AVForums Sonos Play:5/Play:3/Play:1 Discussion
Discussion in 'Streamers & Network Music Players' started by GarryPearson, Oct 13, 2009.
  1. codex70
    codex70 Member
    Oct 1, 2009
    89
    +4
    Just tried it on my S5. If I put my ear to the speaker with my iphone right sat next to the s5, I can just about hear a faint hiss. This is whether or not music is playing (ie playing, but with vol at nothing). The hiss is so quiet though that even a couple of inches from the speaker I can no longer hear it (though whether you have more sensitive hearing or not, I 'm not sure).
    I really wouldn't be able to hear it under normal circumstances, so if you can, then it's definitely different to mine.
    • Thanks Thanks x 1
  2. ro53ben
    ro53ben Member
    May 2, 2006
    1,201
    +142
    yes, it's a faulty unit - you should return it for a replacement.
    • Thanks Thanks x 1
  3. mabayes
    mabayes Member
    Dec 7, 2010
    2
    Hi, I am looking at getting a Sonos Zoneplayer, but where I intend to use it I have NO router and NO PC - just an iPhone - is it the product for me ? or would the Bose dock be a better option ?
  4. deeno65
    deeno65 Member
    Sep 19, 2008
    1,992
    +48
    to get the best out of this, you need a connection to a router,hard wired will work but a wireless one will talk to your iphone.you also need a broadband connection to stream music from the net .my advice to you is visit a local supplier and ask for a demo,on what you need and a hands on explanation thanks
  5. amcluesent
    amcluesent Moderator
    Aug 13, 2002
    4,886
    +961
    > is it the product for me <
    Do you mean no internet access at all?
    Without either a local music server or streaming music off the interweb, the S5 would be 99% wasted.
    >would the Bose dock be a better option<
    B&W Zeppelin is the dock of choice.
  6. ro53ben
    ro53ben Member
    May 2, 2006
    1,201
    +142
    Yes, you can use an S5 without a router or PC. If you have just the S5, you'll need to connect the iPhone to the line-in socket on the S5 using 3.5mm jack plugs. All music will need to be controlled manually on the iPhone.
    Alternatively, you can purchase the Sonos Wireless Dock with the S5 which will allow you to stream wirelessly from the dock to the S5 and also use any Sonos controller to remotely control the music playback.
    If you have music services, like Spotify, on your iPhone - you can play these through the S5 directly or via the wireless dock.
    Personally, I'd choose the Sonos option over the S5 as it's more expandable in the future - e.g. you can add a 2nd S5 to an adjacent room and play the same music in both.
  7. Member 410254
    Member 410254 Member
    Oct 7, 2009
    832
    46
    +106
    You don't need to have the router in the vicinity, i would advise simply buying a Sonos Zonebridge and hard wire that to your router (Wherever it is in your house) and let that talk to your S5. You won't appreciate any of the Sonos features without access to the internet and would be well worthwhile paying £79 for the Zonebridge.
    I would suggest the new Arcam rCube
    Kind regards
    Phil @ Custom Cable
  8. Harpo8
    Harpo8 Member
    May 3, 2010
    43
    Been reading about the Sonos setups for a while now and after watching the demo, i thought to myself, there is no way they will setup that quick (10mins) and sound as good as everyone has said - I was proven wrong! :smashin: :smashin:
    I went over to bluewater at the weekend and bought the S5 and Zonebridge bundle for £349.99, seemed the best deal about that I could find. Took less than 10minutes to setup and I was away.
    I now plan to purchase 1 or 2 Zoneplayers/amp when we move into our new home.
    Very impressed
  9. Dan.Scott1234
    Dan.Scott1234 Member
    Nov 17, 2005
    1,288
    41
    +19
    There's a great CR200 for sale in the Classifieds here (Shameless plug for my own sale thread:oops:)
    Sonos setup is first class though, really couldn't be easier. When you get your second zone and see how easy it is to join them and play different things in different rooms you'll get that big smile again too!
  10. disney_cjd
    disney_cjd Member
    Jun 20, 2007
    545
    +15
    They are v easy indeed. Even run mine of a ReadyNAS and its a breeze. Keep an eye on BestBuy as I got mine from there and often they have a 20% cashback via quidco so you are quids in!
  11. davisa
    davisa Member
    Dec 10, 2002
    395
    +24
    Just got a ZoneBridge, ZP90 and Sonos Dock. Took less than 10 minutes to set up. iTunes on the other hand took three days to successfully make the move from local hard drive to NAS.
  12. CallMeSteve
    CallMeSteve New Member
    Feb 13, 2008
    3,594
    +153
    I've been thinking of getting a Sonos S5 and the cheapest I've seen for the kit with the zone bridge is £360 at Comet. Anybody seen anything cheaper?
  13. Harpo8
    Harpo8 Member
    May 3, 2010
    43
    Carphone warehouse is 349.99 in store only and you will need to ring around. I got the last one at Bluewater. Maidstone/london (city), chatham, gillingham were all sold out too. Good luck :smashin:
  14. Jazz Monkey Jr
    Jazz Monkey Jr Active Member
    Jan 10, 2005
    10,485
    +678
    Call your local dealer that's on the sonos website, they will always knock at least £20 off
  15. CallMeSteve
    Feb 13, 2008
    3,594
    +153
    Tried them already but none of the local stores have it in stock.
    The retail price is £399 so even if they knock off £20, it's still more than £360! :)
  16. Jazz Monkey Jr
    Jan 10, 2005
    10,485
    +678
    It's always worth trying your local dealer.
  17. gillw
    gillw Member
    Jul 11, 2003
    116
    +6
    Any updates on Sonos deals would be welcome. :thumbsup:
    I'm thinking of buying the S5 starter bundle (inc bridge). Amazon have it for £388 and in recent months have given a further 10% off Sonos products. I'm just waiting to see if they offer this again in Feb.
  18. Jazz Monkey Jr
    Jan 10, 2005
    10,485
    +678
    Again ring all local dealers from the sonos site, other than that, best buy is your best bet when they have the special offer days.
  19. Harpo8
    Harpo8 Member
    May 3, 2010
    43
  20. metroman2
    metroman2 Member
    Apr 14, 2005
    130
    +14
    I have ordered 2 x S5's @ £329:95 each but not with the bridge as I did not need it, from Richer Sounds milton keynes + a ZP90 and the latest controller...roll on Thursday :thumbsup:
  21. davisa
    davisa Member
    Dec 10, 2002
    395
    +24
  22. Jazz Monkey Jr
    Jan 10, 2005
    10,485
    +678
  23. gillw
    gillw Member
    Jul 11, 2003
    116
    +6
  24. davisa
    davisa Member
    Dec 10, 2002
    395
    +24
  25. Beancounter
    Beancounter Member
    Aug 22, 2004
    1,661
    +45
    I currrently have a Pure Avanti in my dining room but am considering a Sonos S5.
    I just want peoples views on sound quality. Will it be good enough for a 10ft by 10ft room and will the difference in quality be really noticeable over the Avanti.
    Just trying to get some ammo to help persuade the wife to spend £379!
  26. ro53ben
    ro53ben Member
    May 2, 2006
    1,201
    +142
    Never heard the Avanti, but it will easily fill that room with sound.
    Being an all-in-one, the only challenge is stereo separation. Like other units of this form factor, you don't really get a lot. The S5 does offer the option of pairing it up with another unit, which sounds quite amazing, but does double the price.
    On it's own, it's better sound quality than a Bose Sounddock, Klipsch or other similar iPod dock style units - it's excellent value for the price.
    • Thanks Thanks x 1
  27. Beancounter
    Beancounter Member
    Aug 22, 2004
    1,661
    +45
    My only reservation is that I would be using my iPhone to control the unit. If my wife is at home whilst I am out the S5 is pretty much uncontrolable without the iPhone or the Sonos controller yes?
  28. ticmon
    ticmon Member
    Feb 3, 2006
    99
    You can download the Sonos desktop controller to use on a PC/Laptop so you can use it without your iphone or the CR200.
    • Thanks Thanks x 1
  29. eyeballKid
    eyeballKid Member
    Jun 4, 2005
    570
    +55
    Other options/things to consider: Sonos zoneplayers do come in different configurations - a ZP120 and a set of bookshelf speakers might be the Sonos unit to consider for a larger room, although this will add to the budget. And you will still need to consider what you need in terms of controllers and music sources (eg. NAS full of music plus a backup, Napster/Spotify streaming service).
    • Thanks Thanks x 1
  30. HMHB
    HMHB Well-Known Member
    Nov 11, 2001
    24,155
    +2,431
    It's also worth mentioning that you'll need your own wireless network for the iPhone to work as a controller in a Sonos system. The bespoke Sonos controllers don't require this as they use the Sonos network to communicate.
    • Thanks Thanks x 1
