Antares TAS-350 question
Discussion in 'Satellite TV Forum' started by kb9, Apr 4, 2007.
  1. kb9
    kb9 Guest
    I have just obtained a digital FTA satellite receiver of the above model, and it works just fine.
    However it does not appear to have all of the Astra 19.2 channels set. It appears to have no over-the-air update mode, but it does have an update mode via the serial port. It appears to be able to take both firmware and channel data updates via RS232, I just need the files.
    Rather than manually set each new channel, does anyone know where I can get the updates to upload to it. There is no indication in the manual of a web site (or even postal address) at all.
    As it is a new model, there may be no firmware update yet, but hopefully there will be channel data updates.
    regards,
    Keith
  2. fernandez
    fernandez Active Member
    Jun 5, 2005
    6,028
    +1,039
