Any structural Engineers? Need to convert kN/m3 to kg/m3
Discussion in 'General Chat' started by Laubi02, Oct 22, 2012.
  1. Laubi02
    Laubi02 Active Member
    Jan 30, 2009
    5,606
    +247
    I've got the typical density of reinforced concrete - 17 to 24kN/m3. But I need it in kg/m3 format. anyone know how to do this?
  2. MIghtyG
    MIghtyG Active Member
    Mar 1, 2008
    2,696
    +717
    Density in newtons per meter cubed!?! weird :laugh:
    afaik it should be a case of g=9.81ms^-2
    and F=M.A so M=F/A (Keep in mind Newtons are the SI unit for force and Kg are the SI unit for mass)
    17000/9.81=1732kg/m^3 to 24000/9.81=2446kg/m^3
  3. nheather
    nheather Well-Known Member
    Oct 6, 2004
    11,808
    +2,022
    They are different dimensioned units. One is a mass per cubic metre and one is a force per cubic metre.
    The most common way of converting a static mass to a force is to multiply it by the acceleration due to earth's gravity. An easy rule of thumb is 10 but more accurately it is 9.81.
    Cheers,
    Nigel
  4. nacmacfeegle
    nacmacfeegle Active Member
    May 1, 2008
    3,076
    +832
    1700-2400 kg/m3 approx.
    Density isn't normally quoted in N/m3 though, dunno why it is here.
  5. DPinBucks
    DPinBucks Active Member
    Dec 2, 2008
    5,031
    +926
    1kgf (kilogram of force) = 9.807 Newtons. So to convert kN to kg, divide by 9.807.
    Strictly speaking, that's only meaningful in standard gravity, but the conversion factor applies universally.
    ===== EDIT ====
    MightyG's done it for you.
  6. nheather
    Oct 6, 2004
    11,808
    +2,022
    Sorry, pedant alert.
    It can't apply universally because it varies greatly depending on where you are in the universe. ;)
    Cheers,
    Nigel
  7. nacmacfeegle
    May 1, 2008
    3,076
    +832
    It will vary depending on where you are on earth and at what altitude, but when we have a huge variation on the specified density, who cares?:)
  8. DPinBucks
    Dec 2, 2008
    5,031
    +926
    A pedant replies:
    No, it doesn't. :)
    Newtons and kilograms are arbitrary units. Note that I defined the conversion in terms of kgf, not kg. kg are units of mass, which are universal. Newtons are arbitrarily assigned to kg mass on Earth. The same principle applied on another planet wouldn't be Newtons. But Newtons on Mars are still Newtons. They're not very useful there, that's all.
  9. Laubi02
    Jan 30, 2009
    5,606
    +247
  10. logiciel
    logiciel Moderator
    Feb 2, 2008
    45,526
    +4,418
    kN=1000*kg*m/s*s so kg=kN*s*s/1000*m
    • Thanks Thanks x 1
