Audio Diffmaker
Discussion in 'Hi Fi Systems & Separates' started by Tone-uk, Dec 12, 2010.
  1. Tone-uk
    Tone-uk Member
    Apr 3, 2009
    1,342
    63
    +167
    Just thought I'd post a link to this software which may be useful to those who wish to test for audible effects of
    changing interconnects
    changing speaker cables
    "special" power cords
    vibration control
    different kinds of cd players
    different power amps
    etc etc
    Audio DiffMaker
    Link also provides an AES paper and slide show.
    Best Regards
    • Thanks Thanks x 1
  2. formbypc
    formbypc Member
    Oct 9, 2010
    1,577
    63
    +103
    This doesn't test for 'audible effects', though - it tests for differentials based on the capabilities, design and limitations of this software.
  3. Mr Pig
    Mr Pig Active Member
    Jan 31, 2008
    2,757
    103
    +255
    And the capabilities of the soundcard, microphone and PC. So do you think the sound card in your PC is capable of picking up the, often subtle, changes in hi-performance Hi-Fi system? Is it not like trying to tell a fake oil painting from a real one with only distant pictures taken with a 1MP camera to go by?
  4. Autopilot
    Autopilot Active Member
    Feb 5, 2005
    6,733
    +1,003
    You need to go and read up more on this software then, as you dont understand how it works. It's a serious bit of kit used by many professionals and it works amazingly well.
    • Thanks Thanks x 1
  5. Mr Pig
    Jan 31, 2008
    2,757
    103
    +255
    I don't, that is true, but it does work on the signal translated through the computer sound card, yes?
    And if you wanted to test speaker cables, power amps etc it would also have to rely on a microphone on top of that, yes?
  6. Alan Mac
    Alan Mac Member
    Feb 13, 2007
    1,402
    +233
    No, a microphone is not required.
    Alan
  7. Alan Mac
    Alan Mac Member
    Feb 13, 2007
    1,402
    +233
    I have tried out the Audio DiffMaker software using a couple of the “dyf” files containing an excerpt from the musical “CHESS” (I think).
    Comparing The power amplifier “Home theater moderate cost 100 W monophonic amplifier" with its input signal, it required a total boost of about 40 dB for the difference signal to be roughly the same loudness as the reference track.
    Comparing The power amplifier “Hafler DH200" with its input signal, it required a total boost of about 70 dB for the difference signal to be roughly the same loudness as the reference track.
    Alan
  8. Mr Pig
    Jan 31, 2008
    2,757
    103
    +255
    How do you test differences in speaker cables and power amps without a microphone to record the sound?
  9. Alan Mac
    Alan Mac Member
    Feb 13, 2007
    1,402
    +233
    The sound has already been recorded.
    Do you require a microphone to play back LPs or CDs etc. ?
    Alan
  10. Mr Pig
    Jan 31, 2008
    2,757
    103
    +255
    How do you record the signal emanating from a speaker without a microphone?
  11. Alan Mac
    Alan Mac Member
    Feb 13, 2007
    1,402
    +233
    You don’t. Why would you want to involve the loudspeaker, apart from it providing an electrical load for the amplifier?
    Alan
  12. karkus30
    karkus30 Well-Known Member
    Jul 29, 2002
    13,993
    +1,279
    Errr, maybe I'm a bit thick but it says you can test the entire audio chain including room acoustics. I like the idea, can someone show the wiring set up because I can't work out how this is possible without a Mic?
    I can't see how you can even compare things from the power amp end of the chain. Can you input the speaker cables directly into the soundcard from the power amp, or is it something else?
    Me and poor Mr Pig are obviously a bit confused.:rolleyes::lease:
  13. Mr Pig
    Jan 31, 2008
    2,757
    103
    +255
    Yes. The post says that it can test speaker cables and power amps. That's what it says.
    And it doesn't test for audible differences, if you'll excuse me saying. It tests for electrical differences which are within the resolving capabilities of the sound card/computer DAC in question. And I hate to say it but for most computers, that ain't great...
  14. Mr Pig
    Jan 31, 2008
    2,757
    103
    +255
    Sorry but I just had to quote that sentence as I liked it so much. Superb :0)
  15. Alan Mac
    Alan Mac Member
    Feb 13, 2007
    1,402
    +233
    Hardware connections are shown in the Help section entitled “Hardware Connections and Program Sources”.
    NOTE THE WARNING:
    “You should NEVER connect the output of a power amplifier directly to a sound card input....”
    Alan
  16. Autopilot
    Feb 5, 2005
    6,733
    +1,003
    If I misread that as patronising and smug, I apologise.
  17. Alan Mac
    Alan Mac Member
    Feb 13, 2007
    1,402
    +233
    For objective evidence that MP3 compression really does cause easily audible signal degradation, listen to the horrendous difference signals from:
    Audio DiffMaker example files
    MP3 compression, 128 kbit/s and 256 kbit/s
    In comparison with these very large and distorted difference signals, the difference signals from nearly all other audio components pale into insignificance.
    The only other “component” with a difference signal comparable with the 256 kbit/s MP3 is likely to be the analogue LP. But anyone with an LP cutting lathe is unlikely to be willing to provide such evidence.
    Alan
  18. formbypc
    formbypc Member
    Oct 9, 2010
    1,577
    63
    +103
    I don't really need Diffmaker to tell me that mp3 coding introduces audible degradation, as I can hear it for myself.
    I'm not sure what point you're making with reference to LP - you're referring to the difference between what and what?
  19. Mr Pig
    Jan 31, 2008
    2,757
    103
    +255
    Music and noise.
  20. trailer
    trailer Active Member
    Dec 22, 2004
    2,863
    +241
    This isn't a hi-fi component comaparison tool. Think of it as a way, for example, of comparing a remastered CD to the original.
  21. formbypc
    formbypc Member
    Oct 9, 2010
    1,577
    63
    +103
    The OP has a different opinion, though .....
  22. trailer
    Dec 22, 2004
    2,863
    +241
    I'm surprised no one tried to explain this before.
  23. formbypc
    formbypc Member
    Oct 9, 2010
    1,577
    63
    +103
    You mean that the OP has totally misunderstood what it can/should be used for?
  24. trailer
    Dec 22, 2004
    2,863
    +241
    Well as far as I can tell it is used for comparing two recordings. How you get those recordings is your business I guess.
    More vagueness.
  25. Autopilot
    Feb 5, 2005
    6,733
    +1,003
    Read the site.
    Plus have a google, there are loads of more knowledgable and hardcore sites with some good examples.
  26. Tone-uk
    Tone-uk Member
    Apr 3, 2009
    1,342
    63
    +167
    Seems like a few have you have read the site and understand what it's all about and some of you have not and do not!!
    The answers are all there - as hinted to by Alan Mac/Autopilot - have a read if your are interested.
    In fact, it's probably much easier to give it a try and learn as you go along.
    (don't know how that "!" got up there as a title??)
  27. trailer
    Dec 22, 2004
    2,863
    +241
    Well for those who haven't would you be obliged to summarise please?
  28. Tone-uk
    Tone-uk Member
    Apr 3, 2009
    1,342
    63
    +167
  29. trailer
    Dec 22, 2004
    2,863
    +241
    OK, I'll do it. Import two recordings into the program and the software will determine any differences between them.
  30. Tone-uk
    Tone-uk Member
    Apr 3, 2009
    1,342
    63
    +167
    Is that your summary from what I linked too???
