AVForums exclusive hands-on with the new JVC Projectors
Discussion in 'News' started by Phil Hinton, Oct 6, 2011.
  1. Rickyj @ Kalibrate
    Rickyj @ Kalibrate Active Member Assured Advertiser
    Jan 29, 2003
    4,955
    +1,014
    The official dealer launch event is next week. It appears JVC had reported possible prices to some dealers earlier than this, and it seems that told one/more dealers that they could release the information on Tuesday, probably while Steve was in the interview (Steve does not set prices), so he was probably unaware. Officially though though prices are still to be confirmed at the dealer launch next week...
    • Thanks Thanks x 1
  2. lovingdvd
    lovingdvd Member
    Mar 21, 2003
    153
    +12
    Phil,
    Thanks for the great info! Glad to read about the improved motion handling the X70. You mentioned that it is the best you have seen in DILA. Does that include Sony's VW series projectors as well? I know they use SXRD but I think technically they are the same - so just wanted to find out from you.
    There is a lot of talk that Sony's motion handling like what is in the VW90 is the best. How do you think the X70 compares?
    Also is it safe to say that the red fringing on horizontal scrolling text (and also what you could see in between the black and white lines on a referee's jersey) like what we had with the RS20 is complete gone?
  3. IWC Dopplel
    IWC Dopplel Active Member
    Sep 11, 2008
    3,625
    103
    +348
    I am very inetrested in just how much better the motion is and 2D performance, the X70 sounds very ineteresting :)
  4. Steve Withers
    Steve Withers Assistant Editor
    Oct 18, 2009
    4,943
    +1,882
    I thought the X70 had the best motion handling I'd seem outside of a DLP projector and that includes the VW90, which also has terrible 3D.
    I've got an X3 and I've never seen any of the artefacts you refer to, can you be more specific?
  5. Manni01
    Manni01 Member
    Sep 4, 2008
    937
    46
    +239
    Ric, that fringing is gone on the x7, so it's likely to be gone for good. This is why Steve can't see it on the X3.
  6. eiren
    eiren Well-Known Member
    Oct 12, 2007
    10,621
    +2,533
    So it is it time to upgrade my HD950? Is it that much better? When/where can I see one?
  7. rigman
    rigman Active Member
    Dec 14, 2000
    2,678
    83
    +14
    You can see them at the home entertainment show in Manchester on 22/23rd October.
    • Thanks Thanks x 1
  8. mikeaitch
    mikeaitch Member
    Apr 21, 2001
    1,583
    +57
    Steve
    Isn't the JVC also dobling the pixels electronically as well as mechanically, so that the pixel count rises to 4K overall? that's how I read it
  9. Steve Withers
    Oct 18, 2009
    4,943
    +1,882
    Possibly Mike, that would take the resolution up to 3840 x 2160, not quite 4K but close. I'd love to take a look at an e-shift technical paper or at least a more detailed explanation than the one provided by JVC, just so I can fully understand what's going on.
  10. Wilt
    Wilt Active Member
    May 13, 2004
    998
    28
    +31
    JVC make great projectors but make unreliable bulbs. Yet again I'm having to run my HD1 in high lamp mode to sort out the flicker which starts to happen after 800hrs.
    There's also the issue with severe dimming after a few hours of use which many have been experiencing.
    Hopefully they've made improvements in this area with the new line.
  11. Smurfin
    Smurfin Active Member
    Aug 13, 2002
    17,343
    +1,745
    Is this a historical issue across all of their ranges?
  12. Steve Withers
    Oct 18, 2009
    4,943
    +1,882
    I have to say I put over 1,000 hours on my HD100 and aside from the normal reduction in brightness that you would expect from a bulb, I never had any problems.
    I've now put nearly 400 hours on my X3 and once again I haven't had any problems and the image is still quite bright.
  13. charker
    charker Member
    Aug 4, 2002
    393
    +21
    My HD1 bulb was exactly the same, flickering from 900 hours and had to turn on high lamp mode. Finally blew at 1800 hours
    When I first put in the new bulb it was amazingly bright. After 200 hours it is back to what I had got used too
  14. Webmonkey
    Webmonkey Member
    Mar 6, 2008
    311
    +8
    does the X3 have any known convergence "issues"?? I saw it demoed shortly about 1 year ago and was impressed by it blacklevel for being a digital (I am coming from CRT).
    But I was disappointed by the lack of brightness in 3D mode and the amount of cross talk - so this new X30 sure is interesting to me. I recently saw the Optoma Hd87 demoed and was impressed by its sharpness and depth in 2D - only thing I did not like was black in night scenes.
  15. Steve Withers
    Oct 18, 2009
    4,943
    +1,882
    The convergence on my X3 is excellent and I have certainly not had any problems with crosstalk, although as some people have pointed out it takes the X3 about 30 minutes to reach optimum performance for 3D. The brightness is also very good and that's after 300 hours. I'm looking forward to directly comparing the new X30 with my X3.
  16. antsims
    antsims Active Member
    May 15, 2007
    2,722
    +117
    So can I watch 3d content in 2:35:1 format using the lens memory function on its own, or do I need the anamorphic lens as well?
  17. Steve Withers
    Oct 18, 2009
    4,943
    +1,882
    Yes you can use the lens memory function with 3D content and a 2.35:1 screen without needing an anamorphic lens.
    • Thanks Thanks x 1
  18. antsims
    May 15, 2007
    2,722
    +117
    Fab. I think I've found my new pj!!
