ADVICE on RGB to Plasma VGA convertor
Discussion in 'Plasma TVs' started by terryshep, May 2, 2002.
  1. terryshep
    terryshep Member
    Mar 26, 2002
    194
    +4
    i would like some advice on the JS Technology RGB to Plasma VGA convertor.
    i have a Panasonic TH-42PW4B 42" plasma tv and want to connect Sky Plus to it using this convertor. At the moment it is connected via a scart to composite video connector and the picture is very good. How much of an improvement will i see by going from RGB to VGA ?
    Also when i have my PC connected to the VGA i only get the options to display 4:3 and 16:9, will i have all of the other options available (such as 4:3, 16:9, Zoom, Panasonic Autio & Just) if i use the above convertor. I can't use component as i have my DVD player and Xbox connected in there.
    Does anyone know where you can get a component switcher box so that i can connect both the xbox and DVD player up to the Plasma tv and switch between them without actually replacing connections as i do now.
  2. Ten
    Ten Member
    Jul 1, 2001
    163
    16
    how about using a quattro switcher, get some phono to scart convertors and plug them all in via it
    or as recommended by someone on this forum, use a audio/video (composite) switcher, much cheaper
    ten
  3. NeilS
    NeilS Member
    Nov 16, 2001
    148
    +5
    If you're using composite video then going to RGB will be a big improvement.
    You should have 16:9 4:3 and Zoom modes on VGA.
    Neil
  4. terryshep
    terryshep Member
    Mar 26, 2002
    194
    +4
    yes please
  5. terryshep
    terryshep Member
    Mar 26, 2002
    194
    +4
    i take it that the JS Technology RGB to Plasma VGA convertor is not that good for the lack of replays
    so im not getting one thanks for saveing me £120 :D
