Anti Glare screen protector iPad 2
Discussion in 'iPad' started by jamesh1000000, Jun 2, 2011.
  1. jamesh1000000
    jamesh1000000 Member
    Jul 25, 2007
    46
    Im after a good quality anti Glare screen protector, could anyone recommend a good one??
    thanks
    James
  2. RheesSnow
    RheesSnow Member
    Oct 29, 2010
    162
    +14
  3. oafc0000
    oafc0000 Member
    Jun 27, 2005
    134
    16
    Installed the Power Support Anti Glare the other night. Its very good. Does effect the clarity of the screen slightly but the benefit of now not having the most expensive portable mirror in history is a huge benefit.
  4. windfall
    windfall Member
    Oct 19, 2003
    2,136
    48
    +38
    Ive got a Belkin one at the moment and it's really bad, scratches too easily and looks terrible, so I'll give one of these ago to.
    :smashin:
  5. spanna
    spanna Member
    Sep 23, 2005
    1,404
    48
    +98
    What about the moshi ivisor thing? That seems to be getting good reviews everywhere, especially with it being reusable and very easy to install.
    Has anyone got one?
  6. jamesh1000000
    Jul 25, 2007
    46
    Bought the ivisor last week and couldnt be more pleased with it :)
  7. SHATNERSTACTIC
    SHATNERSTACTIC Active Member
    Sep 9, 2007
    3,014
    +411
    Sounds promising. Mine arrived this morning. Hopefully we'll have some sunshine over the weekend here for me to give it a try.
  8. tjhilder
    tjhilder Member
    Nov 7, 2008
    711
    +45
  9. spanna
    spanna Member
    Sep 23, 2005
    1,404
    48
    +98
  10. SHATNERSTACTIC
    Sep 9, 2007
    3,014
    +411
    Got mine from cancom. Had no trouble with unwanted peeling but haven't had it long. It's effective enough to allow me to read from the kindle app in the bright sunshine today so I'm pleased so far.
  11. Triggaaar
    Triggaaar Active Member
    Apr 13, 2003
    4,339
    +558
    these Media Devil matte, anti glare protectors have good reviews too. May get those or the moshi.
    Does the moshi affect the picture quality much (ok - it won't a lot and must do a bit, but compared to others)?
  12. donka
    donka Member
    Sep 19, 2005
    1,868
    +141
    The prices of these screen protectors are ridiculous - I used to review these years ago for Pocket PC devices and some of the best ones were actually very cheap.
    I'm on the lookout for one, not so much for the anti glare but one that allows the finger to glide smoothly across the screen without it feeling sticky because the surface is so glossy. Any ideas? I know matte screen protectors are the best in this regard but compromise the display quality too much for my liking. I don't use my iPad 2 outdoors in daylight so screen reflections are really an issue for me.
  13. Triggaaar
    Apr 13, 2003
    4,339
    +558
    It can be crazy can't it. I would say though, that if you want something to give you a clear picture, and cut down on the fingerprints that are hideous with the naked iPad, it can't be easy to make something.
    I wouldn't be so worried about fingerprints on an iPhone, but on an iPad they are a pain.
  14. splinters69
    splinters69 Active Member
    Dec 17, 2007
    7,093
    +493
    Currys are selling off double packs of speck antiglare protectors for 97p down from £20. Instore only...:D
  15. donka
    donka Member
    Sep 19, 2005
    1,868
    +141
    For iPad 2??
  16. oafc0000
    oafc0000 Member
    Jun 27, 2005
    134
    16
    A month in I am VERY happy with the Power Support Anti Glare! Would highly recommend it.
  17. splinters69
    Dec 17, 2007
    7,093
    +493
    Alas no, but the screen is exactly the same size. Only downside is it cover the front camera. However, it does give everything a lovely soft focus look...even makes me look pretty...:D
  18. Inotrope
    Inotrope Member
    Dec 23, 2004
    640
    +31
    Very impressed with the Mediadevil Matte screen protector - which has converted me from invisible shield.
    High quality, and a lovely smooth finish. A bonus that there a two in a pack for £14ish !
  19. sneeks
    sneeks Active Member
    Jan 9, 2007
    3,706
    +407
    I bought and fitted one of these last week. Screen clarity is definitely reduced more than other matte protectors I have used in the past but it installed perfectly with no bubbles. My pack also arrived and both the plastic applicator card and screen cleaning cloth were missing.
  20. aaronkwok
    aaronkwok Member
    Sep 23, 2009
    30
    ZAGG and SGP seem to be very famous.
  21. Hades
    Hades Active Member
    Jan 10, 2002
    11,666
    +1,125
    Hmmm I've just purchased the MediaDevil Matte screen protector and not sure whether to fit it or not now. Been reading a few articles now including here that it reduces the image quality. Not sure if I should return it and get the Crystal Clear instead.
  22. Hades
    Hades Active Member
    Jan 10, 2002
    11,666
    +1,125
    Just to update that I stuck with the Matte version and have no issues with it.
  23. branny
    branny Active Member
    Feb 26, 2005
    3,545
    83
    +207
    That's the one I use. Used them on the iphone in the past and they are quality.
    There is no doubt that they reduce screen quality, so......
    Are there any anti glare that don't affect screen quality?
    B
  24. adonis
    adonis Member
    Sep 6, 2005
    1,481
    +90
    as above, any out there that dont reduce much of the quality of the screen when watching movies?
  25. Peew971
    Peew971 Member
    Aug 14, 2007
    1,761
    +194
    I've just installed the Matte MediaDevil. Great quality, perfectly cut and touch is still very responsive but it does really affect picture quality. Games and videos in particular are very affected but on a positive note it does what it says, it truly is anti glare.
    I'll give it a few days but unless there's the perfect AG film out there I might go with a clear one :(
