AV Player HD what iPad video should have been!
Discussion in 'iPad Forum' started by marlmanxxx, May 5, 2011.
  1. Simba
    Simba Active Member
    Apr 11, 2006
    5,245
    +399
    I tried to play MKV and M2TS 1080 resolution clips on the new iPad but the result was disappointing.
    I used VLC (got it from iTunes ages ago), cinexplayer and Aceplayer - all of them struggled to churn out 1 frame per second.
    I take it those apps aren't using hardware acceleration? Does AV Player HD use hardware acceleration?
  2. BradleyLove
    BradleyLove Member
    Jul 6, 2006
    1,611
    +226
    AV Player HD only uses hardware acceleration for file types that are natively supported by iOS.
  3. AFSTER
    AFSTER Member
    Sep 28, 2005
    1,339
    48
    +27
    just put about 8gb 1080 file onto ipad 3 and it was well laggy
    on av player and also buzz
    i thought it supported 1080 hence itunes doing content
  4. donka
    donka Member
    Sep 19, 2005
    1,872
    +141
    It supports 1080p through the built in Video app since it supports hardware decoding. Buzz etc. can only use hardware decoding for iTunes supported media - there is usually a setting to enable this. Any other non iTunes media type will be decoded in software hence the lag you are experiencing.
  5. bpsmith
    bpsmith Active Member
    Jan 8, 2010
    7,573
    +709
    How many times does this need to be said? If people read the whole thread they would already be well aware of this!
  6. Simba
    Simba Active Member
    Apr 11, 2006
    5,245
    +399
    That application is perfect !!! Now I can play 1080p movies flawlessly!
    • Thanks Thanks x 1
  7. Charis
    Charis New Member
    Jul 25, 2012
    3
    I recently bought AVPlayerHD and none of my Avi files play. They are choppy, the video skips, the sound screeches or the movie just does not play. Sometimes the app won't even open. I have enough free space on the ipad and yes I am adding the files through iTunes. I am beginning to think the problem may be with my iPad! I've uninstalled and reinstalled the app, tried different length movies etc and have not been able to use this app successfully. Rather disappointed after having bought it too. Any suggestions would be appreciated!
  8. Kyuss72
    Kyuss72 Member
    Apr 1, 2011
    254
    +27
    Relax. Your iPad is fine. .avi files are prehistoric and require minimal CPU power. To convince your self just go and watch some YouTube videos or something on the ipad 's native player.
    I am guessing you have a first generation iPad or you are not running the latest iOS on your iPad.
    How am I doing so far?
  9. Charis
    Charis New Member
    Jul 25, 2012
    3
    I have the latest software, OS 5.1.1 and am on the iPad 2. I have no problems with YouTube vids. You think avi files are the problem? Should I convert them to something else?
  10. Kyuss72
    Kyuss72 Member
    Apr 1, 2011
    254
    +27
    I had the iPad 2 and I don't remember having any issues with avi files. mkv files though could be temperamental.
  11. Charis
    Charis New Member
    Jul 25, 2012
    3
    Ok thanks for the feedback. Will have to try a different program then as am not having any joy with this one. Trial and error!
  12. smugor
    smugor Member
    Jan 2, 2006
    203
    +7
    does this new update work then? (claims to play 1080p mkvs smoothly now on ipad3).
    haven't tested yet, was hoping someone could put me out of this suspense..
  13. tonton
    tonton Member
    Aug 22, 2006
    863
    +21
    Jailbreak and install XBMC. Problem solved.
    But I did see the update claiming hardware acceleration, so did wonder the same.. :p
  14. phila67
    phila67 New Member
    Aug 3, 2012
    I used to love this app. Unfortunately the lack of support for streaming from my seagate Goflex Satellite has meant I have had to switch players. Add support for that and I'd be back in a shot
  15. smugor
    smugor Member
    Jan 2, 2006
    203
    +7
    in response to my previous post, i just put a 6.5gb 1080p mkv on there, watched it for 30 seconds and it seems fine. pretty fast to scan through too. impressed.
  16. shahedz
    shahedz Active Member
    Apr 26, 2005
    9,826
    +980
    Hi, how do you actually drags movies over here when connected to a computer via USB.
  17. shahedz
    Apr 26, 2005
    9,826
    +980
    Sorted , this app is superb!
  18. Zooks
    Zooks Member
    Mar 2, 2007
    815
    +72
    Ok I should have read a bit more before I bought this app because now realise I can't stream direct from my readynas to my iPad with this. What app can I use to stream direct with no pc running in between. 8player works a treat but won't do mkv smoothly.
  19. prodrive305
    prodrive305 Member
    Feb 24, 2009
    1,335
    +32
    I use goodplayer, same idea and has converted every format I have thrown at it . £1.99 but worth it
    • Thanks Thanks x 1
  20. shahedz
    Apr 26, 2005
    9,826
    +980
    Just an update, when I play a file on the iPad picture is fine, however if I connect my iPad to a TV via the HDMI the same video looks compressed. however when I play the video via my mac mini which is connected to my TV the file video looks a lot clearer and uncompressed. Any recommendations for settings to avoid this compression or a player that doesn't compress?
  21. leeds united
    leeds united Member
    Jul 26, 2009
    3
    Just about to get a apple AV adaptor. One question before i do can you connect your ipad3 to your tv then play movies via AV Player HD. ?
  22. BradleyLove
    BradleyLove Member
    Jul 6, 2006
    1,611
    +226
    Yes, I do this all the time for content that isn't compatible with the standard video player.
    BBC iPlayer and TVCatchup also work. Annoyingly Lovefilm doesn't. Not tried Netflix or ITV player with the AV adapter yet.
  23. Jason56d
    Jason56d Active Member
    Jul 13, 2006
    2,483
    +324
    Just recommended this to a friend for his iPad, and he said he could not find it in AppStore. I thought he was just being a doughnut, but, he's right!
    It's disappeared, says 'not available in uk iTunes'?
    Could it just be while the apps are being updated for ios6?
  24. shahedz
    Apr 26, 2005
    9,826
    +980
    No longer available. An email a friend got from the developers today.
    something to do with the hardware acceleration which they can't do- so I have been told.
    Date: 20 September 2012 09:41:23 BST
    To: ************************
    Subject: Re: AVPlayerHD not on App Store UK
    Hello
    We are terribly sorry for the inconvenience.
    To our deepest regret, our applications have encountered error issues.
    From Apple's consultation, we have decided to take AVPlayer, AVPlayerHD remove from Appstore.
    We can't promise how long, but we will do our best to come back with a solution.
    Thanks you sincerely
    Best Regards
    ePlayWorks
  25. leeds united
    leeds united Member
    Jul 26, 2009
    3
    If you already have it will it still work then I just bought my av cable so it's just my luck if I have spent £35. :(
  26. shahedz
    Apr 26, 2005
    9,826
    +980
    Same here I bought the HDMI connector a few weeks back!! Good thing my friend noticed it as I was about to upgrade to IOS6.
  27. leeds united
    leeds united Member
    Jul 26, 2009
    3
    So if i upgrade to IOS 6 which i thought was released tomorrow i will lose AVplayerhd?
  28. shahedz
    Apr 26, 2005
    9,826
    +980
    Yes, it's what's holding me off from upgrading now.
  29. BradleyLove
    BradleyLove Member
    Jul 6, 2006
    1,611
    +226
    :confused:
    I upgraded to iOS6 today and AVPlayerHD is still on my iPad.
  30. shahedz
    Apr 26, 2005
    9,826
    +980
    Really my friend said it would remove itself. Thanks for posting will try now.
