Argos Value Freeview £15 - Upscale To 1080i?
Discussion in 'Freeview Forum' started by ben.light89, Feb 27, 2009.
  1. ben.light89
    ben.light89 Member
    Feb 27, 2009
    Was just looking at some Freeview boxes on Argos becuase I have had mine ages now and starting to get a little worn..
    Anyway, Argos are advertising this:
    Buy Argos Value LPDV205B Matt Black Digital Set Top Box. at Argos.co.uk
    Here is the specification:
    Digitally interactive.
    Digital text.
    Supports RF loop-through.
    Digital video broadcasting (DVB).
    Subtitles available.
    Auto setup.
    Auto detection of new channels.
    Auto scan for new channels.
    Now and next electronic programme guide.
    7 days electronic guide.
    1 SCART socket.
    Upscales to 1080i.
    Freeveiw playback approved.
    Remote control requires 2 x AAA batteries, included.
    Size (H)4.5, (W)23.7, (D)12cm.
    Weight 0.46kg.
    This bit had me, Upscales to 1080i.
    Surely for £15 you cant have a value freeview that upscales?
  2. prking
    prking Member
    May 2, 2008
    1,441
    63
    +203
    It also says that its Freeview Playback approved, if so it would be the world's cheapest PVR. I'm sure they have made a mistake.
  3. ben.light89
    ben.light89 Member
    Feb 27, 2009
    Im sorry, Im a bit new to this, what is PVR?
    Is it unlikely that it is a 1080i PVR then?
  4. y2k
    y2k Active Member
    Jan 3, 2008
    3,279
    +297
    Don't think it records m8 so wouldn't be a PVR.
  5. ben.light89
    ben.light89 Member
    Feb 27, 2009
    Is it possible that is an upscaler though?
    They dont seem to advertise very well...
  6. Andy98765
    Andy98765 Active Member
    Feb 15, 2006
    10,374
    +1,491
    You will not get 1080i out of a Scart socket, HDMI/DVI yes.
  7. ben.light89
    ben.light89 Member
    Feb 27, 2009
    Yeah that's what I though, but it does not mention HDMI/DVI so i doubt this is possible.
    Just goes to show how much companies think they can rip us off these days...
  8. y2k
    y2k Active Member
    Jan 3, 2008
    3,279
    +297
    PVR = Personel video recorder
    If it has HDMI then it will upscale the picture but no mention of HDMI. I always thought that most LCD or Plasmas upscaled the picture if it was HD ready and has a digital tuner built in, may be worth looking into because it would probably do a better job than a cheap freeview box anyways.
  9. prking
    prking Member
    May 2, 2008
    1,441
    63
    +203
    That was might point, the description is clearly for an upscaling PVR, so you would need to contact Argos for the correct spec.
  10. Already Taken
    Already Taken Member
    Oct 5, 2008
    146
    +10
    It won't be intentional , just someone at Argos doing a copy & paste of anonther item description and getting it wrong.
  11. y2k
    y2k Active Member
    Jan 3, 2008
    3,279
    +297
    Just says "Upscales to 1080i" m8, no mention of PVR or being able to record anything.
  12. scribbler101
    scribbler101 Member
    Jun 17, 2008
    1,407
    63
    +118
    As no-one here knows, have you phoned Argos?
  13. grahamlthompson
    grahamlthompson Well-Known Member
    Aug 3, 2006
    18,764
    163
    +3,104
    Not most, all do. Without scaling the picture would either be too small or too big depending on the signal you send it. For example a HR Ready display with 1320 x 768 screen pixels sent a 720 x 576 SD signal will have to invent extra pixels (upscale) to get 1320 x 768 pixels. The same TV sent a 1920 x 1080 HD signal will have to remove pixels (downscale) to 1320 x 768 pixels. HDMI scalers on freeview boxes are largely a gimmick as all but the cheapest TV's will have much better and more expensive scalers than you will get on a Freeview PVR (including the Topfield 5810 and Humax 9300).
  14. prking
    prking Member
    May 2, 2008
    1,441
    63
    +203
    It says Freeview Playback approved. Freeview Playback (now called Freeview+) is the promotional name for PVRs which meet the Freeview specification. As I and others have said, someone has copy/pasted the description for a Freeview PVR instead of the correct description. The same innacurate description is used for several of the boxes.
    • Thanks Thanks x 1
