Audessey Eq setting
Discussion in 'Integrated Amplifiers & Receivers' started by The WB, Aug 31, 2006.
  1. The WB
    The WB Guest
    Today I watched a movie in a Flat eq setting. I have to admit is sounded to me much better than the audessey eq. I found everything just right, I found it had a warmer sound while the audessey had a brighter sound. What eq setting do other members use it will be intresting to know.I find it good in music as movies also which was recommended to me.
  2. Dr Manhattan
    Dr Manhattan Active Member
    Mar 16, 2001
    8,656
    +565
    I found the opposite. For Movies the Flat setting appears a bit brighter so I prefer the Audyssey setting. If you use any of the THX Modes with EQ make sure it's set to Flat as well, rather than Audyssey.
  3. The WB
    The WB Guest
    How come? And yes I always watch my movies in THX mode is that why mabey audessey came into bright for me?
    Cheers!
  4. Dr Manhattan
    Mar 16, 2001
    8,656
    +565
    Should be the other way around if you use Audyssey with THX, it can kill the higher frequencies stone dead as Audyssey uses a roll off and so does THX processing. Flat doesn't roll off the treble so lets THX Re-Eq do it's thing properly.
    If Audyssey is bright then I'd have a go at re-running the EQ again.
  5. DeafPhil
    DeafPhil Guest
    I agree with The WB, when I use Audessey EQ I lose most of the bass making it sound much brighter. Using the Flat EQ with THX (which is what the manual says you should use if I remember correctly) increases the impact of explosions etc. in movies
  6. The WB
    The WB Guest
    the way you put it deafphil was right, that is exactly what i was experiecing also. I definelty found I had much more impact in sound of flat eq. i also read it on a audessey article regarding thx saying it has to be flat eq. So you both were right in being flat eq on thx.
  7. Eddy Boy
    Eddy Boy Member
    Dec 9, 2004
    937
    28
    +35
    When set to Audessey it actually performs some of the role off of high frequencies but not to the level of that used in cinemas. THX processing performs the role off in the same way has the cinema. Rarely would you use the two together. (just for anyone who is reading this and think what are they on about)
  8. GlynH
    GlynH Member
    Dec 9, 2002
    274
    +8
    Wasn't there some issues with earlier software causing a bass suck-out?
    Does your XV have current software?
    Please don't ask me what is current and what version mine is - it's still in the box...:eek:
    Kind regards,
    -=Glyn=-
  9. Dr Manhattan
    Mar 16, 2001
    8,656
    +565
    Early A1XV's and A11XV's had a problem with Audyssey as it wasn't EQ'ing correctly below 100hz and was also over-emphasizing the higher frequencies a bit too much. I believe THX Ultra2 BGC (Boundary Gain Compensation) was also defaulting to ON.
    Yours should have the latest firmware so will be fine. :)
  10. The WB
    The WB Guest
    Talked to chris from audessey today and he said the THX and Audessey eq do not go together because the sound is to bright. Thx has to run flat eq.
