Anything better than handbrake
Discussion in 'iPad' started by Hopalong, Jan 17, 2011.
Thread Status:
Not open for further replies.
  1. Hopalong
    Hopalong Member
    Jan 11, 2008
    336
    +21
    Hi all I am currently using handbrake to convert my episodes of smallville so I can watch them on my iPad. Each episodes which is only 44 minutes long is taking 1hour 30 mins to convert which seems bonkers to me:rolleyes:
    I was just wondering if anybody else used a different programme to convert video files which was quicker and was just as good.
    I've still got season 8 and 9 to go and with 20-24 episodes in each season it will take forever to convert all of them using handbrake.
    Thanks.
  2. StevieBuck
    StevieBuck Member
    Jul 7, 2007
    3,705
    +685
    There's a list of similar programmes to Handbrake given here which you may be able to use instead:
    HandBrake 0.9.5 - VideoHelp.com Downloads
    The speed at which the files convert however will largely come down to the speed of your computer (laptop) though, and the quality settings you choose within the programme.
    I take it you are converting the files from DVD?
  3. celsius
    celsius Member
    Jun 1, 2008
    458
    28
    +39
    Instead of finding a better way to convert the video, why do you not explore ways to play the video on ipad WITHOUT having to convert them?
    There are many ways you can do that and for free.
    I have given up converting video (for PS3/PSP/PMP) a long time ago. They are time consuming and IMO, totally unnecessary.
  4. Tempest
    Tempest Active Member
    Jan 11, 2002
    4,075
    103
    +431
    I don't recall the name, but there is one system, that you buy which comes with a USB dongle which contains hardware to speed up the conversion process and I believe improve the quality at the same time.
    Perhaps someone here can find a link to it?
  5. Hopalong
    Hopalong Member
    Jan 11, 2008
    336
    +21
    No there not from DVD there downloaded files in the divex format entire series is only 7gig but I must admit the pc is about 5 years old now that being said it's had a very easy life it's only ever been used for storing files on only time it gets turned on is when I want to sync up my apple stuff it's got a 3.2ghz processor so I would have thought that was decent enough for such a task.
    It's took it 6 hrs to do 4 episodes :eek:
    Didn't think it would be that bad started off thinking this morning I'll just put a couple of series of smallville on my iPad to watch while I'm in hospital turned into a major time consumer :(
    Almost tempted to just buy the series off iTunes instead of being a tight sod:D serves me right for not getting vlc when it was still available
    Thanks all for the advice I'll check out some of the other conversion programmes.
  6. Theydon Bois
    Theydon Bois Moderator
    Jun 26, 2007
    12,840
    171
    +4,471
    Downloaded fom where?
  7. internetuser
    internetuser Active Member
    Jul 17, 2003
    3,203
    83
    +211
    Use vlc ?
  8. Shoka
    Shoka Member
    Jan 10, 2002
    4,327
    +241
    Roxio Popcorn is an alternative, it's not free though. It's quicker than handbrake but I find the quality of Handbrake conversions far superior.
  9. peterjcat
    peterjcat Member
    Oct 13, 2009
    278
    28
    +37
    Handbrake is in almost all cases the best tool for the job. It's only slow because the default settings go for quality and small file sizes rather than speed. Reduce the quality slider, or even go for MPEG-4 (ffmpeg) rather than H.264 (x264) for the video codec, and things will go much faster -- you'll just end up with slightly lower quality and/or larger files, but if you're in hospital you probably won't care about that :)
    • Thanks Thanks x 1
  10. mritschris
    mritschris Member
    May 27, 2010
    452
    +18
    Use total Video converter. I have used it for years and it has converted my tv shows with default settings on the program in under 10minutes. With really good HD quality. Although i was converting 350mb .avi files. It's also very easy to use and has a good GUI.
    http://www.effectmatrix.com/total-video-converter/
    • Thanks Thanks x 1
  11. Nebbs
    Nebbs Member
    Apr 21, 2008
    1,033
    +160
    If you missed Vlc why not try cineXplayer, does pretty much the same as vlc
    • Thanks Thanks x 1
  12. Hopalong
    Hopalong Member
    Jan 11, 2008
    336
    +21
    Thanks for all replies I'll give that total video converter a try,also moved some files over to the wife's new laptop with a quad core i5 processor to see if that does it quicker,
  13. dejongj
    dejongj Well-Known Member
    Sep 11, 2003
    28,183
    +4,356
    Your wives laptop will do it a lot quicker, your hardware is by far the limiting factor in this process.
    A box like the elgato h.264 can transform your machine for this.
  14. Theydon Bois
    Jun 26, 2007
    12,840
    171
    +4,471
    Thread now locked. PM me to answer the question and I will reopen the thread.
Thread Status:
