Annoying Commentary on movie & Documentary channels
Discussion in 'Virgin Media' started by haventaclue, Jul 1, 2009.
  1. haventaclue
    haventaclue Member
    Dec 12, 2008
    69
    Hi. Does anyone know how to turn this on, use will probably know what i mean it the background commentary that describes whats going on, on the channel :mad::mad:. Is there a shortcut key i input on the remote etc, iv tried going through my settings doesnt seem to be any options to change it
  2. niall@inkything
    niall@inkything Member
    Jun 28, 2006
    662
    +68
    It sounds like a commentary for blind or partially-sighted people who want to watch TV. You should look for options marked 'accessibility' to switch it off... it might be in the same section as 'subtitles for the hard of hearing'. Sorry I can't help with your specific setup.
  3. Sly Fly
    Sly Fly Member
    Nov 23, 2004
    1,065
    63
    +114
    Yup, in the menu settings for sure. There's a button the switches it off/on from the remote as well (I think) but from memory I can't tell you which one it is...
