SBS via it's web interface?
  7. formbypc
    formbypc Member
    Oct 9, 2010
    1,577
    63
    +103
    Sorted.
    Re-boot PC, re-boot wireless router, and back to normal again.....
    Ain't technology great?
  8. osullivj35
    osullivj35 Member
    Jan 8, 2003
    5
    I am looking at getting a wi-fi radio that can play my files on my external HD. It looks like the squeezebox touch might be the one to go for.
    I am a bit concerned about the external HD, have people had much trouble connecting to it. I have a variety of files not just mp3's on the HDD
    J
  9. amcluesent
    Aug 13, 2002
    4,616
    +812
  10. castalla
    castalla Member
    Dec 26, 2010
    350
    28
    +26
    I've searched and googled ... no defintive answers ...
    Is it possible to Play ALL albums via the Touch - or must each album be added to a playlist?
  11. nacmacfeegle
    nacmacfeegle Active Member
    May 1, 2008
    3,076
    +832
    "You certainly need a powered-caddy for the drive"
    This is certainly true if you want to avoid any risk of things not playing nice, but I've had success with a variety of USB powered drives (Toshiba and WD amongst others), and am currently using a cheapo generic 2.5" USB powered caddy, which even came with a separate USB power adaptor cable (implying that it needs two USB ports to drive it). FWIW I recall it was a 'Star Tech' caddy from t'bay.
    This is probably down to good fortune rather than any 'engineering' on my part, to be honest.:cool:
    Castalla..
    "Is it possible to Play ALL albums via the Touch" Yep, I'm pretty sure it is, all albums in the collection or by specific artist, I'd need to check the actual mechanisms involved. Method of selecting this may also vary depending on whether you are using a local Touch Sever or an external server, its deffo possible using a plugin running on an external server.
  12. Ben Jammin
    Ben Jammin Member
    Jun 23, 2008
    1,264
    63
    +127
    OMG i am an idiot!!! My gf just picked up the remote and pressed 5 to skip to artists beginning with letter J. I had no idea you could do that! Been scrolling through entire music collection like an IDIOT. lol!
  13. Peter Galbavy
    Peter Galbavy Guest
    But note that once you have hundreds of artists/albums etc. then some buttons will do nothing or skip over letters (like an old phone, press a key multiple times to scroll through the letters on the label) until the Touch has cached the names.
    Also, the buttons do not work in all modes and at all levels. You cannot, for example, select an artist and then select a specific album with the keys. Or was that specific track? I forget.
  14. MI55ION
    MI55ION Active Member
    Nov 8, 2005
    5,505
    +572
    Well not sure if it would even work this way but I have a USB Asynchronous DAC and I want something like a SB unit to stream music into it.. The main question that come to mind and something I require confirmation on is whether such a device would be compatible with the asynch protocol. As for benefit, well I believe I have found the holy grail of digital interface with USB Asynch and my DAC. Sure I could continue to use foobar2000/asio4all Along with a laptop but the user interface and ipad/phone apps are not as user friendly as ipeng/SB remote.
  15. amcluesent
    Aug 13, 2002
    4,616
    +812
    >Well not sure if it would even work this way but I have a USB Asynchronous DAC and I want something like a SB unit to stream music into it.<
    See the link in post #122
    IIRC the Stereophile article on using the Touch USB as output was to an QB-9 Ayre DAC which is aync.
    • Thanks Thanks x 1
  16. MI55ION
    Nov 8, 2005
    5,505
    +572
    I must have missed it, cheers.
    It's a long thread, I'll read the lot and then decide if the touch is worth buying.
  17. Magic Beans
    Magic Beans Member
    Jun 25, 2008
    1,137
    48
    +49
    I've been doing some reading recently and it would seem that the way to SBT audio nirvana is to output via USB, into an asynchronous HD DAC.
    Has anybody tried this and done some comparisons?
    I'm impressed with the SBT so far and have performed all the software tweaks, with noticeable improvements. However i'm considering the next step and an external DAC seems to be the way forward (currently coax out into the AV9). Although it's deciding the best direction to go; good legacy DAC (DAC64 etc) and moderate modern HD capable DAC (rDAC etc)?
  18. redmarkred
    redmarkred Member
    Jan 25, 2006
    1,199
    +78
    Before I go and purchase a Squeezebox Touch can someone confirm 2 things for me:
    1. That I can use Spotify though the Touch without having to have my PC on.
    2. That I can stream internet radio through the Touch without having my PC on.
    Many thanks :)
  19. Crocodile
    Nov 4, 2002
    12,321
    +2,418
    Yes (Premium only) & yes.
    • Thanks Thanks x 1
  20. formbypc
    formbypc Member
    Oct 9, 2010
    1,577
    63
    +103
    Used the SB Touch a few days ago to play back from Music Folder, finished doing so, and put it into Standby.
    Returned a few days later and wanted to listen to Internet Radio - this had disappeared from menu(s) - spent a frustrating 5 mins going around every menu, it was nowhere to be found, so did a Factory Reset, and on restart, Internet Radio was back!
    Anyone had the same experience?
  21. redmarkred
    redmarkred Member
    Jan 25, 2006
    1,199
    +78
    Amazon have the Squeezebox Touch back in stock for £204.99! :)
  22. UrbanBumpkin
    UrbanBumpkin Member
    Feb 3, 2010
    67
    Pixmania have the Squeezebox Touch on for £187 delivered.
  23. recruit
    recruit Guest
    Hi Chaps, not sure if this has been asked before but I have a WD My Book World Edition, the original ethernet version, now can I use that with the SBT similar to using it like NAS, I have about 500gig of music on there and would like to use it if possible but can purchase something else if I really have to?
  24. fullerms
    fullerms Member
    Oct 31, 2008
    76
    You would need a squeezebox server. Not sure if your WD can run it. If it cannot, either upgrade to a NAS which can run squeezebox server or buy a plug computer and run squeezebox server on it.
    Lookup sheevaplug or Tonido plug on Google.
  25. formbypc
    formbypc Member
    Oct 9, 2010
    1,577
    63
    +103
    Same symptoms again in the last day or so. Internet Radio option disappeared from Home Menu, and restored to it by a factory reset ...
  26. redmarkred
    redmarkred Member
    Jan 25, 2006
    1,199
    +78
    I have just got my Squeezebox touch! Very pleased with it so far. :)
    Can anyone answer some questions concerning the Spotify App.
    1. Sometimes the Spotify app seems to be unable to retrieve my Spotify playlists and comes up with a timeout message quite quickly. Is there a setting where you can change how quickly it times out?
    2. Is there any way to add tracks to your Spotify playlists on the Touch. You only seem to be able to add a track to your favourites!!!!
  27. cloudnine
    cloudnine Member
    Oct 29, 2010
    211
    +20
    My squeezybox is coming next week and am after a compatible USB harddrive.. im sure ive seen a link to devices but now can't find it... Any recommendations of drive or link to list?? Thanks
  28. nacmacfeegle
    May 1, 2008
    3,076
    +832
    Squeezebox Touch - USB Compatibility - SqueezeboxWiki
    • Thanks Thanks x 1
  29. cloudnine
    cloudnine Member
    Oct 29, 2010
    211
    +20
    Thanks.. just arrived unexpectedly and took me about 10mins from getting it out of the box to connecting it to my amp, getting a usb stick in it and getting it playing. It must be some kind of record for me. Im just about to re-rip my cd collection from scratch and was unsure whether to put it all on my laptop then onto a usb HDD or whether to get one of these.. 1Tb Music Server CD/DVD rip - Squeezebox Sonos & DLNA on eBay (end time 10-Jul-11 17:39:58 BST)
  30. fullerms
    fullerms Member
    Oct 31, 2008
    76
    Go for the music server. Though the squeezebox touch works with a usb drive, it's a real PITA to use it that way.
Thread Status:
