Acrantophis House reno with av living room.
Discussion in 'Members' Home Cinema Gallery' started by acrantophis, Mar 4, 2012.
  1. acrantophis
    acrantophis Member
    Dec 27, 2009
    168
    +10
    Having recently sold up and purchased a new property (3 bed bungalow) with a great location but needing a total update. We set about a partial re-design, new extension and update incorporating a few av orientated features. The plan would be to convert two bedrooms into a fairly large living room, have a long , open hallway to enable access from the front of the building to the now, rear of house living area and an extension added to the side. As we actually have to live in the property whilst renovating, we will do the work in two phases, phase 1 will be the new living room, hall and extension, on completion, we will occupy this part and begin the remainder of the house.
    [​IMG]
    Before
    [​IMG]
    After
  2. acrantophis
    acrantophis Member
    Dec 27, 2009
    168
    +10
    The before pics
  3. acrantophis
    acrantophis Member
    Dec 27, 2009
    168
    +10
    Work begins on converting the bedrooms.
  4. acrantophis
    acrantophis Member
    Dec 27, 2009
    168
    +10
    and continues....
    • Thanks Thanks x 1
  5. acrantophis
    acrantophis Member
    Dec 27, 2009
    168
    +10
    Puss thinks i need a wash after the wall cutting
  6. Seventy1
    Seventy1 Member
    Feb 18, 2010
    186
    28
    +27
    Your cat is amazing! Is that a Pixie bob or am I mistaken?
    Also looking forward to seeing your project progress ;)
  7. acrantophis
    acrantophis Member
    Dec 27, 2009
    168
    +10
    lol, No, he`s an early generation Bengal. ..
  8. acrantophis
    acrantophis Member
    Dec 27, 2009
    168
    +10
    Foundations begun for the new extension.
  9. phil5366
    phil5366 New Member
    Oct 23, 2008
    1,430
    +275
    Keep the pics coming!
  10. acrantophis
    acrantophis Member
    Dec 27, 2009
    168
    +10
    And on with the roof.
  11. Rick2102
    Rick2102 Member
    Nov 2, 2011
    339
    28
    +46
    Hi acrantophis.
    Keep the pics coming, and looking forward to updates :smashin:
    Do you know the angle/pitch of the roof? Are you tiling it?
    I am looking at a similar pitch roof and not sure if it will be ok tiled.
    Thx.
  12. acrantophis
    acrantophis Member
    Dec 27, 2009
    168
    +10
    Hi Rick, as the origional part of the house has a low 9 degree pitch, we had to match it for sake of appearance, we were looking at DECRA tiles, but we are possibly on the limit or below it so far as angle is concerned . So for the time being, we matched the origional roof and had it felted, we will look at the two roofs together at a later date with a view to the final finish.
  13. acrantophis
    acrantophis Member
    Dec 27, 2009
    168
    +10
    Meanwhile the new living room has to be prepped and wired, we are going 7.1 but not sure at this point if the window placement will interfere overmuch as the side speakers will be closer to the rear speakers than we`d like but the wiring is in and we`ll just have to see.
  14. acrantophis
    acrantophis Member
    Dec 27, 2009
    168
    +10
    HDMI for projector run across the room, HDMIS to tv, 4 rear speaker cables , 4 cat5 , Satellite coax, freeview coax, coax incase we change to virgin, trigger from screen to amp, telephone line....have i forgotten anything ? Too late! Framework to hold the projector screen goes together.
  15. acrantophis
    acrantophis Member
    Dec 27, 2009
    168
    +10
    As we will be using sonos and various ipads, ect, We thought to check wireless coverage in the new build, and we didnt have enough ! So after going around with a netbook and doing a broadband speedtest in various areas, we purchased a wireless extender, the optimum position was high up in the new hallway, so we were able to fit an extra single socket to power the extender high up at ceiling level. Now, from our incoming 10mb connection, we have 7mb out in the garden.
  16. Rick2102
    Rick2102 Member
    Nov 2, 2011
    339
    28
    +46
    Hi acrantophis,
    Yeah, might have looked a bit strange, you can work with differnt heights but different pitches can look a bit odd sometimes.
    Thanks, the Decra tiles look interesting and only need a 10 degree pitch which is good. Your project is looking REALLY good, and loving the updates. Look forward to more pics.
    Good luck. :smashin:
  17. acrantophis
    acrantophis Member
    Dec 27, 2009
    168
    +10
    The roof goes on and the extension finished.
  18. acrantophis
    acrantophis Member
    Dec 27, 2009
    168
    +10
    Internally, first fix wiring, boarding out , plastering, second fix and paint.- all done evenings and weekends, christmas day, boxing day.....
  19. acrantophis
    acrantophis Member
    Dec 27, 2009
    168
    +10
    Screen goes in, beamax 106 ".
  20. acrantophis
    acrantophis Member
    Dec 27, 2009
    168
    +10
    And is given a thorough testing. lol
  21. acrantophis
    acrantophis Member
    Dec 27, 2009
    168
    +10
    The living room. Rear speaker wiring, projector mount, doors.
  22. acrantophis
    acrantophis Member
    Dec 27, 2009
    168
    +10
  23. acrantophis
    acrantophis Member
    Dec 27, 2009
    168
    +10
    Nice new couch on order too. Different colour and a couple of extra seats though.
  24. acrantophis
    acrantophis Member
    Dec 27, 2009
    168
    +10
    New front door and led light from steiner.
  25. acrantophis
    acrantophis Member
    Dec 27, 2009
    168
    +10
    Thats about all for now as the living room is now full of kitchen cabinets and won`t progress any further until the kitchen is finished. I`ll update after this.
  26. acrantophis
    acrantophis Member
    Dec 27, 2009
    168
    +10
    Blok arrived today, beautiful piece of furniture, cant recommend highly enough. It was more expensive than many other offerings and had to justify it to myself a few times, but in the flesh , its worth every penny, so much more substantial and better made than possibly any other furniture I've ever seen and the service exemplary , not to mention supporting a British company.
  27. acrantophis
    acrantophis Member
    Dec 27, 2009
    168
    +10
    New Sofa also arrived this week, sadly not quite as ordered, will do the job until the correct one arrives in another 3 months ! Its the opposite way around to the ordered version.
  28. acrantophis
    acrantophis Member
    Dec 27, 2009
    168
    +10
    The good stuff starts to happen after spending most of the day mounting speakers and setting up the amp and projector.
  29. Rodrigues
    Rodrigues Member
    Dec 30, 2011
    135
    +42
    Looks great, clean, beautiful room, congrats!
    Is that a REL subwoofer?
    [​IMG]
  30. Silverblack
    Silverblack Active Member
    Sep 24, 2008
    2,582
    +432
    Thats seriously looking top notch that is!!!:thumbsup:
