AVForums Squeezebox Touch discussion thread Pt.II
Discussion in 'Streamers & Network Music Players' started by amcluesent, Mar 19, 2011.
Thread Status:
Not open for further replies.
  1. stuart2
    stuart2 Member
    Feb 24, 2006
    335
    +15
    So just how good is the Squeezebox? I am not talking iPod/MP3 good here. I am talking true HiFi. I know it can stream FLAC files. Logitech just states that it can have a USB drive connected to it to play FLAC files and nothing more. Does anyone else remember the anologue versus digital arguments when CD came out? I am talking true HiFi quality here.
    CD recordings have a limitation of 44.1Khz / 16bit but can be improved by playing through a DAC with higher capabilities. I would be using the optical output to my Denon AVR-4306, which has 192Khz / 24bit capability. If I connected an iPod to this I would get a reasonable sound, but it would not be HiFi. Is that just down to the compression or are the components of the Squeezebox also good enough for it to be HiFi?
  2. Strocky
    Strocky New Member
    Dec 4, 2006
    1,227
    +72
    The touch WILL output digital and analogue at the same time :smashin:
  3. Strocky
    Strocky New Member
    Dec 4, 2006
    1,227
    +72
  4. Strocky
    Strocky New Member
    Dec 4, 2006
    1,227
    +72
    General consensus is you'll need to spend £300+ on a DAC to better the Touch DAC :smashin:
  5. amcluesent
    amcluesent Moderator
    Aug 13, 2002
    4,842
    +922
    >or are the components of the Squeezebox also good enough for it to be HiFi? <
    Certainly the Touch is good enough for hi-fi.
  6. stuart2
    stuart2 Member
    Feb 24, 2006
    335
    +15
    Thanks for the replies. Can you use the HDMI output to display a playlist on your TV in the same way as it is displayed on the Touch's screen?
  7. amcluesent
    Aug 13, 2002
    4,842
    +922
    There is no HDMI output on the Touch
  8. Strocky
    Strocky New Member
    Dec 4, 2006
    1,227
    +72
    Anyone got a link for the online tagging service that was mentioned on here? :smashin:
  9. SirStan
    SirStan Member
    Nov 12, 2008
    28
    +6
    Hi all ... a quick question if I may:
    Can I interchange the PSUs between a Touch and an SB2?
  10. Crocodile
    Crocodile Well-Known Member
    Nov 4, 2002
    12,796
    +2,734
    Kind of.
    They're the same voltage but different current ratings. The Touch is higher (presumably because of the colour screen & USB power requirements. So you can use the Touch PSU with SB2 no problem but the Touch may struggle with the SB2 PSU.
    • Thanks Thanks x 1
  11. coolio107
    coolio107 Member
    Dec 18, 2008
    542
    28
    +92
    I've been using the Touch with an SB3 PSU for several months (without using USB/SD card). It worked fine, probably because I never needed the power for the external devices and the server.
    • Thanks Thanks x 1
  12. stuart2
    stuart2 Member
    Feb 24, 2006
    335
    +15
    Thanks. Logitech's website is not very helpful. I have just checked on Amazon and they have a photo of the ports on the back of the Touch. I thought you could stream youtube, etc. with the Squeezebox Touch.
  13. JSW
    JSW Active Member
    Feb 21, 2002
    4,212
    +297
    Downloaded and installed 7.5.4_R9394 but when restarts it keeps asking to update to 7.5.3
    How can I stop it asking as I cant get round it and 7.5.3 album art is broken :confused:
  14. JSW
    JSW Active Member
    Feb 21, 2002
    4,212
    +297
    Found it, swipe right :suicide:
  15. robfitzp
    robfitzp Member
    Dec 12, 2002
    1,162
    38
    +21
  16. judethedude
    judethedude Member
    Oct 6, 2005
    2,217
    +82
    I currently use a Duet receiver and iPeng on my iPhone 4 to control music in two different zones. I'm considering purchasing a Touch to replace the Duet receiver but have a couple of quick questions :
    1. Is there a significant sound improvement between the Duet receiver and the Touch ?
    2. Will the Touch screen update and show tracks/artwork selected using iPeng (via the iPhone) ?
    Thank you :thumbsup:
  17. amcluesent
    Aug 13, 2002
    4,842
    +922
    1. Noticable improvement, so long as partnering equipment is decent. Of course, hi-rez playback is possible on the Touch.
    2. Yes.
    • Thanks Thanks x 1
  18. judethedude
    judethedude Member
    Oct 6, 2005
    2,217
    +82
    Thanks for the info Amcluesent :smashin:
    However, my cunning plan to buy a Touch from the Logitech "Special Offers" at £159 has now been somewhat thwarted as it's been removed from the "offers" :facepalm: It was there last night :rolleyes:
  19. mr_yogi
    mr_yogi Member
    Sep 12, 2003
    1,542
    +148
    Misco were doing for a similar price, I not sure if they still are.
  20. judethedude
    judethedude Member
    Oct 6, 2005
    2,217
    +82
    Bought Touch from Dixons as works out at about £161 with code and Quidco :smashin:
  21. grimmers
    grimmers Member
    Aug 18, 2006
    3
    just bought a buffalo link station live nas to go with my touch, the touch shows it there in my folder along with my other hard drives on my computer. the touch will access the hard drives and play the albums on them, but will not access the nas. any ideas anyone please?
  22. mr_yogi
    mr_yogi Member
    Sep 12, 2003
    1,542
    +148
    Does the link station run the Squeezebox Server software?
  23. grimmers
    grimmers Member
    Aug 18, 2006
    3
    no it does not unfortuantly,but the linkstation shows up in the folder displayed on the touch, but will not open to play the albums on the linkstation.thanks
  24. Crocodile
    Nov 4, 2002
    12,796
    +2,734
    Not really understanding your setup but try creating a shortcut to the NAS & placing that in your default library folder. Then do a full rescan in SBS.
  25. gazzerr
    gazzerr Member
    Aug 29, 2001
    179
    16
    Can anyone help me with a few questions
    Do you need the PC on to listen to internet radio
    Can you listen to the BBC overseas
    Lastly anyone know if it works in Syria as the Logitech website is blocked, I think by Logitech due to sanctions
    Thanks for your help.
  26. amcluesent
    Aug 13, 2002
    4,842
    +922
    Without a PC, it works best if you have access to
    Code:
    http://mysqueezebox.com
    Is that also blocked?
  27. gazzerr
    gazzerr Member
    Aug 29, 2001
    179
    16
    No its blocked as well. Will it not work without that?
  28. happynow
    happynow Member
    Jun 14, 2004
    152
    +10
    I have installed latest sbs update twice now and it loses all my tracks in my library and can't find them. I did a system restore and all is well. Reinstalled update again and it does the same.
  29. amcluesent
    Aug 13, 2002
    4,842
    +922
    >Will it not work without that?<
    Hmm, the 1st thing a new Touch does is attempt to 'call home' to update it's software. Not sure how easy it is to work around that.
    Assuming you can, and have access to a PC, you can d/l the iPlayer app for the Touch which gives you the BBC services and doesn't need a PC running or connection to mysqueezebox.com.
    • Thanks Thanks x 1
  30. happynow
    happynow Member
    Jun 14, 2004
    152
    +10
    The scanner just won't find anything. I even changed library to a new folder with 1 album in it and it still doesn't find any music. Any suggestions? I have looked in the Squeezebox server forum but couldn't find any answers.
Thread Status:
