anyone know of a small underseat subwoofer?
Discussion in 'ICE, Sat Nav & Dash Cam Forum' started by cameronl, Sep 13, 2006.
  1. cameronl
    cameronl Member
    Aug 13, 2002
    1,137
    38
    +13
    hi there, the sound in my car is very average. I really wish I had more bass!
    can anyone recomend a good (and small) under the seat subwoofer?
    thanks
    CaM
  2. cj101
    cj101 Member
    Apr 1, 2005
    67
    +3
  3. cameronl
    cameronl Member
    Aug 13, 2002
    1,137
    38
    +13
  4. Phil 55
    Phil 55 Guest
  5. cameronl
    cameronl Member
    Aug 13, 2002
    1,137
    38
    +13
    I've ordered the other one now.....it will soon be bass time!
    CaM
  6. carlymart
    carlymart Member
    Jan 11, 2004
    537
    +18
    i have one of the alpines in the foot well of my elise and it works great and is an easy install
  7. happyink
    happyink Guest
    hi, just bought a Pioneer TSWX22A powered subwoofer, i have a radio cd player that came with my 2006 santa fe, no make, the only name that i can see on the inside is HMC. The rear speakers are rubbish, the fronts very good so i thought i´d fit the active sub. the radio/cd player does not have a line output, but the sub can be connected by the speaker inputs, i did all of this and the sound was worse.i checked and double checked everything, i can only think that my radio is a waste of space. any suggestions?
  8. Leaat23
    Leaat23 Member
    Oct 24, 2005
    177
    +14
    Happyink, sounds like its time for a new head unit, mate, one with RCA outputs. It might be worth checking the connections you have made to the sub for any shorts/loose connections ETC.
