AVForums Squeezebox Touch discussion thread Pt.II
Discussion in 'Streamers & Network Music Players' started by amcluesent, Mar 19, 2011.
Thread Status:
Not open for further replies.
  1. larkone
    larkone Active Member
    Apr 21, 2006
    2,473
    83
    +362
  2. Crocodile
    Crocodile Well-Known Member
    Nov 4, 2002
    12,776
    +2,632
    Now I'm really confused. I don't see that in 7.6.2 or 7.7.2. :confused:
    You are looking at the web interface for LMS (server IP address:9000)?
    I also saw the thread that Larkone has linked to but presumably you don't have the error messages? All the same, a restart of both server & router wouldn't hurt.
  3. BobbyMac
    BobbyMac Active Member
    Aug 26, 2011
    3,982
    +310
    Re-installed LMS & re-booted my router and jobs a goodun, cheers lads :smashin:
  4. redmarkred
    redmarkred Member
    Jan 25, 2006
    1,212
    +82
    Right the good news is that my re-buffering issue appears to be fixed.
    My ethernet cable arrived so I tried the Touch wired. However within 5 minutes the Touch experienced a re-buffering episode. So the problem wasn't to do with the Touch being wireless.
    Next I decided to try the ethernet cable between my router and server in order to eliminate the homeplugs (and went back to having the Touch wireless). This seems to have solved the problem. I haven't had a single re-buffering incident since.
    Clearly the homeplugs were dropping the connection occasionally (mainly in the evening). It's strange however that the SB Radios upstairs were never affected. Could this be due to them being on a seperate electrical circuit?
    Anyway the problem now seems fixed so thanks for everyones advice. :)
  5. larkone
    Apr 21, 2006
    2,473
    83
    +362
    Glad you sorted it. If you wanted to use the homeplugs again it is worth checking what could be on the same circuit that is causing them a problem. I had a similar issue with homeplugs being on the same circuit as my boiler and that killed the the throughput when the boiler came on. Solved by moving them around.
    • Thanks Thanks x 1
  6. redmarkred
    redmarkred Member
    Jan 25, 2006
    1,212
    +82
    I wouldn't mind picking up another Touch but they seem to be out of stock at most places. Does anyone know where I can pick one up?
  7. BobbyMac
    Aug 26, 2011
    3,982
    +310
    Unfortunately EBay is your cheapest bet these days :blush:
  8. BobbyMac
    Aug 26, 2011
    3,982
    +310
    Just got a notification to update the FW on my touch to 7.7.3 r16662, any change logs floating about?
  9. amcluesent
    amcluesent Moderator
    Aug 13, 2002
    4,794
    +891
  10. mip.palmer
    mip.palmer Member
    Mar 24, 2006
    151
    28
    +25
    Bought a brand new sealed touch at PC World for £89.91 today. Info on HUKD. Radio also available at £49.91, both limited supply.
    Regards mipmip.
  11. BobbyMac
    Aug 26, 2011
    3,982
    +310
  12. audioenthusiast
    audioenthusiast Active Member
    Feb 21, 2011
    3,803
    +596
  13. redmarkred
    redmarkred Member
    Jan 25, 2006
    1,212
    +82
    Cool! Yeah someone told me about this yesterday and I managed to get one for £89 at my local PC World. What a bargain!!! :thumbsup:
  14. Broosta
    Broosta Member
    Sep 14, 2007
    457
    28
    +32
    FYI as of 11:00 today - Norwich PC World has at least 1 SB Radio but no Touch's (I got the last one), Norwich Currys has 1 Touch not sure if any radios. Lowestoft and Yarmouth have no Touches.
    I just phoned up main sales number and they could tell me stock numbers of any store.
    They are not ex display or shop soiled at all, brand new, sealed with all the plastic stickers all over the shiny bits.:smashin:
    I'm quite excited about my Touch! I have a SB3 and the Touch has been on my hit list for a while but at £89 for a brand new boxed shop item it seems like a bargain not to be missed.
    Otherwise they are about £210 new on ebay, £150ish second hand on ebay, and cheapest place I saw new was amazon at £190.
    Now gonna plug it in and play. Was the best connection method (from player to amp) analog or digital?
    • Thanks Thanks x 1
  15. Intenso
    Intenso Member
    Dec 31, 2004
    271
    +23
    I tried the main number and was told that it was a discontinued line and that was it.
    Any idea if they have any left in Bristol?
    Looking for a Touch
  16. audioenthusiast
    Feb 21, 2011
    3,803
    +596
    What number was that on? I phoned and they couldn't see them on the system at all?
    Depends on how good the DAC is in your amp!
    Going digital uses your amp's DAC, going analogue uses the Touch's DAC.
    • Thanks Thanks x 1
  17. Broosta
    Broosta Member
    Sep 14, 2007
    457
    28
    +32
    Yes they said that to me too but then when you ask if they can search the stores they are able to (if they can be bothered I suppose).
    So I'd just call same number again and you might get somebody who can be bothered, but sorry I only checked locally to me.
  18. Broosta
    Broosta Member
    Sep 14, 2007
    457
    28
    +32
    0844 561 0000
  19. audioenthusiast
    Feb 21, 2011
    3,803
    +596
    Yeah, that's the one I called thanks. I'll try again later and hope to get somebody better.
  20. Intenso
    Intenso Member
    Dec 31, 2004
    271
    +23
    Thanks just tried and they said that there wasn't any stock showing anywhere.
    Think that might be the end of it I'm afraid...
  21. fidgety
    fidgety Member
    Jan 31, 2008
    841
    +49
    Lucky, I spend saturday and sunday driving from store to store for currys, pc world and even sent me yesterday to their enf of line outlet, no touches left.
    They searched their stock system for me and showed none, so either these on the shelves are already out of the system (doubtful), or their searches are flawed.
    If someone can buy one for me I'be most obliged.
  22. redmarkred
    redmarkred Member
    Jan 25, 2006
    1,212
    +82
    Managed to pick up a spare Touch in case my other one ever packs up.
    It's in perfect working order with no marks on the screen. However the bottom strip of plastic/metal (the bit with the Logitech Logo on it) has a couple of long scratches on it. Any advice on how I can repair this without making it look worse. I know it's not a major issue but it's annoying.
    Any advice appreciated, cheers :)
  23. HeadBanger
    HeadBanger Member
    Sep 22, 2000
    1,355
    +157
  24. fidgety
    fidgety Member
    Jan 31, 2008
    841
    +49
    I've been searching high and low for these all around Manchester. If someone can pick one up for me I'll be most grateful.
  25. HeadBanger
    HeadBanger Member
    Sep 22, 2000
    1,355
    +157
    I went to the Southend-on-Sea branch first and they had none. I asked a sales guy if he could search other store's stock and he obliged and logged into their system and searched for manufacturer 'Logitech' and product name 'squeeze'. It brought up a list of the nearest stores that had stock - Basildon was the nearest for me (I think that Lakeside was listed as having the Logitech Radio). I'm sure that if you find a friendly salesperson at your local Currys/PC World they'll do the same for you too.
    • Thanks Thanks x 1
  26. amcluesent
    Aug 13, 2002
    4,794
    +891
Thread Status:
