mtenga
Did Andrew send you a us update for the oppo? It won't work on our models. You need to take the beta off the oppo uk site. The uk beta is about to go official as the us has just done.MRX finally updated. Several issues but got there in the end.
Lip sync issues remain and I now have a unacceptable pop and thump through the sub when changing channels on Sky. This is due to codec change from PCM to DD. Totally unacceptable noise that wasn't there prior to this update.
Oppo 103 says I am on the latest firmware via net, which it is not according to Oppo. Tried to install from USB but player says no firmware found.
Looks like MRX will need to be swapped out and not sure what's going in with Oppo. Have emailed Nick.
I'm not recognising your problems on 1.1.9. I've got no thump when the PCM adverts change to the dd programme and the delay is improved though still a bit obvious. My lip sync is improved after installing the two betas as well.
