Adding new cable to existing dish/lnb
Discussion in 'Freesat Forum' started by barry7767, Oct 3, 2008.
  1. barry7767
    barry7767 Member
    Sep 19, 2007
    32
    11
    +6
    Probably about to answer my own question - currently have Sky HD, want to add a freesat HD box to dish to view in conservatory. When I connect the new cable to the LNB, what precautions do I need to take? Should I unplug power to Sky HD box or even unscrew the two feeds to Sky box? Is it possible to get a shock? :eek:
  2. BrianMc
    BrianMc Member
    Dec 18, 2007
    1,262
    63
    +156
    There should be no problem whatever you do! The SkyHD STB is supplying a low voltage (about 15V DC) to each of the two LNBs it is connected to. There should be no voltages present on the other two outputs.
    Powering off the SkyHD box at the mains is probably safer all the same!
    • Thanks Thanks x 1
